cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Dec 28, 2024 at 5:11 AM
    #3121
    cynicalrider
    cynicalrider #NFG
    Jersey
    The only thing I can think might negatively affect the crawling is dragging the rear links.
  2. Dec 28, 2024 at 6:14 AM
    #3122
    02hilux
    Planet: EARTH
    He will be riding on his trailing arm. My lower links became the anchor, even with 40s. You tend to do smart things and be braver when the suspensions cycle well. o_O
    :anonymous:
    cbechtold[OP] likes this.
  3. Dec 28, 2024 at 6:15 PM
    #3123
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Thanks dude! I'm stoked on it. Not in my possession, but I had a couple junkyards local that I could have had.
    Yep. It'll be a learning curve, but it's for the better
    02hilux[QUOTED] likes this.
  4. Dec 29, 2024 at 6:45 AM
    #3124
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    @cbechtold exactly.. trying to get this new toy sorted out. Would be a fun night time shenanigans rig.
  5. Dec 29, 2024 at 6:54 AM
    #3125
    cbechtold
    Cory
    Pleasanton, CA
    Hell yeah brother! Get 'er done!
    XPOTRPR[QUOTED] likes this.
  6. Dec 29, 2024 at 9:48 AM
    #3126
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Gah damn Cory! Truck is looking damn good! Can’t wait to see some wheeling in action with this thing! :hearteyes:
    cbechtold[QUOTED][OP] likes this.
  7. Dec 29, 2024 at 4:25 PM
    #3127
    cbechtold
    Cory
    Pleasanton, CA
    Thanks Josh! Working on that! Finishing up the not so fun stuff/maintenance today. Starting on new sliders tomorrow.
    BYJOSHCOOK[QUOTED] likes this.
  8. Jan 4, 2025 at 5:36 AM
    #3128
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    its ok, we’re trading trucks anyway
    Heehee! Jk
  9. Jan 19, 2025 at 10:17 PM
    #3129
    cbechtold
    Cory
    Pleasanton, CA
    Time to get this thread a little more up to date before I take off and spend 10 days in Hammertown. I've basically just been working on a list of things to do that needed to happen prior to Hammers! Still a few things to take care of before leaving as I'm writing this, but it's a manageable list of stuff at this point.
    Starting from the beginning, new diff breather was needed badly. I originally used an OE Toyota breather, but I already knew that wasn't going to last.
    PXL_20241229_233234546
    by Cory Bechtold, on Flickr
    Ended up putting some 3D printed caps on the cross support for the shock towers. They kept filling up with water, so this is an easy fix.
    PXL_20241229_235026432
    Trimmed the fenders even more. I'm at the point where I've taken 6 inches out of the bedsides. Full bump was basically just touching the fenders. Once articulated, it wasn't going to cut it anymore. Also tried a different fender cut that I'm liking a lot more than the standard round cut everyone does on these truck. I'll be doing the same cut on the front fenders once I get a new pair of front fenders.
    PXL_20241230_032831994
    PXL_20241230_035927805
    PXL_20241230_172836692
    PXL_20241230_180443657
    Learned of a new issue I never thought I'd have, tires are getting into the wheel wells in the bed. I have an idea on how I'm going to tackle that, but that's something I'll have to do some cad work first before I cut the bed up.
    PXL_20241230_180955615
    Managed to keep the gas filler neck in the stock location for now. That'll change later and I'll finish the cut on the driver side later once I relocate that again.
    PXL_20241230_181002484
    PXL_20241230_181049940
    Also cut the bedsides for a high clearance rear bumper. Clearance for days now!
    PXL_20241230_235212946
    Swapped the front wheel studs out to 1/2-20 studs to match the rear unit bearings. Easy swap. Got the tip from the guys at Sherpa Motorsports.
    PXL_20241231_002323992
    Lastly, swapped out the dying alternator for another Sukuzi alternator.
    PXL_20250104_040549217
    Glueman, malburg114, rob1208 and 4 others like this.
  10. Jan 19, 2025 at 10:23 PM
    #3130
    cbechtold
    Cory
    Pleasanton, CA
    Spends the last 2 weekends building a new rear bumper. Super stoked on how this came out. Tried out a different approach compared to what is normally done with just the single piece of round tube the whole way around.
    PXL_20250120_032505184
    PXL_20250120_032558352
    PXL_20250120_032716541
    PXL_20250120_032737695
    PXL_20250120_032751310
    For those who want more detailed photos and the build of the rear bumper, here's the link to the Flickr album.
    https://flic.kr/s/aHBqjBPQPw
  11. Jan 20, 2025 at 6:46 AM
    #3131
    dzuf
    dzuf Well-Known Member
    Darcy
    British Columbia, Canada
    Somehow I’ve never came across this build thread. Got some catching up to do!
  12. Jan 20, 2025 at 8:32 AM
    #3132
    Crunchytaco69
    Crunchytaco69 Active Member
    Cam
    Tacoma on tons
    Won Tons
    are you worried about the frame at all where the panhard bracket meets the frame? I was curious why Nick didn't plate that portion [​IMG]
    malburg114 likes this.
  13. Jan 20, 2025 at 11:27 AM
    #3133
    cbechtold
    Cory
    Pleasanton, CA
    Nope. Between the majority of the frame that was plated where the panhard is tied into and the cross support to the otherside of the frame, I'm not worried about it. Nick has heard of zero issues from his customer's rigs running his kits.
    Crunchytaco69[QUOTED] likes this.
  14. Jan 20, 2025 at 11:36 AM
    #3134
    Crunchytaco69
    Cam
    Tacoma on tons
    Won Tons
    gotcha, well thats good to hear. That rear bumper turned out super clean!
  15. Jan 20, 2025 at 4:39 PM
    #3135
    cbechtold
    Cory
    Pleasanton, CA
    Thanks man! I'm super stoked on it. Are you making it out to Hammers this year?
  16. Jan 21, 2025 at 7:12 AM
    #3136
    cynicalrider
    cynicalrider #NFG
    Jersey
    You can see the external plating here for essentially the entire bracket too.
    [​IMG]CMB17754 by Cory Bechtold, on Flickr
  17. Jan 21, 2025 at 8:15 AM
    #3137
    Crunchytaco69
    Cam
    Tacoma on tons
    Won Tons
    nah Im not gonna be out there its to busy for me. I like to go when no one is there and the trails are open
  18. Jan 21, 2025 at 9:11 AM
    #3138
    cynicalrider
    cynicalrider #NFG
    Jersey
    I was digging through the build pics and just realized that you essentially built the bumper off the frame. Any concern about it not being removable for anything in the future? I know you guys don't really deal with rust out there.
  19. Jan 21, 2025 at 3:17 PM
    #3139
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    that bich is hot!
  20. Jan 21, 2025 at 9:06 PM
    #3140
    cbechtold
    Cory
    Pleasanton, CA
    Damn. I'll have to catch you out there one of these days.
    Nope. She's plated and welded directly to the frame. The rear bumper rarely came off as is before. I figured if I'm pulling this one of, it's to build a new one.
    Thanks Ferny!
    cynicalrider[QUOTED] likes this.
