cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. May 22, 2023 at 8:23 AM
    #2941
    02hilux
    Planet: EARTH
    Sweet. Thanks!
  2. May 22, 2023 at 11:20 PM
    #2942
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
  3. May 26, 2023 at 8:32 PM
    #2943
    cbechtold
    Cory
    Pleasanton, CA
    Well in an attempt to get the truck ready for Summer, I'm trying to wrap up my "Winter Projects." It ain't going to plan lol
    I start on a good note, here's a photo of the truck with the new wheels. Still can't get enough of how these look.
    PXL_20230525_013036565
    by Cory Bechtold, on Flickr
    PXL_20230525_012910317
    Now on to the main thing I'm working on over my 4 day weekend, fixing my steering rack leak.
    PXL_20230526_182231805
    I'm also taking this as a time to upgrade a weak point for these trucks. Hello Total Chaos Lower Uniball Conversion.
    PXL_20230526_201723362
    PXL_20230527_002953173
    These things are beef. I did install some ARP hardware for the connection to the spindles. Can't wait to see how they hold up. Also going to run dual sheer heims now and see how those work. Hopefully I don't kill a steering rack quickly or break mounts like a wet napkin.
    PXL_20230527_002646717
    Now into my biggest road block now. I'm still completely confused on how I didn't see this when I did all the work for the long travel last year, but one of the fittings for the power steering is completely rounded off. I'm hoping I can get parts tomorrow if by some stroke of luck a local Toyota dealership has the power steering lines. I'll be making calls in the morning, but worse case I guess I'll order parts that I need and go a head and start working on the electrical stuff for the truck again.
    essjay, rob1208, synergy10 and 6 others like this.
  4. May 28, 2023 at 2:19 PM
    #2944
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    You know i have a steering rack. OEM too…
    That flex f*cks! So sick
    otis24 and cbechtold[OP] like this.
  5. May 28, 2023 at 3:59 PM
    #2945
    cbechtold
    Cory
    Pleasanton, CA
    I fortunately have a brand new steering rack and I plan on later rebuilding my current steering rack as a backup.
    Flex ain't to shabby either. The rear works pretty okay, but I'm working on a fix for that.
  6. Jun 17, 2023 at 12:28 AM
    #2946
    cbechtold
    Cory
    Pleasanton, CA
    Finally wrapped up my time in wiring purgatory. As much as I'm happy I took the time and stoked on the outcome of the wiring this time around, I'm so over wiring right now and I'm still not done yet. Still have a few things to wire up, but that's a problem for future me. Anyways, here's where everything sits in it's mostly final form.
    I last left off on putting the finishing touches for the box prior to installing it in the truck. Afterwards, I went ahead and started getting a good base with ripping out all the previous wiring outside of the winch controls and got the box bolted to the bed.
    PXL_20230530_231742842
    PXL_20230531_023529243
    PXL_20230606_051403077
    There are 8 5/16" bolts holding down the box, which is not at all overkill. :bananadead:
    Once I had everything ready to wiring, I started with figuring out where to put an in-cab battery cut off switch. Ended up sacrificing the lower center console in the truck, but I never use it anyways, so it's fine I guess.
    PXL_20230528_010453393
    Easy access and hidden out of the way. This is mostly for the event of an electrical fire.
    PXL_20230528_013121529
    Also added a 12v sockets and usb outlet inside that going to be constant hot power to the 2nd battery.
    With everything mostly laid out, I could finally start rewiring the auxiliary accessories. I started with wiring the Switch Pro head unit, battery cut off switch, and power/ground leads for the main battery to the terminals under the hood. For those curious, the truck was swapped over to 1/0 gauge wire. I'll explain more on this later.
    I also ran terminal pass thrus under the driver seat as well as I found grommet that I could run the Switch Pros harness through without cutting another hole. This couldn't have worked out more perfect.
    PXL_20230602_052049835
    PXL_20230604_224555691
    This is also where I decided to add a cut off switch for the winch. While I doubt I'll use it often, or ever, I've had it laying around for a few years and it actually works out perfectly since the winch is going to be ran on a separate circuit from the truck. I was actually able to reuse some of the 4/0 gauge wire that I had on the truck previously for this circuit with minimal amp/voltage drop from the battery to the winch.
    With all that ran, I made a quick little harness for the lights on the front of the truck, wired up the winch, and started cleaning up wires. Also had to replumb the front locker since I moved the ARB compressor as well to the box.
    [​IMG]PXL_20230606_043815008 by Cory Bechtold, on Flickr
    PXL_20230606_040924944
    If anyone is interested, the loom I'm using is off of Amazon. It's made by Alex Tech. Looks a ton better than the old wire loom I had under the truck. I used a variety of sizes and mix between their braided expandable loom and their split sleeve loom. Anyways, back to wiring.
