cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Jun 7, 2022 at 8:17 PM
    #2641
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Yep. T100 booster and master because of the Tundra calipers up front and Sequoia calipers in the rear.
    TacoEspecial likes this.
  2. Jun 7, 2022 at 8:37 PM
    #2642
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Do you have disk brakes in the rear?
  3. Jun 7, 2022 at 9:15 PM
    #2643
    cbechtold
    Cory
    Pleasanton, CA
    I will. I have a Sequoia axle is sitting under the truck now and ready to go in once I finish up the brakes.
    otis24[QUOTED] likes this.
  4. Jun 7, 2022 at 9:15 PM
    #2644
    otis24
    Mark
    California
    Oh right!
  5. Jun 8, 2022 at 5:39 AM
    #2645
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Only reason for new brake lines is because you're getting rid of ABS right? Or is that because of the new rear brakes?
  6. Jun 8, 2022 at 5:58 AM
    #2646
    cbechtold
    Cory
    Pleasanton, CA
    It's because of the ABS delete. There's no reason for the new lines if you're keeping ABS.
    Wulf and BYJOSHCOOK[QUOTED] like this.
  7. Jun 8, 2022 at 6:12 AM
    #2647
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    How did your Pedal fit?
    When I did T100 booster/master it made the pedal travel all wonky.
  8. Jun 8, 2022 at 6:43 AM
    #2648
    cbechtold
    Cory
    Pleasanton, CA
    Pedal fits fine. I had to pull out all the existing linkage. I'm probably going to pull the pedal out and drill a hole a little higher up compared to stock to get smoother pedal travel since I'm using washers to angle the booster. Would also allow the booster to seal properly against the firewall.
  9. Jun 8, 2022 at 6:46 AM
    #2649
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I also pulled the linkage, but also found if I trimmed ~5-6 threads of the t100 rod then it fit OK with one of the clevis's I don't think I spaced the booster unevenly... still not 100% happy with my setup, curious to see how you like whatever solution you end up with.
  10. Jun 8, 2022 at 8:58 AM
    #2650
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
  11. Jun 8, 2022 at 11:52 AM
    #2651
    cbechtold
    Cory
    Pleasanton, CA
    Yeah, fitment is a bit wonky out the gate. I'll probably post about it once it's all finished and buttoned up.
    Bandido[QUOTED] likes this.
  12. Jun 8, 2022 at 11:53 AM
    #2652
    cbechtold
    Cory
    Pleasanton, CA
    Hello :wave:
  13. Jun 12, 2022 at 7:32 PM
    #2653
    cbechtold
    Cory
    Pleasanton, CA
    Okay. Here's hopefully the last update on the whole front end before she's back on all 4. Got all the brake lines bend up and test fitted. Pretty happy with how these came out for never really working on brake lines before.
    PXL_20220612_235331948.PORTRAIT
    by Cory Bechtold, on Flickr
    PXL_20220612_184414308.PORTRAIT
    PXL_20220612_235354516.PORTRAIT
    PXL_20220612_235136582.PORTRAIT
    PXL_20220612_235217121.PORTRAIT
    The line going from the master cylinder to the rear brakes could be a lot better if I'm being honest, but I think the fitting on the frame might leak since it might be bottoming out on threads. Going to be awhile until I know since I need to plumb the rear brakes first.
    PXL_20220612_235603128.PORTRAIT
    I also received motor mounts from @Bonzen for the truck. My old motor mounts were basically ready to come apart, plus the passenger side one did split in 2 after I got the motor out.
    PXL_20220613_000114886
    And there is out current state of affairs. Still a lot of work to do, but I'm excited to move on from the front and get the Sequoia axle swapped in along with a few more goodies. Actually starting to see the light at the end of the tunnel as well since motor stuff is starting to arrive. I've got a few things I'm still waiting on, but hopefully soon I'll have everything and we can really get this party started.
  14. Jun 12, 2022 at 7:42 PM
    #2654
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Those brake lines look great
    TacoEspecial and cbechtold[OP] like this.
  15. Jun 12, 2022 at 7:45 PM
    #2655
    cbechtold
    Cory
    Pleasanton, CA
    Thanks Ian!
  16. Jun 12, 2022 at 9:06 PM
    #2656
    Bonzen
    Bonzen Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Glad they made it! And I second it, the brake line fab looks legit.
    cbechtold[OP] likes this.
  17. Jun 12, 2022 at 9:12 PM
    #2657
    cbechtold
    Cory
    Pleasanton, CA
    Thanks man! I'll get the OEM mounts mailed back to you here soon.
  18. Jun 12, 2022 at 9:28 PM
    #2658
    otis24
    Mark
    California
    It’s looking great!
    I can’t wait to see this beast out on the trails!
  19. Jun 12, 2022 at 9:40 PM
    #2659
    cbechtold
    Cory
    Pleasanton, CA
    Thank! Same here Mark. Getting closer everytime. I'm probably going to miss out on summer wheeling, but I'm definitely getting into some snow this Winter.
  20. Jun 12, 2022 at 9:42 PM
    #2660
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Nice progress Cory! Brake lines look professional. And Those motor mounts look sick! When will the motor be done? Are you planning on being down for all wheeling season?
