cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Dec 27, 2014 at 7:10 PM
    #301
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Yupp! Your pics convinced me, semi gloss front and back!
  2. Dec 27, 2014 at 7:13 PM
    #302
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Glad I could help with that then. :D
  3. Dec 27, 2014 at 7:14 PM
    #303
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Haha yes, I hope to have everything painted up by friday!
  4. Dec 27, 2014 at 7:22 PM
    #304
    cbechtold
    Cory
    Pleasanton, CA
    If all goes according to plan with the rear, then I should start painting maybe mid next week. Friday at the latest.
  5. Dec 27, 2014 at 7:23 PM
    #305
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Sweet, got everything planned for the swingout?
  6. Dec 27, 2014 at 7:32 PM
    #306
    cbechtold
    Cory
    Pleasanton, CA
    Ish... I just need materials to be able to build it. The general idea is a tire carrier and dual jerry can holder.
  7. Dec 28, 2014 at 5:04 PM
    #307
    cbechtold
    Cory
    Pleasanton, CA
    Got a whole lot done today. Bumper is pretty much all tacked together. Just a few things need to be tacked/welded on after the whole thing has been welded together.
    Untitled
    by Cory Bechtold, on Flickr
    Untitled
    Untitled
    Untitled
    Untitled
    Going to get some material tomorrow for the swing out and some more gas to make sure that I have enough. Should hopeful get the bumper at least full welded together, for the most part.
    Anyways... More tomorrow.
  8. Dec 28, 2014 at 5:14 PM
    #308
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Looks great! Making quick work of it, making me excited to finish mine lol.
  9. Dec 28, 2014 at 5:36 PM
    #309
    cbechtold
    Cory
    Pleasanton, CA
    Tacking everything in place never really takes that long. Welding everything and grinding the welds smooth will take some time.
  10. Dec 28, 2014 at 5:53 PM
    #310
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Well, quick work compared to me :anonymous:
  11. Dec 28, 2014 at 6:18 PM
    #311
    cbechtold
    Cory
    Pleasanton, CA
    Nothing to be ashamed with how much time you take to build something. Rear bumper also seem to easier to build than the front. Also help that I have the right tools to make the job a bit quicker.
  12. Dec 29, 2014 at 2:44 PM
    #312
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Did your front bumper come with install directions?
  13. Dec 29, 2014 at 2:49 PM
    #313
    cbechtold
    Cory
    Pleasanton, CA
    I ordered the DIY version so mine included how to build and make the whole thing. I would assume that your's should be straightforward. Literally is should say that it's recommended to have 2-3 people to install the bumper and to make sure all bolts are tight, then after a few hundred miles, recheck the bolt to make sure they're tight. If you're don't come with direction, the install should be rather straightforward. I can provide details if needed.
  14. Dec 29, 2014 at 2:52 PM
    #314
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    The part that holds the skid plate on, that U shaped metal peice that had 4 bolts in it, to take it out do you just have to hit it with a hammer to get it to budge loose or is there a bolt im forgetting....
  15. Dec 29, 2014 at 3:27 PM
    #315
    cbechtold
    Cory
    Pleasanton, CA
    Are you talking about the brace that holds on the stock bumper?
  16. Dec 29, 2014 at 3:30 PM
    #316
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Nvm, sorry. Looked at some more of your pics and figured it out!
  17. Dec 29, 2014 at 3:32 PM
    #317
    cbechtold
    Cory
    Pleasanton, CA
    Alrighty then... Since you're talking about you're front bumper, does this mean that your bumper came in? :spy:
  18. Dec 29, 2014 at 3:39 PM
    #318
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Check my build :D
  19. Dec 29, 2014 at 3:41 PM
    #319
    cbechtold
    Cory
    Pleasanton, CA
    Will do... I'm excited!
  20. Dec 29, 2014 at 7:13 PM
    #320
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    For sanding bumper to remove all rust....
    Would you recommend a high grit flap disc? A paint stripping disc? Or a wire wheel? Or any other recommendations?