    I ended up having a little bit more time while I was still waiting on parts for the steering, so I also ran the wires for the 12v socket and usb outlets and a future HAM radio through another grommet I found on the passenger side of the truck. This side was going great until I realize that there's basically nowhere to zip tie the cables too. Eventually landed on just wire loom clamp and bolting it to the underside the truck to keep the cables out of the way. Yes, I put a little bit of seam sealer on the threads before I finalized install. Ideally, I wanted to put the whole harness harness on the frame, but I'd need to order up some weld on zip tie brackets and I don't have time to wait for that unfortunately.
    PXL_20230616_014817194
    And that just about wraps up the majority of the wiring. Like I originally said, I still have a few things I'm going to get done at a later date, but I'm pretty happy with how everything turned out this go around. While definitely not the last time I'll dig into rewiring this truck, I'm willing to bet this will probably stay in the truck for the longest period of time.
    Here's what the battery box ended up looking like. It's a little tight with everything now wired and installed, but it's cleaner than what I had before.
    PXL_20230616_022759414
    I still have a little more cleaning to do as well as I'd like to label everything eventually to satisfy my OCD.
    Also here's the end result in the cab with the Switch Pros and the HAM radio head unit.
    PXL_20230617_020005209
    PXL_20230617_015703931
    Not half bad if I don't say so myself. Now to wrap up the steering this weekend and stop wrenching on this truck all the damn time.
  7. Jun 17, 2023 at 5:16 AM
    #2947
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Dude this looks sick. Definitely makes me think about dual batteries for the future. But one thing, why didn’t you consider just using a normal truck tool box? You’re already losing the space with this little box, why not just upgrade to the bigger one?
  8. Jun 17, 2023 at 6:37 AM
    #2948
    cbechtold
    Cory
    Pleasanton, CA
    I did consider that, but I'm trying to keep space loss at a minimum. If I wasn't planning on linking the truck at some point down the road, then yes, bigger tool box would be sweet!
    BYJOSHCOOK[QUOTED] likes this.
  9. Jul 11, 2023 at 9:23 PM
    #2949
    cbechtold
    Cory
    Pleasanton, CA
    Time for another update before I start beating on the old girl this Summer. Got some fun trips coming up that I'm excited about especially after no wheeling or camping last year. She's pretty much wrapped up at this point with a few small projects that I'll work at a later time. More wheeling, less wrenching Cory!
    PXL_20230625_004212410
    I start off with where I left off with the steering.
    PXL_20230618_181502103
    Out with the old, in with new new. Most likely the original steering rack, so a new one will be nice.
    PXL_20230619_033722236
    Along with a new rack, I also added a 333 Fabrication billet rack clamp. Super tight fitment on this, so hopefully this helps keep the rack in place better the stock one.
    PXL_20230618_222452345
    PXL_20230624_213350075
    Also added a Derale cooler for the power steering. Factory steering setup never had one, so I figured it wouldn't hurt to add one for some better longevity on the power steering fluid.
    PXL_20230624_213045051
    Steering setup is pretty legit now and I'm pretty happy with it. Been driving it for a little bit and it's feels great so far. Now only time will tell if the rack and the mounts can keep up.
    PXL_20230628_025442135~2
    PXL_20230628_025520447~2
    Ditched the swingout and lowered the rear suspension about an inch as well to level out the truck more. Flexed out the truck as much as I could and thinks clear great fortunately. Handling is so much better without the swingout!
    PXL_20230706_161905312
    Took the truck to Stellarbuilt to get aligned. Truck drives better than she ever has. Hopefully it'll last for a little bit before I need to get another one haha!
    PXL_20230709_222321389
    Lastly, a new carrier bearing was a must! I was getting so tired of the vibrations being so random on the freeway. Little disappointed that the last one only lasted just around 3.5k miles since the driveline was rebuilt.
    Now, enough wrenching for now. I'll be doing hoodrat shit with the buds this weekend! :drunk:
  10. Jul 11, 2023 at 10:20 PM
    #2950
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
  11. Jul 12, 2023 at 3:16 PM
    #2951
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    :bikewhoops:See ya there
    cbechtold[OP] likes this.
  12. Jul 12, 2023 at 7:43 PM
    #2952
    cbechtold
    Cory
    Pleasanton, CA
    :headbang: Yeah buddy!
  13. Jul 13, 2023 at 1:56 PM
    #2953
    waldeeeeen
    waldeeeeen Well-Known Member
    Walden
    Mosquito CA
    01 Tacoma 4x4 SR5 TRD 5sp
    I haven't followed your rig in a year or two.... I had a lot of reading to get caught up on. I'm pretty jealous of how nice this project is turning out. Once @Fernando gets his truck back and my daily has a motor in it again I definitely want to wheel with you guys again.
    I am curious though, my truck lives with a dual swingout, 5g fuel, 35 spare and camper and I'm about to run fernies old expedition leafs because the dakars with aal sit perfect empty but with the even 100lbs in the bed they sag. How come you decided to go the leaf spring route you did an no spare? I am constantly filling the bed and camper roof rack with things. I can't imagine not having all the storage.
    Fernando and cbechtold[OP] like this.
