CB SWR Reading HIGH
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Mar 31, 2012.
  1. Mar 31, 2012 at 1:07 AM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    So I finally had the chance to try and tune my whip with my friends meter. My whip is grounded to my frame and sits right behind my tool box, at the drivers side.
    I have a different mount now, but same concept. Ran a ground wire from there through the cuby hole onto the frame.
    Anyone have any ideas why the reading could be so high?
  2. Mar 31, 2012 at 1:14 AM
    CayucosTacoma
    This is the fire stik 2 with a tunable tip and i have a cobra CB
  3. Mar 31, 2012 at 1:22 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    High where? Channel 1 ? Channel 40 ? To calibrate your antenna, find a nice open parking lot. Test channel 1, 40 and 19.
    If your antennae is not adjustable (i.e no tunable tip) you'll have to experiment with location to find a good location.
    That being said, just off the top of my head from the picture you posted - that's a not ideal place to put an antenna. There isn't much of a counterpoise and the cab will block and reflect a good deal of the signal.
    If you don't want to put the antenna over the cab, put it over the hood. If you want to go over the bed, use a tunable, or a coil loaded antenna. They won't work quite as well, but they'll do OK.
  4. Mar 31, 2012 at 1:27 AM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
    If it has the tunable tip (I think all FSII do) then you need to tune it. You might never get great performance out of it at that location, though.
    So start at the bottom and go by 1 turn increments and note your SWR on channels 1, 19, and 40. I bet you'll have to get pretty long to get decent SWR on all of them, but I doubt you'd get below 2 on both ends.
    As long as you're below 3 everywhere, it's OK. Lower is better, but below three wont blow up your radio.
  5. Mar 31, 2012 at 1:44 AM
    CayucosTacoma
    Hmmm OK So if I am getting a high swr reading I should adjust the tip upward or downward?
  6. Mar 31, 2012 at 2:56 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Firesticks are not the greatest and the tunable tip does not give you enough tunning ability. A whip style antenna which you can use a dremmel to cut down and adjust the length is best. Also it should be a a minimum of 2 feet above your cab. I find in our tacomas that the "Lil Wil" by Wilson works the best. JMO
  7. Mar 31, 2012 at 4:41 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2002 Sliver-ade-o 2008 P71
    Yes
    Ditch the Firestik. I could never get mine tuned right either. Got myself a little Wil and worked with no tuning right out of the box. I just upgraded to a Wilson 1000 and needed no tuning as well. 1.2 on all channels and it smokes! BTW I have 2 little Wils if you're interested I might let go of one.
  8. Mar 31, 2012 at 4:51 AM
    H Bomb
    H Bomb Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    I just set up my firestik yesterday. Read way high. I unscrewed the tunable tip all the way. It read high again. I turned the tunable tip down half way and now it is reading under 3. Luckily, tuning it helped. Here is the troubleshooting flow chart I used for troubleshooting: http://www.rightchannelradios.com/high-swr-troubleshooting-flowchart
  9. Mar 31, 2012 at 5:05 AM
    LUSETACO
    Dennis
    South Central Pee A
    Yes
    A reading of 3 is acceptable but you're losing about 25% of your output. Some newer radios will reduce power if SWR is high reducing your output even more.
  10. Mar 31, 2012 at 8:56 AM
    CayucosTacoma
    The only reason I don't have a mag mount is because of the damage it does to the paint.. luse taco how much do you want for a whip?
  11. Mar 31, 2012 at 9:02 AM
    LUSETACO
    Dennis
    South Central Pee A
    Yes
    Well the little Wil is a mag mount. I'm not really worried about the paint too much because unless you're like 7 feet tall you'll never see the scratches.:p
    Just shoot me a PM if you're interested.
  12. Mar 31, 2012 at 9:05 AM
    CayucosTacoma
  13. Mar 31, 2012 at 10:01 AM
    CayucosTacoma
    so if my SWR reading is to high, should i adjust the screw at the top to go down or up?
  14. Mar 31, 2012 at 10:26 AM
    LUSETACO
    Dennis
    South Central Pee A
    Yes
  15. Mar 31, 2012 at 10:29 AM
    H Bomb
    Try both up, down and in the middle. Take swr readings and see what happens. What readings are you getting now, by the way?
  16. Mar 31, 2012 at 11:03 AM
    CayucosTacoma
    i cant remember but it was in the middle of the red
  17. Mar 31, 2012 at 11:08 AM
    Bones2Blood002
    Bones2Blood002 Well-Known Member
    SoCal
    10 Offroad on the build
    Sliders, Old man emu lift with aal in the rear, tc uca, relentless front and rear bumpers, ato skid plates
    Double check your ground. Mine was shorted out. I got the same reading when it was shorted.
  18. Mar 31, 2012 at 11:17 AM
    CayucosTacoma
    okay ill go look at it right now
  19. Mar 31, 2012 at 11:48 AM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Make sure you get a ground strap. Wire generally isn't going to give you a decent ground unless it's a large gauge. I have a firestik II. The same thing as you and I have a 1.2 SWR on all channels just about. Just check the ground and make sure when tuning your away from building, cars, trees, etc. and have all windows rolled up and no people around. All of those affect your SWR. You should be able to tune it to a decent working SWR with that set up.
  20. Mar 31, 2012 at 11:51 AM
    H Bomb
    Record the readings you are getting at channel 1, 19 and 40. This will give more info on what the issue is.
    Like the other guy said, check ground and connections. Also, double check that you have the correct connections going into each side of the swr meter.
    I have also read that it is better to mount the antenna on the passenger side. I don't know how much/if that actually causes huge problems though.
