cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Sep 1, 2014 at 7:28 AM
    #81
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    My dampener was getting bashed up a lot off-road so I took it off about 2months ago, I haven't noticed any increased vibrations whatsoever, you'll be fine :thumbsup:
  2. Sep 1, 2014 at 11:02 AM
    #82
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I'm glad to hear that. I might not even have to worry about putting it back on when I get skid plates. Thanks for the vote of confidence.
  3. Sep 19, 2014 at 1:35 PM
    #83
    cbechtold
    Cory
    Pleasanton, CA
  4. Sep 19, 2014 at 6:21 PM
    #84
    cbechtold
    Cory
    Pleasanton, CA
  5. Sep 20, 2014 at 1:01 PM
    #85
    cbechtold
    Cory
    Pleasanton, CA
  6. Sep 20, 2014 at 4:38 PM
    #86
    johnboyTRD
    johnboyTRD Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Looks good
  7. Sep 20, 2014 at 5:55 PM
    #87
    cbechtold
    Cory
    Pleasanton, CA
    Made progress on welding... More to come though...
    Started grinding down the outside of the bumper as well...
    IMG_8590
    by Cory Bechtold, on Flickr
    I got roughly 1/3 of the outside ground but I got a lot more to go...
    More tomorrow...
  8. Sep 20, 2014 at 5:57 PM
    #88
    cbechtold
    Cory
    Pleasanton, CA
    Thanks...
  9. Sep 21, 2014 at 10:31 AM
    #89
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    These work REALLY well for cleaning up edges after welding. They don't last very long but for clean up work with the least amount of grinding marks, they work the best.
  10. Sep 21, 2014 at 11:42 AM
    #90
    cbechtold
    Cory
    Pleasanton, CA
    We're using flap disc. 36/40 grit and 80 grit. Paint stripping disc would be interesting to see how it would work, and what sort of finish I would get.
  11. Sep 21, 2014 at 3:21 PM
    #91
    cbechtold
    Cory
    Pleasanton, CA
    Exterior of the base bumper is nearly finished... Spend most of my time grinding away to make it smooth. Looks great so far, and it can only get better.
    Base Bumper Welded
    I'm done for this weekend... More next weekend...
  12. Sep 21, 2014 at 3:42 PM
    #92
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Looking really good. I can't wait until i get my Relentless front/rear in....
    How are you going to paint it? Powder or rattle can?
  13. Sep 21, 2014 at 5:06 PM
    #93
    cbechtold
    Cory
    Pleasanton, CA
    Thanks... Most likely I'm going to a ton of semi-gloss black spray paint.
    Which rear bumper you going with? Wrap around or basic?
  14. Sep 21, 2014 at 5:13 PM
    #94
    thegame
    Brian
    Folsom, CA
    Oh yeah the paint stripping disc leaves a lot better finish than flap discs. You'll see!
  15. Sep 21, 2014 at 5:23 PM
    #95
    cbechtold
    Cory
    Pleasanton, CA
    Maybe we'll give it a try. I'll update you if we ever try it.
  16. Sep 21, 2014 at 9:11 PM
    #96
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    DIY wrap around! :D
  17. Sep 21, 2014 at 9:43 PM
    #97
    cbechtold
    Cory
    Pleasanton, CA
    I envy you so much... I'm short some cash, but I'll get there soon. Relentless Fabrications' wrap around rear bumper is next on my list of purchases for my truck.
  18. Sep 21, 2014 at 9:47 PM
    #98
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I cant wait.. I've been told its going to ship tues/wed. Got the front bumper fully fabricated, it will probably be here around christmas. Wanted the rear quicker so i ordered it DIY. What did you use? UPS or Fastenal?
  19. Sep 21, 2014 at 9:53 PM
    #99
    cbechtold
    Cory
    Pleasanton, CA
    Technically, I went with Fastenal, which should have taken a week or so for it to arrive, but I got it the next day... I'll probably use Fastenal for the rear bumper as well... Got to save every penny for this truck! :D
  20. Sep 21, 2014 at 9:59 PM
    #100
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I'm using fastenal also, I figured i was close enough is Reno that it should take about the same amount of time. Your post confirmed that :D. I have to save for the OME lift I want.. Adding all this weight isnt going to go well with stock.
