cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Jun 12, 2022 at 9:47 PM
    #2661
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Thanks Dan! Kurt said he can have the motor assembled as a long block in about a week or two after I deliver parts to him. I'm just waiting on a piston and a freeze plug for the back of the motor. Unfortunately it does look like I'll be down for the vast majority of wheeling season. Especially since I also have to break in the motor and differentials before I can wheel or drive long distance.
    otis24 and Dan8906[QUOTED] like this.
  2. Jun 13, 2022 at 6:13 AM
    #2662
    cynicalrider
    cynicalrider #NFG
    Jersey
    What tools did you use to make the brake lines? I know Eastwood sells a bunch, wasn't sure if you used theirs or not. They all came out awesome!
    cbechtold[OP] likes this.
  3. Jun 13, 2022 at 6:51 AM
    #2663
    cbechtold
    Cory
    Pleasanton, CA
    Thanks man! I used a mastercool universal flaring kit, a few hand benders, a drill with a countersinking bit, and some sand paper.
  4. Jun 17, 2022 at 7:32 PM
    #2664
    cbechtold
    Cory
    Pleasanton, CA
    Today was a pretty big day for me. Front end is pretty much done at this point outside of a few minor details. That being said, I am beyond stoke to finally have the front back on the ground today.
    PXL_20220617_212750259.PORTRAIT
    by Cory Bechtold, on Flickr
    She's gonna look mean once done. Definitely sitting very high right now, but with no motor and suspension isn't broken in yet, she's definitely got a bro lean going on right now. :rofl:
    Outside that, I was also able to run the front diff breather line and got it as high as I could.
    PXL_20220617_192615373.PORTRAIT
    Also got some new edge trimming for the fenders. These have some sheet metal inside them so these should stay on the fender compared to the last one I used.
    PXL_20220617_192310739.PORTRAIT
    And with that behind us, now I'm turning my attention to the rear suspension and axle swap now.
    PXL_20220617_231628849.PORTRAIT
    I'm getting pretty motivated so here's hoping I can knock this section of the build out in some decent time. I'm definitely ready to enjoy a little bit of wheeling and camping if I can get the truck broken-in in time.
  5. Jun 20, 2022 at 6:07 PM
    #2665
    cbechtold
    Cory
    Pleasanton, CA
    Rear axle swap is in full swing, and the rear suspension update is at a stand still for a little bit. I'll explain in a bit.
    While I'm not swapping out the leaf pack, I am putting longer shackles on the truck. The rear will sit about an extra inch taller and interior help level out the truck with LT up front.
    PXL_20220619_181127825.PORTRAIT
    Had to cut the old shackles out, but these new ones are definitely beefier compared to stock.
    Here's ride height and full droop with only axle weight. Full droop is probably a little more than what I will actually have since I'll be prioritizing up travel this time around.
    PXL_20220619_182758623.PORTRAIT
    PXL_20220619_182834378.PORTRAIT
    Out with the old...
    PXL_20220619_195045903
    PXL_20220619_200321977
    And full pause on mounting up the rear axle. Unfortunately I didn't think to measure the rear axle tubes on the Sequioa axle, and it turns out that the Tacoma u-bolt flip kit I bought from RuffStuff didn't fit at all. Silly mistake as well, but I did order the u-bolt flip kit before I got the axle. I do already have 3 1/4" u-bolts on order, so hopefully next weekend I can get the axle set and the pinion angle set.
    PXL_20220619_221843019
    As for the rest of the time I spent on the truck, I cut my bedsides back to match the front fenders. This did include having to cut the gas tank door, which sucked, and I dropped the angle grinder on it and it left a good dent.
    PXL_20220620_183016249.PORTRAIT
    PXL_20220620_183053372.PORTRAIT
    PXL_20220620_183119972.PORTRAIT
    PXL_20220620_204516884.PORTRAIT
    PXL_20220620_225500953.PORTRAIT
    Overall, not too bad. Once I get the truck out of the garage I'll be able to tell how good or bad the cuts are, but the passenger side is looking pretty good. While I think the cuts are going to look a little bit ridiculous on 35s, it's the only way I can do it without just leaving the holes for the fender flare clips. Either way, I'm digging the no fender flare look right now. Hopefully the new u-bolts arrive this week and I can work on getting the Sequoia axle set in place.
