cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Apr 18, 2023 at 9:47 PM
    #2821
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    yeah fair enough. can't blame you there.
    But..buy once cry once haha
    otis24 and cbechtold[QUOTED][OP] like this.
  2. Apr 18, 2023 at 10:30 PM
    #2822
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    This is my plan. Converting to switch pro is pricy but is the right move.
  3. Apr 18, 2023 at 10:34 PM
    #2823
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    ill have to confirm and double-confirm that. there are lesser brands but the switch pro is solid.
    Dan8906[QUOTED] likes this.
  4. Apr 18, 2023 at 10:40 PM
    #2824
    Dan8906
    Daniel
    Concord, California
    I will still stick to my first point. Having high amp lines going into the cab is a no no. I’d highly suggest rethinking it Cory.
  5. Apr 18, 2023 at 10:47 PM
    #2825
    02hilux
    Planet: EARTH
    Did you get your cc & horn to work with your aftermarket steering wheel?
  6. Apr 18, 2023 at 10:48 PM
    #2826
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I don't think it's problematic at all provided there is some sort of over current protection close to the power source (battery). It's common in motorsport to run the power system into the driver cabin area. I'm putting both batteries in the cab even, screw having that weight on the fender and core support.
  7. Apr 18, 2023 at 10:51 PM
    #2827
    Dan8906
    Daniel
    Concord, California
    As long as over current protection is close to the power source it should be good. The photo he has looks like there’s 4’-5’ from the battery to the breaker though.
  8. Apr 18, 2023 at 11:18 PM
    #2828
    Blackdawg
    Monte
    Wyoming/St. Louis
    I don't see issues with it if it's properly fused/relayed. Think of all the high current amplifiers that crazy people run in car stereo's.
    cbechtold[OP] likes this.
  9. Apr 18, 2023 at 11:36 PM
    #2829
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I totally understand where you're coming from, but in the research I've done and people I've talked too, it shouldn't be a problem. The guys at TT Motorsports are who I saw do this first and they've had no issues with it ove the last couple years with their setup.
    Yes. I got the airbag light fix this past weekend as well. No more airbag light and cruise control still works perfectly.
    It's definitely a long run, but I planned the wire and breaker around that. 100amp breaker and 4 gauge wire is rated for 150amps over 8' of distance, so I'm good there. I'd need to measure the exact distance again, but it was towards 7' if I recall correctly.
    Yeah, I've made everything a little overkill. 40amp rated relays and I'll be upsizing wires for all accessories.
    Speaking of all those crazy car stereo setups, I've always wondered how many amps people are running through those system.
  10. Apr 18, 2023 at 11:44 PM
    #2830
    Blackdawg
    Monte
    Wyoming/St. Louis
    When I was in High school. A lot.
    PLUS they were A/B type amps, so not super efficient and pulled a shit load of power. I had a 4000w amp I think for my subs alone and i ran 0/1 gauge wire into the cab. It had a 400amp fuse :laugh: no joke.
    With Class D amps that are mainly what people use these days, much more efficient so raw power pulls aren't quite as crazy. But some of those people still run 2-10+amps depending on what they are doing.
  11. Apr 19, 2023 at 6:02 AM
    #2831
    02hilux
    Planet: EARTH
    Got a write up and picture diagram?
  12. Apr 19, 2023 at 7:04 AM
    #2832
    cbechtold
    Cory
    Pleasanton, CA
    Well damn. That's a lot more than I was thinking lol
    Depending on what time I get home, I should be working on that after work today.
    02hilux[QUOTED] likes this.
  13. Apr 19, 2023 at 12:41 PM
    #2833
    cynicalrider
    cynicalrider #NFG
    Jersey
    I think the point Dan is making is getting missed. The breaker is at the fuse panel and over 7 feet of high amp power going to the panel. That is 7 feet from the battery to the breaker that is now at risk of chafing from vibrations/getting cut along the way and completely unprotected from shorting itself on the body of the truck regardless of whatever sheathing is put on it.
  14. Apr 19, 2023 at 3:10 PM
    #2834
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    Curious, what made you switch from a bussman to a switch pro?
    I setup a 10 relay /40 fuse bussman in the truck years ago and its been working fine. I bought the case to make the smaller 5 relay/20 fuse unit but haven't touched it yet. I overestimated what I needed when I first built it years ago. I have considered going to a switch pro but like its been mentioned, thats some $$$ and I already have the parts I need for the bussman setup. Curious if there are any advantages I'm not seeing making the switch to a switch pro now.
  15. Apr 19, 2023 at 4:21 PM
    #2835
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    with a switchpro you can do some cool stuff like strobe lights. I think you can also control it from your phone and do different trigger patterns. So map one button to turn on all of your lights with one press. Stuff like that
  16. Apr 19, 2023 at 6:16 PM
    #2836
    rob1208
    Rob
    SF Bay Area
    ah, didnt realize the newer ones do all those extra features. I was just thinking it was still a dumb off/on device like my bussman.
  17. Apr 19, 2023 at 8:25 PM
    #2837
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well I didn't replace it. Not yet. I put one in my other truck. I have 3 ha
    But main reason for me was it has trigger functions. So untapped my high beams to one of the trigger wires. Then tell the switch pro to turn on any one of the 8 circuits with my high beams. This function is can be turned on and off.
    Next was built in strobing. I have it in my dd and can make my DD C2 fog lights strobe when it's a blizzard or I'm behind a plow if visibility on the roads is shit. Plus had hopped to add rear firing ambers for the same reason. Some of the shit I drive through in winter is terrible. So being able to strobe is nice.
    Now all of that is possible with a bussman, but takes some custom wiring configuration. Which just adds more crap to the nest.
    While I was able to just do all that with a very clean install by bending a custom mount bracket.
    And now it's stupid easy to add things to truck as I aquire them. Just slap them in the buss bars and done.
  18. Apr 19, 2023 at 10:14 PM
    #2838
    cbechtold
    Cory
    Pleasanton, CA
    I completely understand his point and caution behind it. I take safety pretty serious on this truck and if there is a generally agreed upon way to either do something correctly, or guaranteed the safest way to do something, then I tend to stick to that or improve upon in my own way. If it wasn't for the way I had my battery relocated to the bed and me wanting to take all accessory wiring off the main battery, outside of the winch, I'd definitely be trying to keep the distance as short as possible between the power cables. The reason I'm personally comfortable running wire the distance that I plan to is because of how my main battery is already setup already running about 10 feet of 4/0 gauge wire spanning that distance.
    Clean man. That's definitely the way to do it if you can afford it.
  19. Apr 19, 2023 at 11:40 PM
    #2839
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean if you're running any large gauged wire anywhere, you need to fuse it at the battery. Thats just car wiring 101.
    Speedytech7 and betterbuckleup like this.
  20. Apr 20, 2023 at 3:18 AM
    #2840
    cynicalrider
    cynicalrider #NFG
    Jersey
    this ^ just cause it hasn’t burned down yet doesn’t mean it won’t? :notsure:
    Speedytech7 likes this.
