CB troubles
Discussion in 'Audio & Video' started by danteisme, Jun 7, 2011.
  1. Jun 28, 2011 at 11:54 AM
    Teniente
    Teniente Well-Known Member
    Carson City, NV/Ensenada, Baja California, MX
    White 2006 SR5 DCSB 4x4
    I'm not a radio engineer, but I did sleep at a Holiday Inn last night............
    Maybe you are not getting enough ground plane effect where the antenna is located on the composite bed.
    Try this simple check...........buy or borrow a magnetic mount antenna and put it in the middle of the top of your cab, connect to the SWR/radio and then run your checks.
  2. Jun 28, 2011 at 6:50 PM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i'm not sure if its a ground plane issue or not. i followed another members issues on here, he has his 4' firestik mounted in the exact same spot and is getting 1.5 - 2:1 SWR.
    i folded the bestop out of my way to see if that made a difference. none at all. i noticed a wear spot in my cable though. looks like i may have hit it with my bestop rear window and wore through. i'm going to order a new cable and see what happens after that.
  3. Jun 28, 2011 at 7:27 PM
    danteisme
    South Western PA
    i noticed there is 2 different coaxes with the fire ring. is the only difference in these the fact that the one is an EZ install? i wanna make sure i order the right thing.
    Model MU-8R18 and the K-8R18
  4. Jun 29, 2011 at 6:10 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    danteisme,hey man i think that the 1 guy is right after looking at your coax,doesn't look like the coax that is set up in all of our tractors ( BIG TRUCKS) at work.the cb shops that i have visited have told me not to coil up the coax in a tight coil but a very sloppy or even a serpintine so as to have it spread out. here's my idea i-70 exit 25 and 32B has a pilot t/s eexit 25 has a t/s and in smithton exit49 there are 2 truck stops.on i-79 there is one down at exit 1This is what we do when we need a new coax cable for after a few years they get old for us cause they go outside and are exposed to all types of weather.Hope this info helps.
  5. Jun 29, 2011 at 6:29 AM
    Tiedie
    David
    WFOY
    PM sent
  6. Jul 16, 2011 at 3:37 PM
    danteisme
    South Western PA
    i swapped out for a new fire ring cable, instantly went to a 1:1 on channel 1, 1.5:1 on channel 20, and a hair over 2:1 on channel 40. so it needs some tuning, but this is a lot better.
  7. Jul 16, 2011 at 3:47 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Set it and forget it. You're good to go.
  8. Jul 17, 2011 at 8:40 AM
    danteisme
    South Western PA
    thank god, finally lol
  9. Aug 5, 2011 at 2:03 PM
    gbtoy4x4
    gbtoy4x4 Well-Known Member
    Greg
    Las Vegas
    2010 Silver TRD AC OR 4x4 6sp
    Factory Silver Sport Grill, Gray TRD Shift Knob, BFG 285/75/16 AT's, Debadged, AFE Cai, TRD Short Shifter, Redline Hood Struts, Leer Topper, Budbilt Front, Mid+Xcase Skids, ELocker Skid, Icon C/O, Built Right UCA's, Rear 2in AAL w/Bilstiens, AP U-Bolt flip, 1" 4Crawler Body Lift, Relentless Front Bumper w/Lights + Sliders, Rear Breather Mod, 5 ProComp 7089 Rims, AP SS Brake Lines, Famous Fab HC Rear Bumper W/Swing Out Tire Carrier, Synthetic Brake Fluid, Synthetic Power Steering Fluid, Front Superbumps, Hood Blackout,
    where did you get the tailgate bracket?
    If said I missed it
    Thx
  10. Sep 18, 2011 at 11:53 AM
    idgara007
    idgara007 Active Member
    tx/CA
    09 TRD Sport double cab
    x2 I need one of those but cant seem to find one
  11. Sep 18, 2011 at 8:16 PM
    danteisme
    South Western PA
  12. Sep 19, 2011 at 2:47 PM
    gbtoy4x4
    Greg
    Las Vegas
