CB unit installed pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LVTacoma, Sep 20, 2010.
  1. Sep 20, 2010 at 5:25 PM
    LVTacoma
    LVTacoma [OP] Well-Known Member
    Did this a while ago but have yet to post up. I know alot of guys are asking where to mount CB in our trucks and heres a cool set up I managed.
    Center console mount with antenna cable under cab through a drain grommet, under the carpet and ran right into the center console from underneath. Bulkier CB units probably wont fit under the lid, but mounted up and down inside the console. Anyone else have their set up similar?
  2. Sep 20, 2010 at 5:54 PM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Nice setup.... I did have something similar to yours but found i couldn't quite hear the speaker well enough when the lid was closed. Kind of a PITA driving around with the lid open and nowhere to rest your arm so i decided to buy a Cobra 75.... Much better IMO.
  3. Sep 20, 2010 at 6:31 PM
    LVTacoma
    Actually looking to upgrade to a better Cobra, how do you like your 75
  4. Sep 20, 2010 at 6:35 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    Where is your antenna mounted pics?
  5. Sep 20, 2010 at 6:42 PM
    PRBulldog36
    PRBulldog36 Well-Known Member
    Juan
    San Antonio, Texas
    2006 PreRunner SR5 TRD Off Road
    Bilsteins 5100's X4 front set at 2.5 and rear AAL,BFG Rugged Trail T/A P265/65R/17, Warrior 375 17X8 Wheels with Gorilla locks,Black Billet Grille top and bottom and replaced Toyo emblem with Dallas Cowboys Star by MetalMiller, Vent Shade window louvers and hood bug shield, Fog light anytime mod,Dome light Mod,Blue interior LED's, Six inch Black Chrome billet antenna,Firestik CB Antenna, Cobra 75 CB, 12Vt/DC outlet back of Center Console, CB external speaker, Sirius Satellite Radio, Westin tube step up bars (Chrome), Tinted windows (legal), Eyebrow on windshield (Limo),Leather arm rest mod,HID H4's(fog), HID plug and play 8000, Tailgate theft prevention mod and Tailgate Pop-n-Lock, Trailer hitch brake light,Garmin GPS Dashboard Mount, Baja Lights on the rear bed rail, In Bed Mt Bike carrier, Tail gate extender, N-Fab light bar with Four Hella 500's, Fold down antenna,WeatherTech digital floor mats, mount,Kenwood head unit, Polk Audio 6X9,Two 12 ' Subs MTX, Kenwood Excellon 5 1/4, Ke
    I don't see any of the pic !:rant:
  6. Sep 20, 2010 at 6:52 PM
    TakDwn
    TakDwn Well-Known Member
    PA
    2010 Tacoma DC V6 Shortbed 4x4
    Bili's all around, front 5100's at 1.75", rear TSB w/AAL, 265x75/16 BFG AT, Wheelers steelies Type B 4" bs, LEER cap, Tinted, Relentless hybrid sliders welded, Cab mount chop, Plastic trimming, Sock retros, Mirror lift, Satoshi with old school emblem, WeatherTechs, Mudlaps gone, RedLine hood struts, Fumoto valve, Tailgate clamped, Console organizer, Mobtown Offroad Front Recovery Bar
    Can you use a speaker from your CB, and mount speaker in location that would allow you to hear it?
    If you can do this, you can turn on your CB to a dedicated channel, turn the volume to a level that is best for speaker, run the CB mic cord out from a small nitch, and then close the lid for use.:D
  7. Sep 20, 2010 at 7:10 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    here's where i mounted both my CB and 2meter amateur radios..both locations required some cutting and grinding with a dremel tool :eek::D....
  8. Sep 21, 2010 at 5:34 PM
    DueNorth
    Sorry for the delayed response....
    The 75 is a great little CB. All built into the mic means you don't need much room for it. You can hide it when not in use and i also find the volume is just fine, despite what others have said. I do however keep the volume near max without music on... IMO i think its better than the "cheaper" units but it does the same job, without the size.
    TakDwn
    Great idea, but without looking at the mic more closely, i don't think i can run an aux speaker from it.....
  9. Sep 21, 2010 at 6:28 PM
    TakDwn
    PA
    The aux speaker should wire/plug into the rear of the CB....atleast this is where it's been located in all of my CBs. In the rear is the power connection, antenna connection, and the plug for an external speaker jack to be plugged into. Take a look when you get a chance. I've had 2 of my past Jeeps (one Wrangler and one Cherokee) with an external speaker. Its a good set-up.
    For what its worth the Cobra 75 is a great alternative, especially if you looking to keep vehicle alterations that often results from mounting to a minimum.
    Good luck.
  10. Sep 22, 2010 at 5:26 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
