CBI Offroad, meh at best
Discussion in 'Vendor Reviews' started by corprin, Jul 6, 2015.
  1. Jul 6, 2015 at 9:14 AM
    corprin
    corprin [OP] Well-Known Member
    corprin
    With the '12 Taco being my daily driver, and 'overlander', I want to keep it as stock as possible while it's under warranty and payments are still being made. This lead me to pick up a front receiver hitch so I could run my multi-mount winch. I saw two choices, 4xinnovations and CBI Offroad. Both hitches were within $20 of each other, but CBI came powder coated, so CBI got my money.
    The box arrived and I found that the receiver had been packed poorly, and it punched through the cardboard at both ends and at the receiver tube.
    2731D38F-655F-4A8A-ADAF-F65C53D5EFF4_zps_4a4ec398f114b70813e7359d41b5f00deba99fc9.jpg
    7159F1E5-AB4A-4F6D-986A-D9BB6797F077_zps_a3343e05e290a9d9c452d4a48d72e292dc2e3dc3.jpg
    F76D77C1-D518-4522-9A2C-A36252011F55_zps_eda2d521b334eb17bd27e27b72454e28573a56fb.jpg
    They used a few folds of foam to immobilize a 58lb steel object in a cardboard box.
    92A970EA-5356-4856-9439-1E558A60B887_zps_a8de564aaa2740bab68e23301fa36e53f09db243.jpg
    The powder coating was worn off, negating the reason for going with CBI over 4xinnovations. I sent an email to CBI describing what I found when opening the box, and asking them to contact their powder coater to find out what spray paint was best mated to their coating to prevent long-term corrosion protection for the wore-through areas (yes the type of paint matters).
    I received an email back the next day from an unknown source, as they didn't 'sign' the email. They immediately blamed the shipper (FedEx) and suggested I contact FedEx to file a claim to "pay for recoating the part." No acceptance for responsibility, no care for the customer, and no information from the powder coater regarding the type of paint to use.... just them passing the buck. I responded in kind.
    The following day I received an apologetic from the owner of CBI explaining that the packing process was revised. Whether it has or not is to be seen by other customers, but I hope it has. I thought all was good... then I started to install.
  2. Jul 6, 2015 at 9:14 AM
    corprin
    corprin
    CBI has some amazing installation instructions on their website..
    Having just north of average mechanical ability, I decided to go at it blind. There are a few how-to's out there, but most link to other how-to's for each step of the process... which seemed easy enough. Remove bumper, remove crash beam and crush cans, and bolt on receiver... right?
    Grill, bumper, bumper beams, and crush cans, came off in about 10min. Hauled the part over to the truck and noticed that the lower frame was a bit too wide for the receiver to mount. Discovered the little extendo-frame blocks, now the receiver could slide onto the studs.
    This is where I started to run into issues. The outboard four studs didn't line up with the holes in the receiver, causing the lower flange to be out of alignment with the bottom of the chassis.
    54A30978-F599-4D67-BD5B-7489E273D360_zps_d8125b6ca506476f7d19c6d2859914af4e13672a.jpg
    C0E382E2-C57D-485C-8CB2-F5D4E7B8AD41_zps_7227c41e85e45d513e51a07b3ca76dab070a3ce0.jpg
    342CA5C2-BCEE-4117-84D2-E49CAE2FB122_zps_5db34d53b549c87d0dba61364e4d2158d04b77f3.jpg
    BAFD26EB-2C57-459F-8460-4A0E174871F7_zps_392af44f35fc8f76795133cd13fc5710ff05c495.jpg
    The holes required about 1/8" of dremel work to open the holes up to get the bottom flange to fit flush.
    8ADCA6AD-F768-4760-8EB1-5A2C30CBDD1A_zps_76509340e972fe6103223bed88513b6727162409.jpg
    I hosed the area with some primer to keep things wet and soft, so I could see the engagement of the nut when torqued into place. As you can see, more than half of the nut's face now doesn't contact any material. I was not comfortable with this engagement, so I started brain storming over a beer.