  14. Jul 13, 2023 at 10:41 PM
    #2954
    cbechtold
    Cory
    Pleasanton, CA
    I'm definitely down for some wheeling. Got a couple trips coming up in August and a big one in November, but I can definitely get some more in whenever I can fit it!
    The OME Dakars are okay. They were better when this truck was on mid travel, but now with LT, they struggle in a lot of the go fast stuff I'd like to do. They don't provide the up travel I want, but they're good enough to rock crawl and do some go fast stuff. I actually didn't want to go the leaf spring route to begin with when I did the rebuild last year. I actually was planning on selling off all the stuff I bought for the rear and buying coilovers and 4 linking the rear, but when I went to look for coilovers they were either on a year long back order, or silly expensive on the marketplaces. That being said, I am in complete agreement with the fact they are amazing when there's no weight in the bed, but they sag almost the first 100/150 pounds of loading stuff into the bed.
    As a bit of an elude for a future project, I recently got a set of a coilovers for the rear, but I looked for almost a year before finally seeing PolyPerformance get the coilovers I wanted. Apparently when PolyPerformance got them in, it was the first batch of 2.5x16 Fox's that they've gotten with DSCs in quite awhile.
    As for the spare situation, I have a full size spare in the bed at all times. I just prefer having the peace of mine there more than anything really. Space is definitely a luxury at this point with the dual batteries in the bed and the spare back there. I still manage to make it work, but packing for one and being fairly minimalist helps a ton. King of the Hammers is the one trips a year where a week or more in the desert definitely makes me with I had a little more space in the bed, but I'll make it work once I unload the majority of my stuff at camp.
  15. Jul 13, 2023 at 11:04 PM
    #2955
    waldeeeeen
    Walden
    Mosquito CA
    I might actually be able to swing between Nov 5 and 15. I have 11 day off stretch
    I'm actually super stoked on your build because in lieu of the rclt and mar-rack I haven't seen much for our trucks and the clamshell and steering make me nervous to go your route so I'm intrigued. Particularly since it sounds like you have a lot of exposure to sas.
    My jaw did drop when I saw how much the tc lbj steering costs lol But for now my truck is a mid travel camping rig and i plan to copy @betterbuckleup 's triple set dual case set up and eventually dive into all this electrical nonsense you guys are on about but man it looks overwhelming. Wife and kiddo take a lot of money though so it's a slowwwwwww process
    You gonna do a traditional 3 or 4 link or trailing arm 4 link?
    betterbuckleup likes this.
  16. Jul 13, 2023 at 11:37 PM
    #2956
    cbechtold
    Cory
    Pleasanton, CA
    I'll be at Sand Hollow from the 8th thru the 13th for Best of the West. Going to be a fun and rowdy event from the sounds of it.
    Well there's a few things in the works that I'm not really allowed to talk about for these truck, but beefier parts and more robust setups are a hint. The diff, intermediate shaft, and the steering rack are the tough weak points to address. I feel like I have a good solution, but it's a lot of custom work unfortunately. Once the company releases more information about it, I'll probably just let them talk about it.
    Yeah. The Total Chaos LBCs are silly expensive, but it's one step closer in the right direction for me. Steering wise, likely the get the best performance to reliability ratio, I'm going to have to ditch the factory steering rack for a swing set steering setup with a Saginaw steering box and hydro assist. Still I'd have to do a lot of R&D as well as draw it up in CAD before anything since it's so involved and a bit of a PITA.
    Ian has a well setup rig. If my plan was to SAS it and call it done later, I'd definitely be looking at a build more similar to Ian's. 35s with mid travel, dual cases and lockers is all I'd really need until it gets to buggy lines or tougher trails.
    Plan for the rear suspension is likely going to be a 3 link. I'd love to relocate the gas tank and do a double triangulated 4 link, but it's more work than worth for a street driven rig.
    JTFisherman and betterbuckleup like this.
  17. Jul 14, 2023 at 12:03 PM
    #2957
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    You pretty much pack like a backpacker so you really don't need much space.
  18. Jul 14, 2023 at 3:22 PM
    #2958
    cbechtold
    Cory
    Pleasanton, CA
    Yep. That's my thought as well. Well I try to keep packing minimal where I can. Just need to find another alternative for a trasharoo on the truck since no more swing out.
  19. Jul 14, 2023 at 3:48 PM
    #2959
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Trasheroo in the bed. Problem solved.
    Nice to see you about to enjoy all the labor you put into it. Lo/Lo dual locked is quite capable. You still on 35's or did you bump it to 37's?
    cbechtold[QUOTED][OP] likes this.
  20. Jul 14, 2023 at 4:06 PM
    #2960
    cbechtold
    Cory
    Pleasanton, CA
    That's a thought. There's also a tailgate specific trash bag that looks neat, but I'm not set on anything just yet.
    Still on 35s, but 37s are still the goal. Just going to figure out the weak points and build from there. Linking the rear and a Ford 9" are bound to be next once I work out all the kinks from the front end.
