CCC Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AceRider, Nov 13, 2011.
  1. Nov 13, 2011 at 7:02 PM
    AceRider
    AceRider [OP] Member
    Dallas
    None - yet....
    Howdy, all. I really, really, really love the look, reputation, and fuel performance of the Tacoma. My dream is a 2011/2012 double cab long bed. But here is my issue and my questions:
    - I want it so that I can carry a slide-in, pop up camper
    - The model I'm looking at has a manufactured weight around 1,000 lbs
    - The CCC for the Tacoma models I'm looking at is around 1300 lbs
    - Wife, son, and I weigh in above 300 lbs
    - That leaves less than 1,000 lbs, which doesn't work.
    Questions:
    - CCC excludes gas and fluids as far as I can tell; can anyone confirm this?
    - What limits CCC - is it suspension or frame?
    - Can CCC be improved with shocks or airbags?
    - Does CCC include towing capacity? I'm guessing not
    - Can you add rear disc brakes? I've read that the brakes are soft feeling
    - Is the MPG quoted on Toyota's website accurate? The say up to 21 MPG highway
    I did a search (admittedly quick one) and couldn't find anything about this; if it's out there sorry, I'll look around some more.
  2. Nov 13, 2011 at 7:13 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Yea you can get 21 mpg but depends on how you drive. On avg people I talk to get 16 to 18.
    welcome to TW from SA
  3. Nov 13, 2011 at 7:24 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I'm currently averaging 19.4 with my stock DC 4x4. http://www.fuelly.com/driver/tacodawgfan/tacoma The brakes are a bit soft, that is one thing I quickly realized when test driving but after 8 months now I don't really notice or think about it unless I drive a different vehicle for a few days and then get back in my truck. Not that big an issue. But for the needs and for the price you probably would be better of with a full sized truck as already stated. Good luck and welcome to the club.
  4. Nov 13, 2011 at 7:49 PM
    Lonewolf
    Lonewolf Well-Known Member
    So. Cal
    08 4x4 TRD Sport CC, LB
    King Racing reservoir shocks, Camburg UCA's, Deaver 10 leaf pack, Bilstein 5100's, Magnaflow exhaust.
  5. Nov 13, 2011 at 8:18 PM
    AceRider
    Dallas
    None - yet....
    That's what I was afraid of, thanks all.
    What stops this from having more CCC? The Tundra is actually only 200ish lbs more?
  6. Nov 13, 2011 at 9:35 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    I think if you upgraded the springs you could eke out another 2-300 lbs of CCC. Maybe a bit more. But then you run against the limits of the composite bed, axle, and frame although I suspect the tires would blow before the frame goes - it's pretty sturdy.
    A DCLB is already ~500 lbs heavier than the Access Cab. That reduces carrying capacity even further.
  7. Nov 13, 2011 at 9:42 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    That much weight I'd get a bigger truck. I average about 20 mpg ~80% Highway because I do 40 miles round trip about twice a day. @TacoDawg my brakes are very touchy compared to everything else that I've driven but I like them.
    Edit: DC PreRunner 3.4L V6 Stock.
  8. Nov 14, 2011 at 6:08 AM
    AceRider
    Dallas
    None - yet....
    Doess CCC EXclude things like spare tire, jack, things that are part of the truck at purchase?
  9. Nov 14, 2011 at 6:20 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    In all honesty, if you are nickel and diming it, you are cutting it too close IMO.
    I would either look for something that doesn't weigh as much, or look into getting a full-size pickup.
    Fink
  10. Nov 14, 2011 at 6:34 AM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Not trying to be rude or figure out where the 300 pounds you carry sits on your body/frame but the tacoma is not a very roomy inside.
    I am the typical 5' 10" 175 and feel it being a little cramped in there.
    I would go full size just for comfort.
    The tacoma gas mileage is not much better than a fullsize and you are already in need of a full size for your needs for a camper setup just go fullsize.
    Drum brakes out back are nothing to frown at the improvement to disc is not going to be noticed much if at all.
    Most switch to a larger leaf pack to increase payload/tow capacity but if you are using alot for either need go full size.
  11. Nov 14, 2011 at 6:49 AM
    AceRider
    Dallas
    None - yet....
    Weight is 3 people. I'm around 190ish, wife 115ish, child 25ish.
  12. Nov 14, 2011 at 6:52 AM
    AceRider
    Dallas
    None - yet....
    Thanks for everyone's input. I know I should stop thinking about this, but I just love the Tacoma. I should admit defeat...
  13. Nov 14, 2011 at 6:58 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Yeah with that camper your not going to get anywhere close to 20mpg, even if you upgraded the rear for the weight. I pulled an enclosed trailer loaded down with camping gear dogs, and hunting gear across KS and got about 14. I wasn't trying to conserve any, if I was I suspect 16 would have been tops with that load.
  14. Nov 16, 2011 at 7:22 AM
    AceRider
    Dallas
    None - yet....
    So, the manufacturer can build a unit to 800 lbs, giving me a buffer for passengers, clothes, food, chairs, etc. of roughly 460 lbs. Not a big margin, but doable.
    Does anyone KNOW if the ccc EXCLUDES spare tire, jack, the stuff that comes as part of the truck?
  15. Nov 16, 2011 at 7:44 AM
    Monkeyboy
    Grand Junction, CO
    2012 AC TRD Sport
    Nope, it includes everything. But the stated limits have a margin for error and safety. If you upgrade the springs and get some good tires you should be fine as long as you're careful.
    Which camper are you looking at ?
  16. Nov 16, 2011 at 10:11 AM
    AceRider
    Dallas
    None - yet....
    Coyoterv.biz, the Phoenix pop up.
    I guess his family is the originator of Four Wheel Camper and some other stuff. Everything he does is custom, so he's come up with something that a Tacoma can handle, but it will be SMALL.
    My issue is I used to camp and would again; the Wife won't. But, we've been to Alaska in a small RV and she loved it. Now we have an infant on top of it. I cannot understate the convenience of your own toilette and shower while you are camping.
    Since we use the RV exclusively as a place to SSS, small may not matter. I just received the dimensions and will lay them out on the floor in the next few days and see if she can handle it.
    I want a four wheel truck vs. a small RV like a Sprinter based model since I'd like to camp at Big Bend or off road somewhere in NM, CO, even AZ.
    You have one?
  17. Nov 16, 2011 at 10:12 AM
    Fink
    Orlando, FL
    Have you thought about just going with a pull-behind?
    Fink
  18. Nov 16, 2011 at 10:23 AM
    AceRider
    Dallas
    None - yet....
    I have, but there aren't many off-road oriented trailers. I'm not talking about the Rubicon trail or anything, but I'd like to head off somewhere WITH the camper and camp remotely.
  19. Nov 16, 2011 at 10:24 AM
    Fink
    Orlando, FL
    Makes sense.
    Have you checked out TACODOC's setup? If not, you need to. He's got a build thread on ExPo, YotaTech and a few others.
    Fink
  20. Nov 16, 2011 at 10:32 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Orange, TX
    2017 Tacoma DCSB Off Road
    I put peanut butter on it.
    Ok I don't have much info on this but I think Jayco made a "baja" edition of a trailer which featured a beefier suspension and mud tires.
    Keep in mind I only say this thing in passing and don't know how big it is. It's NOT a pop up, it's a hard wall...
    Oh, and it's Jayco, so you can be assured of 2 things.
    1. It's well built.
    2. It's friggen expensive.
