cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Feb 4, 2022 at 4:53 AM
    #2421
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I think 35's are good enough haha, plus you just did the tubing for it...
    cbechtold[QUOTED][OP] likes this.
  2. Feb 4, 2022 at 6:08 AM
    #2422
    cynicalrider
    cynicalrider #NFG
    Jersey
    You think he would need to revisit tubbing for 37's with LT?
  3. Feb 4, 2022 at 6:25 AM
    #2423
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Well seeing as I just bought 2 sets of 35s, yeah, I'm good for now. No plans to go bigger right now.
    Well it just so happens that I can borrow a 37 for test fitting purposes. ;)
    It's going to be close. The MCM kit moves my wheel forward 3/4 of an inch, as well as I'm ditching the wheel spacers for a better scrub radius.
    BYJOSHCOOK[QUOTED] likes this.
  4. Feb 4, 2022 at 6:25 AM
    #2424
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You have more up travel
  5. Feb 4, 2022 at 6:32 AM
    #2425
    cynicalrider
    cynicalrider #NFG
    Jersey
    :popcorn:
    Ah didn't think of that.
  6. Feb 6, 2022 at 8:56 PM
    #2426
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Planning on using your existing leaf pack in the rear with those long bois?
  7. Feb 6, 2022 at 9:18 PM
    #2427
    cbechtold
    Cory
    Pleasanton, CA
    I'm possibly going to add some longer shackles to the rear, but haven't gotten that far yet. Chevy 63s and 14" shocks might happen if the rear suspension can't keep up at all with the front.
    TacoEspecial likes this.
  8. Feb 6, 2022 at 9:19 PM
    #2428
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Are you out boarding since you got the wider axle now
  9. Feb 6, 2022 at 9:20 PM
    #2429
    cbechtold
    Cory
    Pleasanton, CA
    Yessir!
    Dan8906[QUOTED] likes this.
  10. Feb 6, 2022 at 9:24 PM
    #2430
    Dan8906
    Daniel
    Concord, California
    That’s going to be legit
  11. Feb 6, 2022 at 9:25 PM
    #2431
    cbechtold
    Cory
    Pleasanton, CA
    The increased stability all around is going to be a very welcomed change.
  12. Feb 6, 2022 at 9:29 PM
    #2432
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Can’t strongly enough advocate for custom deaver or Alcan leaf pack. $5k up front wasted when doing 63’s or lift shackles.
  13. Feb 6, 2022 at 9:31 PM
    #2433
    betterbuckleup
    Ian
    Concord, CA
    Not sure how your current leaf pack handles, but I couldn't believe the improvement going from my previous dakar pack to the progressive custom Alcan's.
    You can't compensate for much with shocks when you need a good spring. I should have done an alcan set a long time ago.
    My rear can finally keep up with the front. I was hitting some decently sized whoops (at least for me) at close to 20 mph this last week at hammers. Before, the rear would blow through to the bumps with any kind of weight in the bed over any kind of terrain change like that
    Does your current pack have a couple of beefy overloads similar to the dakar?
    ^^^ what @Dalandser said too
    malburg114 likes this.
  14. Feb 6, 2022 at 9:42 PM
    #2434
    cbechtold
    Cory
    Pleasanton, CA
    While I agree with you, my wallet doesn't. :bananadead:
    Current ride isn't too bad. The stock valving from Icon is just so bad with the current weight of my truck. Presuming I stay with leaf springs outback, Deaver F67s and 12" shacks are likely what I'd do.
    I'd would honestly like to not do a ton to the rear end right now since links are what I'd ultimately want to do.
  15. Feb 6, 2022 at 9:45 PM
    #2435
    betterbuckleup
    Ian
    Concord, CA
    Gotcha. One step at a time I guess for now. get the front dialed and then see what you can do with the rear on a budget lol
  16. Feb 6, 2022 at 9:49 PM
    #2436
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Just save another $500 over what you’d pay for a Chevy kit for a custom stock replacement pack. Or do lift shackles. Guys say their truck handles fine with 63’s have obviously never rode in one with better hardware out back. Not being facetious but LT up front and 63’s won’t be nearly as capable as MT up front and custom leaf pack out back.
  17. Feb 6, 2022 at 9:52 PM
    #2437
    cbechtold
    Cory
    Pleasanton, CA
    Definitely not ideal, but yeah. Eventually everything will come together properly.
    We'll play it by ear with the custom leaf packs. If the rear suspension is underperforming by a significant degree, then custom leaf pack is back on the table.
  18. Feb 6, 2022 at 11:25 PM
    #2438
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    I may be the minority here but having rode in a trailing arm coilover jeep, coil springs and 2.5 shocks jeep and a Tacoma with f67, and then my Tacoma with 63s and bypasses/no bypasses and now 63 main with deaver 62 pack, the best riding is my 63 main with 62 pack and the bypass. With leaf springs the bypass gives so much tunability and allows you to smooth out the ride for what your trying to do. I’d go a junkyard 63 pack with some thin leaves below it and 6 in shackle with a 2.5 or 3.0 bypass over a custom pack any day.
    and I have no intentions of linking mine. With a little more tuning on the bypasses, there’s not much I’ll gain by linking mine in flex or ride quality. And I finally bent a 63 main after almost 7 years of pretty hard wheeling.
    slander and cbechtold[OP] like this.
  19. Feb 6, 2022 at 11:38 PM
    #2439
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @malburg114 made his own custom pack. Chevy's have 4 thick leaves while 62" Deavers have 10 thin ones so not apples to apples anymore. I don't believe that putting money into a problem is the only way to arrive at a great solution, but it's time (and luck with getting some supporting leaves for a deal) vs money eventually. It's tough to say how much of a difference just the main spring makes with supporting leaves.
    I'd be interested to see how such a setup performs with a shorter shackle below or through the frame vs. a longer shackle above the frame. SUA setups either use a 9" through the frame or 12" above the frame and 12" above the frame is the more popular option for good performing setups.
  20. Feb 7, 2022 at 10:28 AM
    #2440
    cbechtold
    Cory
    Pleasanton, CA
    Hunter and Brandon from Acadia Offroad ran leaf springs and bypasses to great success as well. It's definitely an appealing option since keeping as much bed space as possible is something I'd want to do. Glad to hear another person backing leaf springs since they both said the same thing.
    Definitely not an apples to apples comparison, but it's definitely definitely an option to at least consider. It's something that I'm going to have to read more into since I don't know a ton about leaf spring geometry. Time-wise as well, truck wouldn't be down for a month or two getting 4 linked and I wouldn't I have to spend even more time before hand working an older F150 tank into the old spare tire location.
    malburg114[QUOTED] likes this.
