cb swr
Discussion in 'Audio & Video' started by johnw, Jul 18, 2010.
  1. Jul 18, 2010 at 7:02 PM
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    hey i got really high peaking on my swr readings and was wondering how to cure this problem. i dont have the cb grounded to the frame at all just got positive negative hooked up from my amp. so any help would be good
  2. Jul 18, 2010 at 7:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it really needs to be grounded to the frame man. where did you mount it?
  3. Jul 18, 2010 at 7:05 PM
    johnw
    john
    orlando florida
    what needs to be grounded?
  4. Jul 18, 2010 at 7:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the antenna itself. not sure how you have it mounted, but put an eyelet on a good strand of bigger wire......like 14 or 12 guage and run it to the frame from the mount.
  5. Jul 18, 2010 at 7:08 PM
    johnw
    john
    orlando florida
    well the bed rail itself on the second gen like right behind driver side window. antenna itself is lined up with black weather striping on the roof
  6. Jul 18, 2010 at 7:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....it doesnt have a good ground plane there man. you can leave it there....but you'll need to run a wire from the mount down to the frame for the swr to get better.
  7. Jul 18, 2010 at 7:15 PM
    johnw
    john
    orlando florida
    sweet so you think 12 or 14 gauge will do the trick?
  8. Jul 18, 2010 at 7:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it should. when we installed Canada's cb and wired it up......the swr was way off.....and so i twisted 4 good lengths of 16 guage together and taped up, and ran it down to the frame. it was perfect after that.
  9. Jul 18, 2010 at 7:21 PM
    johnw
    john
    orlando florida
    wait so like 12 ga speaker wire or different than speaker wire?
  10. Jul 18, 2010 at 7:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    speaker wire should work.......i think i used the cheap stuff from walmart that comes in rolls....like for wiring truck lights and such.
  11. Jul 18, 2010 at 7:22 PM
    johnw
    john
    orlando florida
    yah thats what i meant but you ran 4 strands of it and rapped them around each other?
  12. Jul 18, 2010 at 7:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....stripped the ends....put on a good sized eylet......twisted and taped them. if you use 12 gauge....you may not have to use but only one strand of it.
  13. Jul 18, 2010 at 7:26 PM
    johnw
    john
    orlando florida
    eh i will get some 12 ga and double it not triple or anything. but thanks for the help its load and clear but i dontwant to blow the cb
  14. Jul 18, 2010 at 7:28 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that'll work. let us know how it goes.
  15. Jul 18, 2010 at 7:31 PM
    johnw
    john
    orlando florida
    will do thanks again. and sand down area that i will be grounding to or no??
  16. Jul 18, 2010 at 7:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can sand it down some....or just find a place that has threads for a bolt to screw into and go that route...either way.
  17. Jul 18, 2010 at 7:34 PM
    johnw
    john
    orlando florida
    alright
  18. Jul 18, 2010 at 9:19 PM
    #Murphy
    #Murphy Well-Known Member
    Nick
    High Point, NC
    F150
    3 inch body lift Bull Bar Hella FF 500 Truck Champ Step ups 10k hid's Nitto Terra Grapplers Unique wheels Yakima Roof Rack Yakima Fairing
    what ground are we talking about? the negative wire on the cb power?
  19. Jul 18, 2010 at 9:24 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    Negative, the antenna mount its self.
  20. Jul 18, 2010 at 9:32 PM
    #Murphy
    Nick
    High Point, NC
    F150
    ohhhhhhhhh. so would mounting this on my bed frame suffice?;)
