CB SUCCESS!! How to achieve 2:1 SWR with a 4' Firestik II
Discussion in 'Technical Chat' started by BradleyScottETC, Jun 17, 2011.
  1. Jun 17, 2011 at 12:25 PM
    BradleyScottETC
    BradleyScottETC [OP] Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Well, as some of you may already know, I've been fighting with my CB for the past few weeks.
    http://www.tacomaworld.com/forum/audio-video/161015-cb-troubleshooting-share-your-thoughts.html
    http://www.tacomaworld.com/forum/buy-sell-trade/162179-fs-complete-cb-setup-115-a.html
    I even went so far as to completely rip out the whole system and put it up for sale.
    Here's where I initially went wrong- first of all, I had a 3' Firestik II, not a 4', which made tuning impossible. I had the antenna mounted directly behind the drivers side of the cab, with a ground wire going to the frame.
    Well, a 4' ground wire is much too long for this system, so I tried to go to ground on one of the bolts holding the rear quarter on (between the cab and the bed). This got me down to about 4.5:1, still bad, but workable.
    I put on a 4" firestik spring, which brought my antenna up to 4:1 SWR, still not working.
    So, I purchased a 4' antenna. Inexplicably, my SWR went back up to infinity. I couldn't figure it out- I had just put another $30 into the system and made it worse.
    After realizing I was never going to recoup my money, I figured that at least the antenna looked cooler mounted on my truck than it did collection dust in my garage, so I decided to put it back on, but this time, in a different location.
    With this setup, I got a 2:1 SWR on ch.1, and 1.5:1 on ch.20 and ch.40. It just needs a little tuning.
    Because this bracket is mounted directly to metal, it has a far better ground without needing an extra wire. The bed rails make an excellent track to run the Coaxial (there are small holes to wrap a zip-tie around to hang the wire neatly underneath)
    Also, because it's farther back from the cab, you don't have to worry about the cab interfering with the antenna (you're supposed to be at least 12" away from the cab, anyway), also you have more of the coaxial running straight rather than being wound in the cab (17' coax is recommended for most applications.)
    I think all of these things factored into making the setup work nearly perfectly.
    Also, I did try this position with the 3' antenna, and it didn't work AT ALL.
    Here's so more pictures.
    and a few glamour shots...
    Wat3rdog likes this.
  2. Jun 18, 2011 at 8:21 PM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    glad you got it to work! so is this setup the 4' firestik with the spring? i have my antenna almost in that same spot, and like you with a 3' its impossible to tune.
  3. Jun 18, 2011 at 8:30 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    so does getting a cab mount (center of roof) work the best then? I know i can search but general question, also what is the best Numbers for tune?
  4. Jun 18, 2011 at 8:36 PM
    Stupid hurts.
    Stupid hurts. Hoogie boogie!
    Steven
    So☆Cal
    '07 5-Lug Impluse Red Pearl Access Cab 2WD
    American Motorsports Front Long Travel Kit, Total Chaos Rear Dual Shock Hoop Kit, Engage 50T Leaf Pack, Engage Front & Rear Hangers, American Motorsports Shackles
    Congrats! I'm still figuring out mine, but I guess I'm going this route. So you're not running a ground wire at all? Also, do you have to drill? It looks as if you used the stock holes to mount the bracket, but I'm not 100% positive.
  5. Jun 19, 2011 at 5:17 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    I needed to widen the holes in the bracket a little because the stock bolts I used were a little two close together- I went in 1 or 2 steps with a uni-bit.
    No, I don't need a ground wire at all- it's grounded to that metal portion of the bed, which is grounded to the frame.
    And yes, it's a 4' firestik II with a spring. The 3' is just too short.
  6. Jun 19, 2011 at 5:20 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    The best number for SWR is 1:1. Most people get between 1.5:1 to 2.5:1. Anything higher than 4:1 and your range is basically non-existant.
  7. Jun 19, 2011 at 5:37 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Nice to see you defeated the swr gremlins..;).....My questions
    1) did you end up using 18' of coax ???
    2) with just 2 bolts holding the base,how much does the 4' move with the spring ??? if at all ??
    3) dam avatar picture makes me miss Clermont,Juniata street and Greater Hills .....Orange groves and Jahna's Mines can be fun....:cool:
  8. Jun 19, 2011 at 6:14 PM
    danteisme
    South Western PA
    this is fantastic, i'm gettin a 4' and trying it with mine.
  9. Jun 19, 2011 at 6:27 PM
    Sapper26
    Sapper26 Well-Known Member
    Will
    Columbus, GA
    99 Xtra Cab 4x4
    That's exactly the dame setup I have and I have it mounted in the same location too. The only difference is I have a quick connect and usually keep my antenna behind the back seat unless I need it. It's a really great setup. Glad you got it figured out.
  10. Jun 19, 2011 at 6:42 PM
    tacopromatt
    tacopromatt Matt's Pro Taco (SOLD)
    Austin, TX
    2017 Cement Tacoma TRD Pro AT
    Odd. I just finished mounting my 4' Firestik to the rail behind the cab (with spring and 90 degree fold-away connector) and with a good ground to the frame I'm getting under 2:1 on all channels.
    I did have to try a few grounds and combinations of spring/no spring, etc.
  11. Jun 19, 2011 at 7:01 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    1) Yes, I kept the full-length coax. The Firestik people recommend running that length, and winding the extra into a big figure-8 pattern.
    2) The bolts are tight- the bracket itself being 90' plays a little, but the spring does most of the movement. When I drive over 45mph it drags about 15-30 degrees.
    3) We were neighbors!?!
    I might put an L bracket on the bed rail down aways to catch the antenna under for pulling into parking garages. I dont know yet.
  12. Jun 19, 2011 at 7:04 PM
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    There is so much that factors into it- it probably boils down to how each of us ran our CB power, what CB radio we have, coax length, bracket type, etc.
    Long story short- if you want a good CB setup, you've got to be willing to troubleshoot.
  13. Jun 20, 2011 at 1:19 AM
    Stupid hurts.
    Steven
    So☆Cal
    Just fixed mine today using this method. My buddy and I were able to talk to each other about 2 miles away and it was loud and clear. Thanks!
  14. Jun 20, 2011 at 3:10 PM
    snoope
    1 & 2 ..Thank you....
    3) You might have been in school with my kids,one at Clermont and the other in Minneola BUT we have been back here since '98.....Publix was on the west side of 27....not where it is now and 27 had no traffic lights :eek:...
  15. Oct 18, 2011 at 3:30 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I'm going to attempt the same setup, but alas I have to use a 3' antenna or else I can't get it in my garage.
    Also, is there a point to this special firestik coax cable that comes with a ring attachment?