    My solution was to hack the flanges off the crash cans to use as a washer plate. This would distribute the load and allow me to actually winch off the receiver.
    F5675D4A-D937-4C56-9F64-48B1E6908891_zps_a25c471796503f50e8ed5521bb4ccba38e519fcc.jpg
    Once I started to bolt the receiver in place, I found that one of the flanges had been bent in the shipping incident, or warped during welding.
    EC537D31-3095-4E44-A91B-5A35E907B1F4_zps_e2766d7e3cbe572e64b093113a0b035908010e1b.jpg
    Either way, 30sec with Old Blue (4lb sledge), the bend was corrected.
    3EA5BE7C-ACEC-4D08-A44B-28442F2808CF_zps_e50224377e5337d341030fed9fcc85b5139e0fca.jpg
    Receiver was removed, cleaned up, painted nicely, and reinstalled.
  3. Jul 6, 2015 at 10:30 AM
    corprin
    corprin
    Now there is the matter of the hinged license plate bracket. From the looks of the alignment of the holes, it will require the hinge to be mounted under the opening where the receiver pokes through. Since my truck had a plate mounted from the dealer, this would leave two unsightly holes in the bumper face. This left an option of having the hinge mounted to the face, but more than half would be exposed, again an unsightly addition to my silver bumper.
    To hide a majority of the hinge I would need the hinge to be folded on itself, but this left the mounting bolts/screws impacting each other preventing the hinge from folding flat.
    8E7F9BEE-16EE-4CAB-A695-22BA6BF2E19B_zps_4eb19ea5e20ab82884e9209f617ff3288cb9b1d8.jpg
    I punched two extra holes outboard of the provided and marked and installed the bolts to clear each other.
    78F344F3-53E0-4426-815F-67D0ACAA7206_zps_9b53ff35c5211c5939a63a85b2e85d47fbe00740.jpg
    the plate bolts slip into the stock holes, which holds the plate flat on the bumper and looks fairly stock.. with only a wee bit of the hinge showing.
    67309268-E1F9-4630-BD62-8D934983F9A7_zps_037cad8d0296fb09c5a5b83e5e8435802191f898.jpg
    Chipskip likes this.
  4. Jul 6, 2015 at 10:39 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    You took that hit better than I would. I would have sent it back. Now that it's modded you own any future problems which might arise.
    Good luck.
  5. Jul 6, 2015 at 10:40 AM
    corprin
    corprin
    With all being said, the CBI receiver is a sturdy part, but FAR from flaw. With my past experiences with 4xinnovation's products, I wish I would have gone with their part in the first place. Shame on me, and lesson learned.
    I will be hesitant of ordering another part from CBI.
    This part was needed on the truck by the end of this week, and with their established lack of customer service, I wasn't willing to argue nor eat any shipping.
    Honestly I can deal with any future issues. I have everything needed to fab the receiver, and much more, in the shop. At $300 it's not worth my time to do it myself. So, I can handle any issues that may arise later, and if CBI is unwilling to work with any warranty or other issues, it would only solidify my thoughts regarding their lack of customer care after the sale is finalized.
    jmaack[QUOTED] likes this.
  6. Mar 22, 2016 at 12:10 AM
    comatosed
    comatosed Well-Known Member
    Central Florida
    Silver TRD Sport
    TRD roof rack, Roof Basket, Weather Tech liners, Wet Okole seat covers, bed mat, AFE Pro Dry Filter, Eclipse AVN726E dvd/nav, kicker door speakers, 8" kicker sub & amp, fox 2.0 coil overs, moab 2.0 front bumper, Full CBI Skid Set, CBI Offroad rear Bumper, CBI Sliders, BFG AT KO 2, Leer Topper setup for camping. Other mods-full synthetic, carbon filter, de-badged, center console lock.
