cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Dec 28, 2022 at 5:44 PM
    #2761
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Happy Holidays to y'all! Here with a small update. Just been driving the truck as of late. I installed a new Nardi steering wheel that my parents got me for the Christmas! Pretty stoked on that.
    PXL_20221229_003413078.PORTRAIT
    by Cory Bechtold, on Flickr
    Also in preparation for updating the auxiliary wiring, I added some switches that I'll be wiring up to a new fuse/relay panel that I'll build.
    PXL_20221229_003446556.PORTRAIT
    Also did my 500 mile oil change for both the motor and diffs. This oil catch can is working great, and I'm glad this stuff isn't going back into my new engine.
    PXL_20221228_224841176.PORTRAIT
    In other exciting news, I've also developed a new grinding/whirling noise from my transfer case that sounds just wonderful. New j shift transfer case is on the way, and I have all new bearings for the crawl box thanks to the guys at Marlin Crawler. Just going to rebuild everything to hopefully solve all future problems so I can start saving up for an Atlas 4 speed if this happens again.
    Still planning on doing one last oil change on the motor and diffs before this 1000 miles round trip to Hammertown and back. Also going to have the alignment redone since it pulls and wanders a little on the road. Looks like she needs more caster and a slight toe out from what I'm gather from people I've talked too.
    rob1208, BYJOSHCOOK, jubei and 3 others like this.
  2. Dec 29, 2022 at 8:02 AM
    #2762
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    What catch can u running?
    They're nice to have.
    You have to take it off every few years for smog check tho fyi
  3. Dec 29, 2022 at 10:23 AM
    #2763
    cbechtold
    Cory
    Pleasanton, CA
    Evil Energy if I remember correctly. I'm glad I kept the hose that goes there if that's the case. I'll runn it by my smog guys in town and see if he'd smog it, but if not I'll just hook that up for a day.
  4. Dec 29, 2022 at 6:02 PM
    #2764
    betterbuckleup
    Ian
    Concord, CA
    Yeah, it's an easy swap to do when the time comes
    cbechtold[QUOTED][OP] likes this.
  5. Jan 8, 2023 at 7:01 PM
    #2765
    cbechtold
    Cory
    Pleasanton, CA
    Pulled the t-case out since it's been making a bunch of noise as of recent. Turns out it's worse that what I was expecting. Needle bearing welded itself to the coupler. Ordering parts tomorrow and hopefully putting everything back together next weekend.
    PXL_20230109_013002340
    PXL_20230108_230152643.PORTRAIT
    I can safely say I'm only fixing this dual case setup one more time because I order an Atlas... presuming it survives long enough to be fixed one more time.
  6. Jan 9, 2023 at 6:18 AM
    #2766
    v5ensx
    v5ensx CARB legal is not CALI legal
    Curious if you were able up get the horn to work without the clock spring?
  7. Jan 9, 2023 at 10:04 AM
    #2767
    cbechtold
    Cory
    Pleasanton, CA
    No, but I have the part to make it work.
  8. Jan 9, 2023 at 12:44 PM
    #2768
    cbechtold
    Cory
    Pleasanton, CA
  9. Jan 9, 2023 at 4:16 PM
    #2769
    v5ensx
    What's needed? Thinking about getting an aftermarket wheel too.
  10. Jan 9, 2023 at 5:09 PM
    #2770
    cbechtold
    Cory
    Pleasanton, CA
    You need a copper fitting to contact the back of the hub to complete the circuit. The most common way I've seen people do it is by using the horn shoe from Honda.
    Part Number: 35259-SH3-A02
    Shouldn't be too hard to wire up once you figure out which wire is the horn.
  11. Jan 9, 2023 at 5:25 PM
    #2771
    v5ensx
    Interesting... Following your built and hopefully you're able to provide detail and which wire it is.
  12. Jan 9, 2023 at 5:26 PM
    #2772
    cbechtold
    Cory
    Pleasanton, CA
    I definitely will. Figure it's information that people would want.
  13. Jan 9, 2023 at 7:43 PM
    #2773
    02hilux
    Planet: EARTH
    Ouch
  14. Jan 9, 2023 at 8:01 PM
    #2774
    cbechtold
    Cory
    Pleasanton, CA
    Ouch indeed. Lesson learned is that I need to check the fluid level of my t-case and crawlbox regularly. :frusty:
  15. Jan 9, 2023 at 8:08 PM
    #2775
    02hilux
    Planet: EARTH
    Was is low? Empty?
  16. Jan 9, 2023 at 8:12 PM
    #2776
    cbechtold
    Cory
    Pleasanton, CA
    Wasn't empty but when I drained it there's was maybe a cup of fluid at most that came out.
  17. Jan 9, 2023 at 8:14 PM
    #2777
    02hilux
    Planet: EARTH
    Fudge. Where did it go?
  18. Jan 9, 2023 at 8:23 PM
    #2778
    cbechtold
    Cory
    Pleasanton, CA
    No idea. Probably leaked out of the crawlbox somewhere. Definitely making sure everything is sealed up real good before I put it back in the truck.
  19. Jan 9, 2023 at 8:37 PM
    #2779
    02hilux
    Planet: EARTH
    That's a lot of missing gear oil. Did it drain/flow to the tail housing of the transmission before the rf1a adapter?
  20. Jan 9, 2023 at 8:49 PM
    #2780
    cbechtold
    Cory
    Pleasanton, CA
    There wasn't a ton of gear oil in the tail housing. Most of the oil that I found was between the t-case and t-case adapter.
