cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Jul 17, 2023 at 4:02 PM
    #2981
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    they do usually have a rate nuts tho... for position sensitive rate change
    rate deez nutz?
  2. Jul 17, 2023 at 6:50 PM
    #2982
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    I definitely plan to mess around with the rear valving eventually. See if I can make the Dakars work for the time being. I'd have to check again, but I think they're stamped with 40/60 valving currently. Likely I'd just start with 30/90 as most do, but I'll need to pull them apart to confirm valving as I got them 2nd hand.
    Yep. Definitely recommend some custom Deavers or Alcans if it's in the budget. F67s would be rad as well, but that's little more involved than what most want to do.
    DashMaple[QUOTED] likes this.
  3. Jul 17, 2023 at 7:50 PM
    #2983
    cbechtold
    Cory
    Pleasanton, CA
    Great weekend in the woods with the buds. Fordyce is a little bit tougher of a trail than I was planning on for a break in run before the Rubicon, but I'm super stoked with how the truck did this weekend. Still a few bugs to work out with the front end, but I've got some time between now and when I hit the Rubicon. Didn't take a bunch of photos this trip. Just enjoyed wheeling and having some great company.
    IMG_7630
    by Cory Bechtold, on Flickr
    IMG_7640
    IMG_7653
    IMG_7658
    IMG_7659
    IMG_7671
    RoaminRoman, jubei, DashMaple and 6 others like this.
  4. Jul 17, 2023 at 8:16 PM
    #2984
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    What rear shocks do you have? Good time to pick up a few shock tools and a nitrogen bottle to start playing with shim stacks if you’re playing in the go fast stuff and have rebuildable/tunable shocks.
  5. Jul 17, 2023 at 8:19 PM
    #2985
    cbechtold
    Cory
    Pleasanton, CA
    They are some old school Fox 2.0x12 piggybacks. My has a nitrogen tank and a handful of the tools I'd need to work on them. I'd just need to get some shock oil and shim and I can start working on them.
    Snowy[QUOTED] likes this.
  6. Jul 18, 2023 at 11:30 AM
    #2986
    JTFisherman
    JTFisherman Well-Known Member
    Jake
    Texas / Missouri
    4Runner
    https://www.suspensiondirect.com/shop/shim-parts
    Shims are a lot cheaper here than from Fox.
    Also pretty sure Fox red jm-92 and Bilstein oil is all F&L Ultra Extreme. Still seems expensive for me to play with having no idea how to re-shim shocks but you can save some buying 5gal.
  7. Jul 18, 2023 at 9:00 PM
    #2987
    cbechtold
    Cory
    Pleasanton, CA
    Oh sweet! Thanks! I'll definitely look into that site later when I get around to messing with the valving. I'll probably just buy the fox branded oil off Accutune and call it a day if my dad doesn't have any laying around.
    JTFisherman[QUOTED] likes this.
  8. Aug 13, 2023 at 1:24 PM
    #2988
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Actually goals dude. Such a sick looking rig
    cbechtold[QUOTED][OP] likes this.
  9. Aug 13, 2023 at 10:50 PM
    #2989
    cbechtold
    Cory
    Pleasanton, CA
    Thanks man! I'm pretty stoked with how she's working right now. Still "relatively" daily driver friendly and she eats almost everything I throw at her off road.
  10. Aug 14, 2023 at 6:49 AM
    #2990
    cynicalrider
    cynicalrider #NFG
    Jersey
    Is Fordyce easier than the Rubicon? I have goals to hit both in 2027 for a big trip out there and want to make sure I pack in the best trails the area has.
  11. Aug 14, 2023 at 7:02 AM
    #2991
    cbechtold
    Cory
    Pleasanton, CA
    It's harder. I feel like most obstacles would be doable without body damage or breaking outside of winch hill 1. Rubicon isn't that bad. Little Sluice is rough, but there is a bypass there. Big Sluice is pretty tough to go up, but if you're planning on going from Loon to Tahoma, then gravity is on your side. You're truck is also narrow enough that you should be able to just squeeze through obstacles.