    I would have to agree with this poster. I've spent 4 grand with this company and can't seem to get instructions, or much help after the fact...Improperly installed armor is not safe, nor is it any sort of upgrade over correctly installed stock parts.
    Centeno707 likes this.
  7. May 24, 2016 at 11:02 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No customer complaint should be handled through email unless that's the only method of contact.
    If you have a problem, call them on the phone!
  8. May 24, 2016 at 11:04 AM
    T4RFTMFW
    Email isn't reliable.
    Talk to a human.
    scottalot likes this.
  9. May 24, 2016 at 11:11 AM
    T4RFTMFW
    Lack of proper communication falls on both ends, then.
    Good luck.
  10. May 24, 2016 at 11:23 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I kind of agree that an email is a perfectly adequate means of communication. It also gives you a paper trail in case you need to bring up something that was said. Phone call proof turns in to he said she said or "I never said that". While its easy to get a quick answer over a phone call, some people will just tell you what you want to hear, whereas if they do that via email and then fail to comply, you've got solid proof of it.
    Hoonatic, Large, Stig and 3 others like this.
  11. May 24, 2016 at 11:23 AM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Email provides evidence when filing a claim or arguing with a company. This is not the best advice. Always email or pm. Call as a last resort unless you get permission to record the call.
    Anybody can say a ton of shit over the phone then turn around and say they never said it. No proof.
  12. May 24, 2016 at 11:24 AM
    VolcomTacoma
    Jeff
    NorCal
    I just said that. Jeez.
  13. May 24, 2016 at 11:24 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    I agree that a human call is necessary sometimes, especial when quick action is required. I think you should expect a response within 48 hrs (not including weekends) from any company. Email allows you to get the response "in writing" so that no confusion about what is promised or agreed upon can occur later. It also gives a company a chance to investigate before responding. If email fails, a call is required.
    OP, you handled this situation well.
    I have bought somethings from CBI, no issues and no need to reach out to CS.
  14. May 24, 2016 at 11:24 AM
    VolcomTacoma
    Jeff
    NorCal
  15. May 24, 2016 at 11:25 AM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Didn't show up til I refreshed the page
  16. May 24, 2016 at 11:26 AM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    Great minds think alike....
    SixthSnail likes this.
  17. May 24, 2016 at 11:36 AM
    T4RFTMFW
    A phone call with a verbal request to reply to an email still accomplishes the key things, and that's some kind of contact with CBI and a continued history of written communication, and at a faster rate than no replies in 2 weeks.
  18. May 24, 2016 at 11:48 AM
    VolcomTacoma
    Jeff
    NorCal
    And then when you get no email and call back and they say they have no record of you calling before or asking for an email? Come on now.
    OP, bottom line here is that you ordered a custom part from a small fabrication company, you didnt pursue any claims through Fedex and there was no implied warranty AFAIK. Then when the part was obviously poorly constructed (shit wasnt lining up) you modified it to fit instead of returning it.
    I get that this is more of a review than a request for restitution, but yeah, hopefully someone else learns from this before buying from them.
    Still surprised @CBI Offroad Fab hasn't jumped in yet to say anything
  19. May 24, 2016 at 11:51 AM
    Centeno707
    Centeno707 1st Gen. Tacoma Owner
    Cody
    Arcata, CA
    2003 Extra Cab TRD 3.4 Auto 4x4
    16x8 Raceline Assault Rims K&N Cold Air Intake Flowmaster Super 44 Exhaust Spyder euro style smoked headlights Spyder Smoked Tail Lights & 3rd Brake Light Weathertech Floormats CBI Moab 1.0 (front) & Trail Rider 1.0 (rear) plate bumpers Warn M8000 Winch Custom Grille
    They actually just e mailed me offering me a slight refund.
  20. May 24, 2016 at 11:51 AM
    Centeno707
    Cody
    Arcata, CA
    Literally minutes ago.
