cb wiring help
Discussion in 'Technical Chat' started by kelch89, Dec 18, 2010.
  1. Dec 18, 2010 at 7:01 PM
    kelch89
    kelch89 [OP] Well-Known Member
    brad
    washington
    2011 sr5
    all blacked out, hid headlights, debadged, 3 inc lift aal. looking for more cool stuff
    so i searched and checked the wiring basics and im still lost. i have no idea how to connect my pos. wire to a fuse or the neg to the chassis or anything. someone bail me out plz. i can build a deck but i cant install a fu**ing cb
  2. Dec 18, 2010 at 7:13 PM
    kelch89
    brad
    washington
    2011 sr5
    ok so anything? i know your probably thinking WOW, but i build things, not wire things. so plz help its christmas time
  3. Dec 18, 2010 at 7:22 PM
    DevL
    DevL Well-Known Member
    Positive to power fuse is running a positive wire from a switched or constant power accessory fuse in your fuse box to the radio. Wire to ground is connecting to the chassis or body, usually via a wire run to a bolt through body or soldering to an area with pain scraped off. Your manual will tell you what accessory fuse slots you have and where. If you cant get a good ground you could always run a wire back to your battery.
  4. Dec 18, 2010 at 7:24 PM
    kelch89
    brad
    washington
    2011 sr5
    ok maybe a dumb question but how do i wire it to a fuse?
  5. Dec 18, 2010 at 7:27 PM
    Rbohno
    Rbohno Well-Known Member
    Richard
    Charlotte,NC
    2010 DC TRD OffRoad
    Viper remote start alarm 2.5" Spacer in front, 1.5" spacer in rear, rear TSB performed N-Fab Nerf bars 16" x 8" Vision Warrior wheels 265/75/16 Dura Trac tires
    I would go to your local auto parts and ask the guys in there to show you where/how to connect the positive. The auto parts can sell you the crimp on connectors(.99) package to do that.
    Then just find a bolt or screw that is threaded into the body of your truck and use that for ground.
  6. Dec 18, 2010 at 7:31 PM
    kelch89
    brad
    washington
    2011 sr5
    hmm ok. maybe ill try that
  7. Dec 18, 2010 at 7:47 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    i just bought a plug that you connect the wire to and plug into you cigarette lighter. not sure if that's an option for you but its sweet for quick disconnects.
  8. Dec 18, 2010 at 8:00 PM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
  9. Dec 18, 2010 at 8:06 PM
    ak47
    Anthony
    Washington
    stock 2nd owner
    chehalis
  10. Dec 18, 2010 at 8:28 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Get yourself an "Add A Circuit" for the switched + power and put an crimp on eye to the black wire and connect it to any number of bolts that attach to chassis ground.
  11. Dec 18, 2010 at 8:39 PM
    BuckNakedBooda
    Sorry my link didn't work....
    Go to www.autozone.com and do a search for bussmann
  12. Dec 19, 2010 at 5:21 AM
    kelch89
    brad
    washington
    2011 sr5
    thanks for the help im going to try going to autozone today, and im located in lacey
  13. Dec 20, 2010 at 11:19 PM
    Manwithoutaplan
    ID
    Does it matter WHich fuse place in the fuse box you pick ??
  14. Dec 20, 2010 at 11:22 PM
    Manwithoutaplan
    ID
    I am on the same boat as you right now.
  15. Dec 20, 2010 at 11:31 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Try and find the radio or ignition fuse or any fuse that will Not have power flowing while the key is off.
  16. Dec 20, 2010 at 11:34 PM
    Manwithoutaplan
    ID
    The Fuse box is on driver side close to the door behind all the gauges right?
  17. Dec 21, 2010 at 8:53 AM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    I'm not sure on the 2nd gens but on mine it is right above the driver side kick panel
  18. Dec 21, 2010 at 12:19 PM
    Manwithoutaplan
    ID
    THanks 01Tacoma I got it all hooked up now i am stoked. I am learning how to do all this electrical crap. SO i hooked up the Red Wire which is AUx wire to the Fuse Panel. Orange wire went to the Battery and THe black Wire went to the CHasis. :D
    "Got to enjoy the little THings " Zombieland
  19. Dec 21, 2010 at 2:19 PM
    01Tac0ma
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    :thumbsup: im glad you got it working, and ive always wondered what the orange wire was for i never used it, all my new cb has is the red and black wires:D
