cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. May 6, 2023 at 5:31 PM
    #2901
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Team no swing out!
  2. May 6, 2023 at 7:21 PM
    #2902
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Yeah. I'm starting to like it now. It kind of makes me want to order a Coastal Off-road high clearance rear bumper and just full send the no swingout lyfe, but that's a next winter sort of project.
    Worst case scenario, I could fabricated a spare tire mount to insert into the rear bumper hitch.
  3. May 8, 2023 at 7:53 AM
    #2903
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Does save a ton of weight and leverage wear with no swingout. I actually had to send my BAMF swingarm that my 35" spare was on, back to get beefed/replaced after KOH this year. I cracked it bombing some trails.. just a lot to ask for of a swingarm with all that overhanging weight. I need my bed space though unfortunately.
    cbechtold[OP] and nudavinci64 like this.
  4. May 8, 2023 at 11:26 AM
    #2904
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    The convenience of a swing out is why I keep it, water/fuel/spare all things I want to bring and take up a lot of space. I’ve considered taking it off for trips through the rubicon but never have. I’d be curious how much of a difference it would make. I know taking my camper shell off makes a noticeable difference
  5. May 8, 2023 at 11:33 AM
    #2905
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I leave it on for the same reasons. I have payed with removing tire and mount and cans and seems to be more than what it weighs since it’s all hanging off. plus my truck is now setup for heavy weight and removing it all would introduce opposite issues of being too stiff with no swingout or no camper if I removed it temporarily. I’m considering going work a less beefy pack so that’s more of an option.
    XPOTRPR likes this.
  6. May 8, 2023 at 11:41 AM
    #2906
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I used to have my spare tire in the overhang of my camper. Which would be approximately where a swing out would put it but maybe a little higher.
    I moved to the middle/front of the camper just in front of the axle to see if it made a difference in how the truck handles.
    It's still in the middle. It's so much better there.
    My truck still handles like a covered wagon but it's much better.
    The downside is that tire is ALWAYS in the way.
    Edit: I moved all the heavy stuff between the axles...mostly batteries, spare tire, water, fridge and beer.
    cbechtold[OP] likes this.
  7. May 8, 2023 at 11:46 AM
    #2907
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Same.. I need the space and convenience and having tables on each swingout is a huge Pro as well. I did have my leaf's re-arched specifically for the truck's newly added weight of the camper and bumper, so when I even just took the one swingarm + 35" spare off.. I could feel the difference with that weight not being there/where it normally would be. Even with moving the spare into the bed and strapping it upright, I can feel the difference.. the weight is there, but now in a different location and distributes said weight differently. I cant wait to get all my parts back so I can get it back to normal.
  8. May 8, 2023 at 11:50 AM
    #2908
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Anyone taking their swingout off in solidarity up in the PNW can donate it to me. I'm tired of lifting a 35 in and out of my bed to get to stuff
  9. May 8, 2023 at 12:05 PM
    #2909
    cbechtold
    Cory
    Pleasanton, CA
    Ah damn. I shaved close to 75lbs off since my swingout is build out of 1/4" material lol
    I've already noticed the handling difference. I actually think I'll like it once I get the spring rates dialed and shocks tuned properly.
    Would recommend trying it out. I actually dig the change so far.
    I'm with you there. Ideally I'd want everything towards the cab for weight, but the amount of room that I don't have there is unsurprisingly, very little.
    I might actually sell my rear bumper and swingout later this year depending on if I like the change enough. :spy:
  10. May 8, 2023 at 12:24 PM
    #2910
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I keep my 13g water tank, tools, spare parts, etc against the cab side in the bed to try and keep the weight as centered and low as possible. Its really just the damn spare tire.
    nudavinci64 likes this.
  11. May 8, 2023 at 12:30 PM
    #2911
    nudavinci64
    Robert
    I want to see if I can get my bumper made in a hybrid style to shave a bunch of weight off. in theory it will work but well see.
  12. May 8, 2023 at 2:30 PM
    #2912
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I’d pull my fingernails out one by one before I ran a swing out all the time. I literally couldn’t imagine having to move it every time I want to drop the tailgate. I even have one now that’s cut off and rusting away next to the shop for my second gen lol
    malburg114 and cbechtold[OP] like this.
  13. May 8, 2023 at 2:45 PM
    #2913
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I was worried about that too when trying to decide to order the rear bumper or not.. but with side access it hasnt been a problem.. but the truck is also a dedicated toy now. I could see how having a swingout on a daily driver might get annoying tho.
    nudavinci64, otis24 and cbechtold[OP] like this.
  14. May 8, 2023 at 8:25 PM
    #2914
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
    Also +1 on this.
    Won’t be running a spare tire swing out this go around. Too much weight off the ass. I will be doing a swing out as a means for extra security on the FlipPac and to hold some traction boards and Rotopax, but definitely no spare tire weight back there.
    rob1208 and cbechtold[OP] like this.
  15. May 8, 2023 at 8:26 PM
    #2915
    cbechtold
    Cory
    Pleasanton, CA
    Damn, that's a lot more weight that I was originally thinking. 13g of water is a while amount, but I guess it makes sense if you're on the road a lot for a long duration of time.
    That's a neat idea. I likely will just build all new armor this coming winter and make it all out of 1.75" DOM tube. Save as much weight as possible.
    This is another big reason for me as well. Too many times where I've wanted to used the tailgate and I've had to move forward 4 feet just to open it.
  16. May 9, 2023 at 5:43 AM
    #2916
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    +1 with no swingout. When my spare was on my swingout, I was riding bumpstops in the rear without any gear in the back. As soon as I moved it to the front of the bed vertically, I have yet to ride the bumpstops even when fully loaded with passengers and stuff. Going to remove my spare tire swingout when I stop being lazy. Planning to keep the driver side swingout for gas and propane however.
    I was never a fan of how tube rear bumpers looked but I've been debating it just to shave weight on the rear end.
  17. May 9, 2023 at 7:04 AM
    #2917
    cynicalrider
    cynicalrider #NFG
    Jersey
    +1 to no swing out. Been running mine on the side of the bed for years. Gone through a couple iterations but ultimately it's one bolt holding it in and like a fin that keeps it vertical. So far haven't seen the bed crack from it.
    jubei and cbechtold[OP] like this.
  18. May 9, 2023 at 7:57 AM
    #2918
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    We got tired of worrying, having to stop, or planning a route to find water to refill on our long trips. 5g wasnt enough for us both for a week+. I've tried to plan and layout the build to keep weight dispersed pretty evenly and have been able to keep my dry/wet weights very similar. The truck weighs ~6500lbs and only fluctuates around 200lbs. I keep some water in it all the time, then fill it up on our long trips.. plus food, drinks, gear/clothing, etc. Everything else is already ready and in the truck. If I could just change where a lot of that weight is (hanging off the back) I'd be ok with the weight and everything. If I could come up with a way to stuff my 35 under the truck.. I'd do that.
  19. May 9, 2023 at 8:21 AM
    #2919
    otis24
    Mark
    California
    I like to carry about 8 gallons plus a few 12 packs of La Croix for extended trips to the desert for just myself.
    Add in another person and 13 gallons is completely reasonable.
  20. May 9, 2023 at 8:22 AM
    #2920
    Speedytech7
    8 gallons of LaCroix sounds dangerous. Ever opened one of them at altitude haha
    XPOTRPR likes this.
