CB/Scanner antenna mounting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by squirrelNUts, Apr 2, 2010.
  1. Apr 2, 2010 at 8:16 PM
    squirrelNUts
    squirrelNUts [OP] Active Member
    Ted
    Massachusetts
    I've got a handheld scanner that I ran a magnetic mount antenna on my car on the trunk. It's too tall to mount on the cab (I have to park in a garage for work). How do people mount antenna's in the bed? I had a gound plane (magnetic mount) antenna in my car on the trunk, but I have a standalone antenna from my house that I'd like to mount in the bed. It's about 3-4 feet long and I'm sure I can mod the tie down brackets to use it, but I'd like to see how others have done it!
    Thanks,
    Ted
  2. Apr 2, 2010 at 8:26 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    I think people usually put it in the bed, close to the cab. Where in MA are you from?
  3. Apr 2, 2010 at 8:27 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    Search for "Firestik NGP" on Google. I have one in my bed that you can see in my build (click link in my sig). Or another option is to get a folding adaptor for your antenna.
  4. Apr 2, 2010 at 8:28 PM
    squirrelNUts
    Ted
    Massachusetts
    Born and raised masshole, wife too.
  5. Apr 2, 2010 at 8:30 PM
    tacobell007
    Drew
    Westfield, MA
    Same. I used to live in Springfield. Moved to Westfield almost 11 years ago
  6. Apr 2, 2010 at 8:32 PM
    squirrelNUts
    Ted
    Massachusetts
    but i moved and cant cut a hole in the wall (apartment) to feed it through...I though I could mount it in the bed somehow. It usually mounts to a post (1 1/4 in PVC worked for me). I'm going to try to make something up to keep the bottom of the antenna in the bed so it doesnt' stick up too much and see what kind of reception I get. It's low band through 800MHz though I usually just listen to local PD on the 400mhz range.
  7. Apr 2, 2010 at 8:34 PM
    squirrelNUts
    Ted
    Massachusetts
  8. Apr 2, 2010 at 8:36 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    I have no idea what you're talking about here.
    http://www.rightchannelradios.com/cb-springs-studs-84/antenna-fold-over-adapter-509.html
  9. Apr 2, 2010 at 8:43 PM
    squirrelNUts
    Ted
    Massachusetts
    one for the car (car now gone) and one for home. I can now use neither. I'm hoping I can hook up the big antenna on the truck (the one that used to be on the house). The magnetic one sticks up too far. It was on my trunk and was ok, but on the cab of the tacoma it won't fit in the garage at work. The tall antenna doesn't need the metal (ground plane) that the magnetic one did, so I think I can mount it low in the bed, I just need to figure out how to secure it. I'm thinking of using one of the rail tie downs and modding it to take a pvc pipe down to bed level and bolt the antenna there. I could use some pics of CB antennas bed mounted, because that's most likely what I'm going to emulate.
    Ted
  10. Apr 2, 2010 at 8:54 PM
    tacobell007
    Drew
    Westfield, MA
