cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Aug 15, 2023 at 2:49 PM
    #3001
    MattJakobs
    MattJakobs Everything but a Tacoma
    Matthew
    NorCal
    1985 4Runner w/ FlipPac
  2. Aug 16, 2023 at 10:45 AM
    #3002
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    What edge protector stuff did you use on your cut bedsides? I don't like the stuff I used, it doesn't hold on well.
  3. Aug 16, 2023 at 10:48 AM
    #3003
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
  4. Aug 28, 2023 at 7:42 PM
    #3004
    cbechtold
    Cory
    Pleasanton, CA
  5. Sep 4, 2023 at 6:51 PM
    #3005
    cbechtold
    Cory
    Pleasanton, CA
    Back to a little wrenching and starting to do some needed maintenance on the old girl. Changed out my old seat brackets to some PRP brackets. My old seat brackets were straight up ghetto fab. :anonymous:
    PXL_20230903_183735267
    by Cory Bechtold, on Flickr
    PXL_20230903_200703306
    Also wrapped the hydraulic lines on the coil overs with a protective sleeve. I'm planning on relocating the remote reservoirs, but I want to wait until Winter before I start ripping into the truck for full KoH prep.
    PXL_20230905_004441191
    PXL_20230905_004411262
    Speaking of said KoH Prep.... :anonymous:
  6. Sep 4, 2023 at 6:55 PM
    #3006
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    I love your truck dude :fistbump:
    cbechtold[OP] likes this.
  7. Sep 4, 2023 at 6:57 PM
    #3007
    cbechtold
    Cory
    Pleasanton, CA
    Thanks man!
  8. Sep 4, 2023 at 7:17 PM
    #3008
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    3 link?
  9. Sep 4, 2023 at 7:17 PM
    #3009
    cbechtold
    Cory
    Pleasanton, CA
    Yep
  10. Sep 4, 2023 at 7:35 PM
    #3010
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    and then sas? :stirthepot:
  11. Sep 4, 2023 at 7:41 PM
    #3011
    cbechtold
    Cory
    Pleasanton, CA
    One day, but SAS is pretty far down the road right now. I'm really enjoying the IFS right now. The front end just flat out works beyond my every expectation. I'm just trying to have the rear keep up now so I can do both the go fast stuff and crawling.
  12. Sep 4, 2023 at 8:51 PM
    #3012
    v5ensx
    v5ensx CARB legal is not CALI legal
    LT front and 3 link rear :headbang:
    TacoEspecial and cbechtold[OP] like this.
  13. Sep 4, 2023 at 8:58 PM
    #3013
    cbechtold
    Cory
    Pleasanton, CA
    She's going to boogie! :headbang:
    TacoEspecial likes this.
  14. Sep 4, 2023 at 9:09 PM
    #3014
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'll be curious to see how things compare when you have more travel in the rear. I think the biggest benefit to SAS at this point would be being able to run a larger tire and not have to have the cv / 7.5 front concerns.
  15. Sep 4, 2023 at 10:11 PM
    #3015
    cbechtold
    Cory
    Pleasanton, CA
    13" front and aiming for 16/17" rear. Should perform a little better in the rocks (no more constant riding on bump stops), but it's going to wild to see the difference when I pickup the speed!
    I think I could get performance similar in the desert, but the rocks would be a night and day difference being able to push the truck harder and down more technical obstacles without working about breaking. That being said, SAS would definitely take the fun out of some obstacles that I really like right now.
  16. Sep 5, 2023 at 4:39 AM
    #3016
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Are you planning on trailing arms to get that much travel in back?
  17. Sep 5, 2023 at 7:17 AM
    #3017
    cbechtold
    Cory
    Pleasanton, CA
    Nope. 16" coilovers with a little bit of angle should net me around those travel numbers.
  18. Sep 5, 2023 at 8:01 AM
    #3018
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Interesting. Why not just do trailing arms/4 link and not deal with the shock shaft speed issues, axle swing, and possible driveshaft plunge issues that come with a 3 link on a 1:1 motion ratio setup like that?
  19. Sep 5, 2023 at 8:09 AM
    #3019
    Speedytech7
    4link requires moving the fuel cell and that's a biiiiiig no-no in CA
    otis24 and cbechtold[OP] like this.
  20. Sep 5, 2023 at 8:14 AM
    #3020
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    F150 tank swap, filled through the stock fill door with EVAP provisions plumbed in is pretty well known to pass smog fine unless something has changed that I don't know about in CA.
