cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Oct 31, 2022 at 8:53 AM
    #2721
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Ha! It's definitely great to see it coming together. It's pretty much exactly what I want for leaf springs suspension outside of maybe a different leaf pack.
  2. Oct 31, 2022 at 11:30 AM
    #2722
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Right!
    I was about to post in your thread asking how things are going the other day.
    cbechtold[QUOTED][OP] likes this.
  3. Oct 31, 2022 at 1:00 PM
    #2723
    cbechtold
    Cory
    Pleasanton, CA
    Well the short of it is that I'm aiming for end of November to be done. Still got a few things to do, but I think it's doable!
  4. Oct 31, 2022 at 3:38 PM
    #2724
    otis24
    Mark
    California
    That’s just around the corner!
  5. Oct 31, 2022 at 8:41 PM
    #2725
    cbechtold
    Cory
    Pleasanton, CA
    Just in time for snow wheeling season! ;)
    otis24[QUOTED] likes this.
  6. Nov 7, 2022 at 9:50 PM
    #2726
    cbechtold
    Cory
    Pleasanton, CA
    Today marks a pretty big milestone in this rebuild. For the first time in 9 months, the truck is back on all 4 tires. Pretty freaking stoke with how the truck is looking now. Rear suspension is pretty much perfect for what I want with OEM leaf spring geometry. Here's hoping that I can get it tuned to work as well as I'd like.
    PXL_20221108_032055816
    by Cory Bechtold, on Flickr
    PXL_20221108_031235768.PORTRAIT
    PXL_20221108_032135051
    While also working on the rear end, I was able to get a new heater core in the truck while waiting for paint to dry. T'was a huge PITA!
    PXL_20221107_012314343
    Lockers are also plumbed and tested. No leaks anywhere. Also installed a new higher rated pressure switch on the compressor.
    PXL_20221108_032921798.PORTRAIT
    PXL_20221102_013327598
    Not as many photos of the rear as I would like, but I was definitely just pushing to get the truck back on the ground the last few days.
    At this point, there's honestly not a whole lot to do anymore. Outside of accessory belts on the motor, all the fluids, filters, and pick up and install my rear driveshaft, she's pretty damn close to being a functionally vehicle again.
  7. Nov 7, 2022 at 10:00 PM
    #2727
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I figure the rear will settle some once you get it rolling around. That shackle angle don't look that great.
  8. Nov 7, 2022 at 10:12 PM
    #2728
    cbechtold
    Cory
    Pleasanton, CA
    It's not ideal, but it's better than I expected. The shackles I have are fortunately adjustable so I'll be messing around with ride height once the front settles and breaks in a little more.
  9. Nov 7, 2022 at 10:16 PM
    #2729
    betterbuckleup
    Ian
    Concord, CA
    you'll know pretty quickly once you get it streetable!
  10. Nov 7, 2022 at 10:19 PM
    #2730
    cbechtold
    Cory
    Pleasanton, CA
    Very true. I'll be staying optimistic about it for now, unless I hate it from the start in which that'll just fuel the fire to link the rear end sooner :bananadead:
    DashMaple and bravinci like this.
  11. Nov 13, 2022 at 9:40 PM
    #2731
    cbechtold
    Cory
    Pleasanton, CA
    We've got a runner! Chasing a high idle gremlin, but I think it is related to the idle air control valve or a vacuum leak. Either way, truck sounds great and is running super smooth!
    Outside that, truck is basically at 95% back together. All new fluids, new filters, new accessory belts, rebuilt rear driveshaft, etc... Just need to put the front of the truck back together, bleeding brakes, and drive her out of the garage. She's almost ready to hit the roads again and I cannot wait!
    jubei, bravinci, DashMaple and 6 others like this.
  12. Nov 20, 2022 at 8:30 PM
    #2732
    cbechtold
    Cory
    Pleasanton, CA
    IMG_6806
    10 months of work has finally come to an end! I am beyond stoke on the outcome of what I created! I had a vision in my head at the start of this, outside of the blown motor, and this is pretty much right on what I was thinking. While not done, this is a great way to start to what I'm considering "Phase II."
    For the first drive, I'm impressed so far. Outside of not being able to drive down the road straight, everything is nice and smooth. Engine is running perfect! 5.29s are a night and day difference. Front suspension is very nice and the rear suspension ain't too bad either. With some good valving and maybe a spring rate change in the front it should be pretty damn good eventually.
    Before I dump more photos, I've got to give my parents a huge shoutout on this whole project. Even when I was not in the mood to work on this truck, my dad was always there to help push and motivate me when needed. My dad even helped a lot on the rear suspension getting everything welded up while I was at work. Also thanks mom for putting up with me and the stupid shit I do and letting me steal you parking spot for last 10 months.
    Okay here are the photos...
    IMG_6801
    IMG_6804
    IMG_6802
    IMG_6803
    IMG_6807
    IMG_6811
    IMG_6816
    IMG_6824
    Also a video of the crawl ratio with the 5.29s. She's pretty damn slow now.
    Now onward to getting the bugs and problems figured out while I get this truck broken in and ready for King of the Hammers in February.
    waldeeeeen, rob1208, Bandido and 18 others like this.
  13. Nov 20, 2022 at 8:56 PM
    #2733
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Looks great man. Now go get it aligned so you can have you're first pucker moment of shit! going too fast! only to realize it's fine and float through it.
    cbechtold[OP] likes this.
  14. Nov 20, 2022 at 9:27 PM
    #2734
    cbechtold
    Cory
    Pleasanton, CA
    Ha! My plan was to call my alignment guy first thing in the morning and see if I can drop the truck off on my lunch break. Definitely looking forward to see how the truck handles once the motor and diffs have more time to break in.
    Speedytech7 likes this.
  15. Nov 21, 2022 at 7:34 AM
    #2735
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's... it's beautiful.
  16. Nov 21, 2022 at 8:28 AM
    #2736
    betterbuckleup
    Ian
    Concord, CA
    What's the process for breaking in the motor?
  17. Nov 21, 2022 at 8:37 AM
    #2737
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That thing is glorious! Nice job!
  18. Nov 21, 2022 at 8:47 AM
    #2738
    cynicalrider
    cynicalrider #NFG
    Jersey
    Now that it's on weight and fully flexed, any chance the tires will hit the outboarded shocks or no? What's the BS on those wheels?
    bravinci likes this.
  19. Nov 21, 2022 at 8:53 AM
    #2739
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    gawd damn she thicccc.
    Stoked to see this thing out wheeling
    cbechtold[OP] and betterbuckleup like this.
  20. Nov 21, 2022 at 9:49 AM
    #2740
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Drive it for like 500 miles keeping the rpm’s down and then change the oil.
    jubei likes this.
