cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Mar 14, 2022 at 8:00 PM
    #2561
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    So was I, but hopefully the 2nd gen Taco UCA bolt fixes that.
    I'm going to just stop by the local ace hardware and buy some fender washers.
  2. Mar 14, 2022 at 8:04 PM
    #2562
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What thickness? 1/32 is enough.
  3. Mar 14, 2022 at 8:06 PM
    #2563
    cbechtold
    Cory
    Pleasanton, CA
    Probably 1/16" to be safe.
  4. Mar 14, 2022 at 8:12 PM
    #2564
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Eh, with a mallet you can open them up if they're a smidge too tight - too much gap won't make it bad, just looks cheap
    cbechtold[OP] likes this.
  5. Mar 14, 2022 at 8:16 PM
    #2565
    cbechtold
    Cory
    Pleasanton, CA
    True, I can always buy both if they're available and go from there.
  6. Mar 18, 2022 at 8:55 PM
    #2566
    cbechtold
    Cory
    Pleasanton, CA
    Good progress these last 2 days. Got all the fitment dialed on the cam tabs and coil tower reinforcements and everything is welded in now. Definitely not the prettiest welds, but they're hot and definitely going to hold.
    PXL_20220319_023804674
    by Cory Bechtold, on Flickr
    PXL_20220318_235549771
    Need to flat out some of the welds on the cam tabs to allow for full range of motion for my alignment guy, but other than that, I'm planning to beef up the factory motor mounts tomorrow. Once that's all done, it's on to cleaning and prepping for paint.
  7. Mar 18, 2022 at 8:57 PM
    #2567
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You installing limit straps - am I missing the frame side tabs?
  8. Mar 18, 2022 at 9:00 PM
    #2568
    cbechtold
    Cory
    Pleasanton, CA
    I need to cycle suspension before I put limit straps on, but I have a few things to do before I do that.
  9. Mar 18, 2022 at 9:01 PM
    #2569
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    One of those guys with $ to spare on painting your frame again
  10. Mar 18, 2022 at 9:05 PM
    #2570
    cbechtold
    Cory
    Pleasanton, CA
    Ha! Definitely not. We'll see then. I know for a fact that I'm at least cleaning everything since the frame is coated in grease.
    Dalandser[QUOTED] likes this.
  11. Mar 18, 2022 at 9:13 PM
    #2571
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    yeah with grease who needs paint anyway? You running stock cam bolts?
  12. Mar 18, 2022 at 9:19 PM
    #2572
    cbechtold
    Cory
    Pleasanton, CA
    For the time being, yes.
  13. Mar 18, 2022 at 9:20 PM
    #2573
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can pretty much set your rears to all out and fronts to mid or all in and call it a day.
  14. Mar 18, 2022 at 9:23 PM
    #2574
    cbechtold
    Cory
    Pleasanton, CA
    That's kind of what I was thinking about starting with until I can get an alignment.
  15. Mar 18, 2022 at 9:35 PM
    #2575
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can set your camber with the rotors and an angle finder off the frame and the toe with a string measured off the rear wheels - put your kit at ride height and it’ll be good as it gets if you bring it to a shop to dial in toe. Got all the measurements in spec this way.
  16. Mar 18, 2022 at 9:42 PM
    #2576
    cbechtold
    Cory
    Pleasanton, CA
    Guess I know what I'm doing once the truck is back on all 4.
    otis24 likes this.
  17. Mar 18, 2022 at 9:57 PM
    #2577
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Do it w/o the coilovers in - just mount the wheels and put it at ride height (jack under crossmember) and measure to the fender from the hub, then remove the wheels, put the front on jack stands, and jack your lca's to the ride height you recorded and do your camber measurement from there. Toe is / can be done with the truck on its own weight.
    Robmonster117 likes this.
  18. Mar 18, 2022 at 10:43 PM
    #2578
    cbechtold
    Cory
    Pleasanton, CA
    Sounds like a plan. I'll see when I can get around to that, but definitely taking that into account for later.
  19. Mar 18, 2022 at 11:20 PM
    #2579
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    String method: done it 3 times and been in spec all three but it felt a bit better after a laser toe alignment - what you can basically specify for the shop to do.
    https://www.youtube.com/watch?v=P6EllJTMrZs
    Done it alone each time, would go quick w/ 2-3 people though. Just keep the 2 distances to the rear wheel and the two distances to the front wheel proportional (ex. 3" on both readings on rear wheel and 1.5" on both readings on front wheel) since your track width isn't going to be identical front to back).
    JTFisherman, otis24 and cbechtold[OP] like this.
  20. Mar 20, 2022 at 7:37 PM
    #2580
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    By your metrics, I’m packing 4”!!!