    TacoEspecial likes this.
  12. Aug 14, 2023 at 7:12 AM
    #2992
    cynicalrider
    cynicalrider #NFG
    Jersey
    Okay good, yeah I heard the Rubicon isn't what it used to be and that Fordyce is hard, so I am excited to give them both a go. I don't want to drive 40+ hours and take off three weeks of work to not be challenged. :rofl:
    jubei likes this.
  13. Aug 14, 2023 at 7:19 AM
    #2993
    cbechtold
    Cory
    Pleasanton, CA
    Oh yeah! It'll be fun! Definitely let me know when you head over. I'm down for a rip through the 'con with ya!
    jubei and cynicalrider[QUOTED] like this.
  14. Aug 14, 2023 at 7:27 AM
    #2994
    cynicalrider
    cynicalrider #NFG
    Jersey
    Awesome! Will def let you know. Going to try to plan it for right after Sierra Trek to take advantage of the lowered levels. Anything else you recommend in the area? Going to try to make this trip Cali focused since going all the way out there is likely a one time deal at least until we potentially move closer.
    jubei likes this.
  15. Aug 14, 2023 at 7:43 AM
    #2995
    cbechtold
    Cory
    Pleasanton, CA
    Slick Rock, Deer Valley, Niagara Rim, Hell Hole, Snake Lake. If you feel like going a little South, there are a bunch of trails in the Shaver Lake area.
  16. Aug 14, 2023 at 11:18 AM
    #2996
    cbechtold
    Cory
    Pleasanton, CA
    Speaking of Rubicon, Rubicon was a big success this past weekend. Ended up going on the Tacos on the Rubicon run with Nick from Martec Engineering and George from Unleashed 4x4. Bunch of awesome built Tacomas, pretty much all of them on one tons and 40s. Definitely felt a little outclassed since myself and one other were on the smallest tires of the group as well as being one of the 3 only IFS rigs to join up. Day 1 was rough. We had a pretty big recovery task on an FJ Cruiser that broke both lower rear links, rear driveshaft, and an inner tie rod. Fortunately he was able to get back on the road from what I last heard.
    IMG_7693
    IMG_7677
    IMG_7683
    IMG_7678
    IMG_7686
    IMG_7680
    IMG_7688
    IMG_7690
    IMG_7694
    IMG_7696
    IMG_7698
    IMG_7700
    IMG_7702
    Overall though, I couldn't be happier with how the truck performed. It's wild how capable this truck is now especially since I wasn't really playing catchup too often with the rest of the group. She's able to kind of keep up which was absolutely impressing the hell out of me. It's trips like this where I absolutely love this truck and what is can do! Not a lot of photos, but a lot of memories and fun. Already can't wait to be back in a few weeks!
  17. Aug 14, 2023 at 12:14 PM
    #2997
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    your truck is looking good Cory! that trip looked like fun with a good group.
    But damn, seeing those SAS'd 2nd gens on 40s is quite tempting. Would be so much more affordable if I could do the work myself but I'm no where near capable.
  18. Aug 14, 2023 at 12:18 PM
    #2998
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Dusy Ershim. If you're ticking off bucket list trails in California, you can't miss it.
  19. Aug 14, 2023 at 12:33 PM
    #2999
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    That's a fun obstacle in that first pic. Good spot to get super crossed up
  20. Aug 14, 2023 at 1:38 PM
    #3000
    cbechtold
    Cory
    Pleasanton, CA
    Thanks man! I'm super happy with how things are working right now.
    Yeah, all the build 2nd gens are rad. Martec makes a pretty rad kit that would work for your truck. Definitely would look at that if you want to look into SAS one day.
    Definitely one of my favorite spots. I really only went down that way since still to this day, one of my favorite pictures I ever took on that trail is right there.
    IMG_1725
