cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Jan 29, 2025 at 11:23 AM
    #3141
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Not sure if I'm going crazy or not... I swear I thought I saw this info but going back thru I could not find it :(
    They covered the length on the links, but what's the coilover/spring setup? and the final wheel travel?
    And if you know the anti-squat at ride height?
    Truck is looking wicked!
    cbechtold[QUOTED][OP] likes this.
  2. Jan 29, 2025 at 10:04 PM
    #3142
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Thanks man! Here's the quick and dirty run down. 2.5x14" Fox Internal Bypass Coilovers with Piggyback Reservoirs with a 14" 175# over 16" 250# springs to start. Overall wheel travel is right around 17.5" strapped and bumped. Anti-squat should be right around 90%.
    Bandido[QUOTED] likes this.
  3. Jan 30, 2025 at 5:43 AM
    #3143
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Thanks man!! Trying to finalize my own DIY setup and this confirms I'm right on (or at least very close) with Coil spring selection!
    I'm Hoping you are only running 1"-1.5" Preload with the empty bed setup?
  4. Jan 30, 2025 at 8:58 PM
    #3144
    cbechtold
    Cory
    Pleasanton, CA
    My spring rates are about 2 1/2" of preload at ride height, but for trailing arms, a 175# upper is likely to light. I'll be messing with spring rates after KOH to help dial in the rear. Like go to a 225# upper to start.
  5. Jan 31, 2025 at 4:25 AM
    #3145
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    That should take you from ~83lbs wheel rate to ~96lbs wheel rate (spring force applied at the wheel)
    My Calculations show ~102lbs wheel rate is a pretty good spot for no pre-load on a lighter rear end(based on my own rr axle load and weight), I'm going to be running ~121lbs with swingout, spare 37" and fuel tank behind the axle.
    are you running a transition nut?
  6. Jan 31, 2025 at 9:13 PM
    #3146
    cbechtold
    Cory
    Pleasanton, CA
    The goal is likely close to 100lbs wheel rate. I do have a transition nut
  7. Jun 17, 2025 at 11:36 AM
    #3147
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    did you end up swapping coils? how's it been riding?
  8. Jun 20, 2025 at 4:16 PM
    #3148
    cbechtold
    Cory
    Pleasanton, CA
    Not quite yet. I'll likely look into it around Winter time when I get to work prepping the truck for KoH. Going to run on it for now and see how it does this Summer.
    otis24 and Bandido[QUOTED] like this.