    I'll end this with an update on my motor. I dropped off everything my builder needs to finish rebuilding my motor. While I won't be seeing my motor for a little bit longer, I know that next month I will have my motor back as a long block. As of right now, my dad and I are aiming for August to have the truck out of the garage and, this might be pushing it a little, possibly at Marlin Crawler Round-Up this year. MCR is definitely pushing it since I need to break in everything and test it before I run the Rubicon. Doable? Yes, but it's going to be close.
  6. Jun 20, 2022 at 6:44 PM
    #2666
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I’ll see ya at the round up! :rofl:With @betterbuckleup and @Tof-Corey
  7. Jun 20, 2022 at 7:02 PM
    #2667
    cbechtold
    Cory
    Pleasanton, CA
    Here's hoping I'll see you guys out there! I'm going to try and make it out there!
    Dan8906[QUOTED] likes this.
  8. Jun 20, 2022 at 9:33 PM
    #2668
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Why did you decide to cut the fenders now? Why not just wait until it's all bolted up and you can flex it out and do that last to cut the minimal amount.
  9. Jun 21, 2022 at 6:33 AM
    #2669
    cbechtold
    Cory
    Pleasanton, CA
    I want the fenders to match more than anything. I also like the look of the fenders without the holes in them.
    otis24 likes this.
  10. Jun 21, 2022 at 7:59 AM
    #2670
    cynicalrider
    cynicalrider #NFG
    Jersey
    Damn you went fully commit to get rid of those holes! I am always so torn on them, I hate the holes and could fill them with weld but then would need to get it all painted. But with no flares, even with the cuts I got now, 35's look tiny. It's a lose lose haha
    Also that trim you are using looks like the same trim I run and it's MUCH more durable and stays on better than anything else I have tried so far.
  11. Jun 21, 2022 at 8:01 AM
    #2671
    cbechtold
    Cory
    Pleasanton, CA
    Yeah, I also though about welding them shut, but I don't have time or money to have this truck wrapped or repainted. Guess that means I'll need some bigger tires to fit wheel well better. :bananadead:
    TacoEspecial likes this.
  12. Jun 21, 2022 at 8:04 AM
    #2672
    cynicalrider
    cynicalrider #NFG
    Jersey
    With LT, bigger rear and a crawl box, I always felt these trucks could reliably handle a 37. But that's based on theory on how well it does on 35's for me personally :p
  13. Jun 21, 2022 at 8:18 AM
    #2673
    cbechtold
    Cory
    Pleasanton, CA
    It is very dependent on how you wheel. A Ford 9" rear, ARBs, and RCVs would definitely allow for a lot more abuse, though the steering rack is still my worry. I'm still toying with the idea, but I'm definitely using these 35s before I buy tires and wheels again. The part that is definitely not my favorite is that I'd have to re-tub the firewall and cut out and/or rebuild new inner fenders. Everything barely clears up front with 35s.
  14. Jun 21, 2022 at 8:27 AM
    #2674
    Dan8906
    Daniel
    Concord, California
    What size is the sequoia rear end? A Currie 9” setup would be a sweet setup.
  15. Jun 21, 2022 at 8:35 AM
    #2675
    cbechtold
    Cory
    Pleasanton, CA
    Toyota 8.4. Same size ring and rinion, but a stronger carrier. Currie makes a sweet setup.
  16. Jun 21, 2022 at 8:35 AM
    #2676
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yup the steering is now the weakest point. Even on 35's I have gone through a bunch of pumps/racks before finally having success with all brand new OEM stuff, and even then my 2017 rack is leaking again. Seen very interesting concepts between rack savers/swing set, but almost all will require a ton of custom fab.
  17. Jun 21, 2022 at 8:40 AM
    #2677
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    I wonder how difficult, or if it would even be feasible to swap a howe rack in
  18. Jun 21, 2022 at 8:43 AM
    #2678
    cbechtold
    Cory
    Pleasanton, CA
    The setup I've like the most has been the one made by TNT Fab.
    https://www.instagram.com/p/CEpUfSeB6-_/
    It's be pretty tough given the location of where it's need to go. Full Hydro would be easier to package, but on a street drive vehicle, full hydro is a big nope from me.
  19. Jun 21, 2022 at 8:45 AM
    #2679
    Dan8906
    Daniel
    Concord, California
    Does he sell those? I don’t see an actual website. I’d be interested in the price. Looks like a sweet setup
    otis24 likes this.
  20. Jun 21, 2022 at 8:50 AM
    #2680
    cynicalrider
    cynicalrider #NFG
    Jersey
    I liked this setup too, but did NOT like no boots to protect those rack seals.
