cbechtold's Long Travel IFS Crawler Tacoma Build and BS Thread
Discussion in '1st Gen. Builds (1995-2004)' started by cbechtold, May 27, 2014.
  1. Aug 18, 2019 at 7:09 PM
    #1621
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    cheater....
    Made that look TOO easy...
    cbechtold[QUOTED][OP] likes this.
  2. Aug 19, 2019 at 8:40 AM
    #1622
    2BeersPlease
    2BeersPlease Well-Known Member
    Do I spy a Rusty on the left there at the end? @TOP TACO
  3. Aug 19, 2019 at 9:48 AM
    #1623
    cbechtold
    cbechtold [OP] IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Yessir
  4. Aug 19, 2019 at 3:08 PM
    #1624
    cbechtold
    Cory
    Pleasanton, CA
  5. Nov 6, 2019 at 10:49 AM
    #1625
    cbechtold
    Cory
    Pleasanton, CA
    Okay, before I complete forget to update this thread for like who knows how long. I ran Bald Mountain the previous weekend with a crew from TW. The smog and smoke definitely wasn't as thick as it was last year, but definitely nowhere near as clear as when I first ran the trail back in 2017. There was also some pretty good carnage. Fun times nonetheless.
    IMG_5871
    by Cory Bechtold, on Flickr
    IMG_5877
    IMG_5878
    IMG_5880
    IMG_5883
    IMG_5885
    IMG_5887
    IMG_5888
    IMG_5889
    IMG_5897
    IMG_5918
    IMG_5921
    IMG_5926
    IMG_5931
    IMG_5933
    IMG_5934
    IMG_5936
    IMG_5938
    IMG_5939
    IMG_5950
    IMG_5953
    IMG_5956
    IMG_5957
    IMG_5961
    IMG_5965
    IMG_5968
    IMG_5970
    IMG_5973
    IMG_5976
    IMG_5977
    IMG_5979
    IMG_5980
    IMG_5982
    IMG_5997
    IMG_6003
    IMG_6005
    IMG_6006
  6. Nov 6, 2019 at 10:52 AM
    #1626
    cbechtold
    Cory
    Pleasanton, CA
    This past weekend was just me wasting my time pulling my t-case out to find out the leak I have isn't fixable unless I go with a different shifter unit. Oh well. Guess I'll start send it in the meanwhile and put oil in when it's needed. Time to wait until my 4.7 gear lets go and start saving for a 4speed Atlas. :bananadead:
  7. Nov 6, 2019 at 10:57 AM
    #1627
    02hilux
    Planet: EARTH
    Mines leaking from the poorly designed rad base. No matter what I do, it leaks.
  8. Nov 6, 2019 at 11:08 AM
    #1628
    cbechtold
    Cory
    Pleasanton, CA
    Yep, that's my issue. I might swap it out for some FROR twin sticks on the t-case to stop the leak. Don't know yet. It only leaks on long drive, so I might just leave it for awhile.
  9. Nov 6, 2019 at 11:33 AM
    #1629
    02hilux
    Planet: EARTH
    Idk if fror will be any better, lol.
  10. Nov 6, 2019 at 11:36 AM
    #1630
    cbechtold
    Cory
    Pleasanton, CA
    Guess I'm saving for an Atlas :bananadead:
  11. Nov 6, 2019 at 2:13 PM
    #1631
    cynicalrider
    cynicalrider #NFG
    Jersey
    Did that dude's LCA bolt shear or what?
  12. Nov 6, 2019 at 2:23 PM
    #1632
    cbechtold
    Cory
    Pleasanton, CA
    As far as I know, it's just the metal that held the bushing in place that failed. I don't know the whole story. The group I was in took a detour and put is about 30 minutes behind the other group. We arrive with him already pulling everything apart to try and fix it enough so he could limp it to Napa and buy a new LCA.
  13. Dec 2, 2019 at 8:18 AM
    #1633
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    How did you get the clutch/free spool handle like that? Its super difficult to reach otherwise
  14. Dec 2, 2019 at 8:37 AM
    #1634
    cbechtold
    Cory
    Pleasanton, CA
    It was pretty easy. There's 8 allen bolts that you remove on the side of the M8000. After those are out, you pull the housing off enough to be able to rotate the handle. Just be careful to not pull the housing off the gears inside.
    Prayn4surf[QUOTED] likes this.
  15. Dec 2, 2019 at 8:38 AM
    #1635
    Prayn4surf
    Socal
    I was hoping you were going to say that. I started searching through the manuals. I have the 9.5 but Im sure its the same
    :fingerscrossed:
  16. Dec 2, 2019 at 8:42 AM
    #1636
    cbechtold
    Cory
    Pleasanton, CA
    Should be fairly similar from the looks of it.
  17. Dec 2, 2019 at 8:43 AM
    #1637
    Prayn4surf
    Socal
    I see you got to help Shay with his LCA problems haha. He just replaced the other one that was heading to a similar fate a couple weekends ago lol.
  18. Dec 2, 2019 at 8:48 AM
    #1638
    cbechtold
    Cory
    Pleasanton, CA
    Helped would be a strong word. I just stood around saying I could drive into town with him so we could get him a new LCA.
  19. Dec 2, 2019 at 8:51 AM
    #1639
    Prayn4surf
    Socal
    Haha He is very capable. Definitely a good dude to wheel with.
  20. Dec 2, 2019 at 9:38 AM
    #1640
    cbechtold
    Cory
    Pleasanton, CA
    Went out and found snow this weekend. Went from Georgetown to Loon Lake and almost made it too the Rubicon trail head. There's not a ton of the ground right now, 3' of snow is pretty good for the beginning of the season. Got stuck a few times, but I was trying to plow a new road in low low and my tires kept getting packed with snow. Ice House Road ended up being a 25 miles of ice, so that was sketchy as shit since I went sideways a few times. Tons of ill prepared (not aired down) vehicles, but t'was a blast otherwise.
    IMG_6008
    IMG_6026
    IMG_6032
    IMG_6033
    IMG_6035
    IMG_6039
    IMG_6045
    IMG_6048
    IMG_6049
