cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. May 9, 2023 at 8:29 AM
    #2921
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I’ve considered moving my water and fuel to under the bed to lower the weight and move it further forward. Much less convenient in that location though
  2. May 9, 2023 at 8:33 AM
    #2922
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Hmmm...bulk la coix on tap?
    I'm going to Shasta June 2nd.
    I might have to bring one and open it on the summit (assuming I make it that far) and see what happens.
    Speedytech7[QUOTED] likes this.
  3. May 9, 2023 at 8:52 AM
    #2923
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Especially being in the desert. We've ran into strangers out here that were not prepared enough for the heat, so its nice having extra just in case you need to help.
    Thought about the water under the bed idea as well. But yeah, not as convenient... and still not the best since its over/behind the axle. I have my slim upright tank mounted to the front wall of the bed.. so its centered and low-ish and it is nice and accessible.
  4. May 9, 2023 at 9:31 PM
    #2924
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I'd need to get the truck up to speed, but I did notice that I stopped hitting bump in the rear and big curbs.
    I can definitely see where that comes in handy. I rarely am out for a week, mostly 2/3 maybe at most. I got one longer trip coming up in November, but that's it for the the year. The rest of my trips will likely be 1 to 3 day trips.
    I feel like that could work well as long as you could have an easy way to fill up and have water on tap. @cynicalrider has a pretty neat setup that you might want to check out as well to get more ideas for.
    cynicalrider likes this.
  5. May 9, 2023 at 9:50 PM
    #2925
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    that's why I went with a dual. not as much taking up when I want to open it. Yes 2 doors but its quick and I have side access like @XPOTRPR
  6. May 9, 2023 at 10:04 PM
    #2926
    cbechtold
    Cory
    Pleasanton, CA
    I considered that option for awhile, but ultimately it came down to 2 things, 1 I'm lazy, and 2 I think no swingout is probably best for what I'm doing with my truck.
    otis24 likes this.
  7. May 9, 2023 at 10:11 PM
    #2927
    nudavinci64
    Robert
    yah if its going to be a rock warrior it makes sense. I don't have enough money, time or space to build another one so my truck is franken, pre-lander, whatever I can do with it vehicle with split personalities
  8. May 9, 2023 at 10:15 PM
    #2928
    cbechtold
    Cory
    Pleasanton, CA
    Yeah, mostly a crawlerprelander schizophrenic wannabe race truck :rofl:
    otis24 and nudavinci64[QUOTED] like this.
  9. May 9, 2023 at 10:40 PM
    #2929
    nudavinci64
    Robert
    haha exactly
  10. May 15, 2023 at 9:27 PM
    #2930
    cbechtold
    Cory
    Pleasanton, CA
    Alright. This is like version 3 of this already the 3rd go around of rewiring the truck, and if I'm lucky, this will be the last setup on the truck, or at least for a long time. I finally made my mind up on how I'm going to wire everything and where everything is going to be stored. I've got to give credit where credit it due. @Robmonster117 showed my what he was doing for his truck which is pretty damn similar to how I have things setup here. He can go more into detail on his thread once he post that, but props to him for being the brains behind this.
    Here's the short of what's going on and what's going to live in this little box.
    - Dual Optima YellowTop 34/78 Batteries
    - ICT Billet Battery Trays
    - KeyLine Dual Battery Isolator
    - Switch Pros SP-9100 Unit
    - Blue Sea Fuse Panel/Terminal Block/Bus Bar/Circuit Breakers
    - Fastronix Remote Charging Post/Military Spec Battery Terminals
    - ARB CKMA 12 Air Compressor
    I've still got a bunch of work to get to before I bolt this in the bed of the truck, but so far, I'm pretty happy with how this is turning out. For the wiring talk, this time I plan on wiring the winch and the truck separately and adding cut off switches for both of them. Outside of that, I'll start wiring accessories to it once I get this bolted down to the truck starting with the compressor and lockers. Lights and whatnot can come later.
    PXL_20230516_020701377
    by Cory Bechtold, on Flickr
    PXL_20230516_023529643~2
    PXL_20230516_015131544
    otis24, Bandido, TacoEspecial and 6 others like this.
  11. May 16, 2023 at 12:24 PM
    #2931
    Robmonster117
    Robmonster117 Well-Known Member
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Me update my build thread? Lol. Looks good Cory
    rob1208 and cbechtold[OP] like this.
  12. May 16, 2023 at 12:27 PM
    #2932
    cbechtold
    Cory
    Pleasanton, CA
    Lol. One day we can hope. Thanks man!
  13. May 16, 2023 at 1:09 PM
    #2933
    cynicalrider
    cynicalrider #NFG
    Jersey
    Really tho less insta updates moar build updates!
  14. May 16, 2023 at 2:54 PM
    #2934
    Robmonster117
    Robert
    Gilroy
    02 ext. cab 4x4
    Truck parts
    Gotta feed the instahoes though:D
  15. May 21, 2023 at 10:32 PM
    #2935
    cbechtold
    Cory
    Pleasanton, CA
    Got a little bit more work done on the auxiliary electrical system. Put some cutouts in the electrical panel for the switch pros and fuse panel for ease of use when wiring. Also got my KeyLine Dual Battery Isolator Kit in and a handful of the wires taken care of. Still got some more wiring to get around to, but good progress today.
    [​IMG]PXL_20230522_002639581 by Cory Bechtold, on Flickr
    PXL_20230521_225549877.PORTRAIT
    Fitment is absolutely mint. Way better than I could have ever done without that help of my Dad and his mill.
    PXL_20230522_002802211
    PXL_20230522_002845563
    PXL_20230522_033918999
  16. May 22, 2023 at 7:08 AM
    #2936
    Dan8906
    Daniel
    Concord, California
    It’s nice when you have the right tools for the job. Looking good brotha
    cbechtold[QUOTED][OP] likes this.
  17. May 22, 2023 at 7:10 AM
    #2937
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's a beast of an annular cutter, wish I had three phase power in my shop, I'd love to have a mill
    jubei and cbechtold[QUOTED][OP] like this.
  18. May 22, 2023 at 7:47 AM
    #2938
    cbechtold
    Cory
    Pleasanton, CA
    Thanks man! Pretty stoked with the outcome thus far!
    Yeah, I was pretty lucky that my dad has all the right tools. He doesn't have 3 phase power. He has a converter from 220v to 3 phase.
    jubei likes this.
  19. May 22, 2023 at 8:04 AM
    #2939
    02hilux
    Planet: EARTH
    @cbechtold
    Do you have a write up on cruise control and horn function with part use for the aftermarket steering wheel?
  20. May 22, 2023 at 8:13 AM
    #2940
    cbechtold
    Cory
    Pleasanton, CA
    I knew I forgot to do something. I'll get that written up and posted by tomorrow.
