cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Sep 20, 2022 at 9:17 AM
    #2701
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    What's the plans for down the line with the rear? SUA & bypasses?
  2. Sep 20, 2022 at 9:22 AM
    #2702
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    More than likely 3 or 4 link in a couple years.
    I keep toying with the idea of SOA F67s and bypasses, but idk
  3. Sep 20, 2022 at 9:31 AM
    #2703
    betterbuckleup
    Ian
    Concord, CA
    If you find a deal on some used leafs, could be an affordable way to go. I hear great things about the performance of SUA setups
    cbechtold[QUOTED][OP] likes this.
  4. Sep 20, 2022 at 9:49 AM
    #2704
    cynicalrider
    cynicalrider #NFG
    Jersey
    soa f67’s? These builds immediately come to mind.
    https://youtu.be/2rTlx96YGWw
  5. Sep 20, 2022 at 9:31 PM
    #2705
    cbechtold
    Cory
    Pleasanton, CA
    I'll keep an eye on the marketplaces for cheap parts, but unless I find some steals, nothing is happening anytime soon.
    Yep. That's exactly why I'd do SOA with F67s. Likelihood of that happening is very small, but I never know at this point with this build.
    cynicalrider[QUOTED] likes this.
  6. Sep 21, 2022 at 2:50 PM
    #2706
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lookin good man. What axle you rocking again? i can't remember. Like the brakes.
    cbechtold[OP] likes this.
  7. Sep 21, 2022 at 3:19 PM
    #2707
    cbechtold
    Cory
    Pleasanton, CA
    It's a 2002 Sequoia rear axle. Uses the Toyota 8.4 diff. It's fairly similar to the Tundra rear axle that is more commonly used for long travel applications.
    Blackdawg[QUOTED] likes this.
  8. Sep 21, 2022 at 3:20 PM
    #2708
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah cool. I have a T100 to use. But think i'll try for one of these for the rear discs.
    Lookin good man! I think that rear setup should perform great with the front.
  9. Sep 21, 2022 at 3:28 PM
    #2709
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I've got a sequoia axle too, what did you end up doing to get the parking brake hooked up?
  10. Sep 21, 2022 at 8:45 PM
    #2710
    cbechtold
    Cory
    Pleasanton, CA
    It's a great axle for the price. Stout as well. Definitely should withstand some abuse. Rear disc brakes paired with Tundra brakes up front should be a huge step up over stock as well.
    We'll see about the rear suspension. I'm hopefully that'll be good enough for the time being so I can save money for the next phase in a few years.
    Not yet. Current goal is get the truck running again and driving. Parking brake can come later, but I already have a few ideas in mind.
  11. Oct 26, 2022 at 10:00 PM
    #2711
    cbechtold
    Cory
    Pleasanton, CA
    PXL_20221025_213147617
    by Cory Bechtold, on Flickr
    I guess it's time to update this thread again since I've actually made progress on the truck. Rear suspension is done with all the mock up and it's ready to get burnt together this weekend. Still a few minor details I need to work out, but I'm ready for everything to start coming together for the end result.
    Rear limit straps to help protect the shocks.
    PXL_20221017_212959796.PORTRAIT
    Brake lines came out okay. Not to happy with the long run on the axle so I might remake that before final assembly. Also need to order some DOT legal brake lines.
    PXL_20221017_212852856.PORTRAIT
    PXL_20221025_210714878
    Added a proportioning valve for the rear to help fine tune braking. Decided to put it under the hood to help keep it as clean as possible.
    PXL_20221025_225250082.PORTRAIT
    And that brings us to yesterday were she's all torn down again and ready to get welded together. I'm ready to see her out of the garage and moving again. I plan on getting the heater core done while I'm getting everything painted and ready for final assembly. Once that's done, it's put the rear back together add fluids, connect the battery, and go... in theory lol
    PXL_20221026_015049168
    The goal is end of November to be running and driving. I think it's doable, but that's also assuming that nothing causes a delay.
  12. Oct 27, 2022 at 8:06 AM
    #2712
    cynicalrider
    cynicalrider #NFG
    Jersey
    Easily the cleanest spot I have seen so far for the proportioning valve. What makes brake lines non DOT legal? :confused: Is this a Cali thing?
  13. Oct 27, 2022 at 8:12 AM
    #2713
    Speedytech7
    Yeah I'm digging his spot, I wish I had thought of mounting it directly to the master cyl. I mounted mine to the master cyl bolt location and had a conversion line go down to the tee instead.
  14. Oct 27, 2022 at 8:28 AM
    #2714
    Speedytech7
    It looks like his brake lines are AN with metric conversion fittings at the end, I don't think that's DOT approved, but it's common, my rear line is AN too and it makes it way easier to replace if required, can make it longer or shorter easily as well.
  15. Oct 27, 2022 at 11:13 AM
    #2715
    cbechtold
    Cory
    Pleasanton, CA
    I believe it has to do with the AN fittings and the lack of a rubberized coating on them, but idk. I'll just order the correct ones.
    Correct. I should have gotten a 45° angle at the banjo, but I'll see if that available when I order the new ones.
  16. Oct 28, 2022 at 10:18 AM
    #2716
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    Out of curiosity, why did you mount the rear bump stops "down" on the frame instead of up? It looks like you're losing out on uptravel with that setup, but I wasn't sure if you were trying to avoid cutting the bedsides more.
  17. Oct 28, 2022 at 10:31 AM
    #2717
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Just from what I see probably so he won't bottom out his shocks :notsure:
  18. Oct 28, 2022 at 1:03 PM
    #2718
    cbechtold
    Cory
    Pleasanton, CA
    The bump stops are set so they will protect the shocks at both full bump and when articulated. I don't mind cutting the fenders at all. I wish I could have gone up more, but that would have meant either going SUA or links which isn't an option right now with trying to get the truck running as soon as possible.
  19. Oct 30, 2022 at 7:48 PM
    #2719
    cbechtold
    Cory
    Pleasanton, CA
    Lots of progress this past weekend. Big thanks to my dad for helping with a ton of welding on all of this while I was stuck at work. We were able to get everything welded up and even got the frame painted as well with the shock hoops in place.
    PXL_20221031_002219260
  20. Oct 30, 2022 at 10:18 PM
    #2720
    Blackdawg
    Monte
    Wyoming/St. Louis
    coming together great!
    I hate that you're doing what I've wanted to do for years but not that much :D great proof of concept.
    otis24 and cbechtold[OP] like this.
