CD player for 2020+
Discussion in '3rd Gen. Tacomas (2016-2023)' started by seabag, Apr 2, 2021.
  1. Apr 3, 2021 at 3:54 PM
    #41
    seabag
    seabag [OP] Well-Known Member
    Ben
    Maine
    2020 Black AC MT V6
    Fisher HS plow.
    Maybe, but for a few bucks its worth the experiment.
  2. Apr 3, 2021 at 4:44 PM
    #42
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Ya kinda have to if you want to download music to your phone. Not real useful otherwise if you go places where there's spotty coverage.
    ugawino likes this.
  3. Apr 3, 2021 at 4:50 PM
    #43
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I have a CD player in mine and I can't say I've used it more than twice. I have 12000+ songs in direct access at any time. Sure, quality is worse but the truck isn't a studio anyway
  4. Apr 3, 2021 at 4:58 PM
    #44
    seabag
    Ben
    Maine
    2020 Black AC MT V6
    Fisher HS plow.
    It was in 2020 that Toyo dropped the player.
  5. Apr 3, 2021 at 5:04 PM
    #45
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    I can move my seat at the push of a button... another reason I didn’t get an older car...
  6. Apr 3, 2021 at 5:10 PM
    #46
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
  7. Apr 3, 2021 at 5:29 PM
    #47
    mosccat
    Mark
    2020 OR
    I just tried my bluetooth adapter, the truck see's it tries to connect and then gives up. I think your best bet is to try a 3.5mm to USB adapter with a CD player and see if that'll work. If not then a new HU will give you what you need plus a bit of amplification...
    EDIT: just realized that this is a receiver, not a transmitter. Duh!
    https://www.amazon.com/Etekcity-Blu...t=&hvlocphy=9032762&hvtargid=pla-561074902714
  8. Apr 3, 2021 at 5:49 PM
    #48
    seabag
    Ben
    Maine
    2020 Black AC MT V6
    Fisher HS plow.
  9. Apr 3, 2021 at 6:03 PM
    #49
    markgphoto
    markgphoto Well-Known Member
    Mark
    Middle Tennessee
    2020 Tacoma ArmyGreen TRD Pro
    What I need is to be able to play my 8-tracks and cassettes.
    OrangeRa1n likes this.
  10. Apr 3, 2021 at 6:06 PM
    #50
    Shocked
    Shocked Well-Known Member
    2021 Tacoma TRD Pro
  11. Apr 4, 2021 at 7:07 AM
    #51
    Dkarr13
    Dkarr13 IG: Tonya_Tacoma
    Ohio
    2016 Sport MT ACLB MGM
    Too much to name for this little space
    Another motor, another electrical wiring needed, another electric button. I'd rather get mechanical. Reliability over luxury
    Crooked Beat likes this.
  12. Apr 5, 2021 at 5:49 AM
    #52
    Xplosiv
    Xplosiv Well-Known Member
    Jeff
    Lewisville, TX
    2021 OR DCSB Black 99 Corvette FRC
    265/75/16 AT's, Cali Raised Sliders, BAMF RTT Rack
  13. Apr 9, 2021 at 3:30 PM
    #53
    seabag
    Ben
    Maine
    2020 Black AC MT V6
    Fisher HS plow.
    For those that are interested, I now have a kit of adapters for one of the old Discplayers and will be running some tests on Sunday. I've both an audio to FM and audio to bluetooth unit. There is only one plug and play usb unit out there whose price runs from 200-300. Nice and clean, but spendy. Made by MITO: https://mitocorp.com/auto/factory-screen-integration/usb-cd-player-integration/. Seems that the issue is buffering and they have a patent on what it takes. I suspect our trucks will take version 2. The Discplayer plus FM or Bluetooth will be a not very pretty kluge but with an adapter costing 20, kind of compelling. I'll spec out the adapters I'm using after I run a test.
  14. Apr 9, 2021 at 5:22 PM
    #54
    TXnativeson
    TXnativeson Mmmmm tacos
    Alabama
    2019 TRD Sport DCSB 4X4 MGM
    I just tried the MPOW model BH390A bluetooth receiver / transmitter and it worked in my 2019.
    NathanAlsum likes this.
  15. Apr 9, 2021 at 5:33 PM
    #55
    0xDEADBEEF
    Interesting. Looks like its ripping CDs on the fly and serving them up as audio files for the headunit. That would be fun to take apart, wish they had more specs on it, depending on implementation it could be great or terrible.
  16. Apr 12, 2021 at 1:12 PM
    #56
    seabag
    Ben
    Maine
    2020 Black AC MT V6
    Fisher HS plow.
    Set some stuff up and ran some tests. The easiest is to use a Bluetooth transmitter like the Taotronics TTBA07. Nice and small; it can life in the center console plugged into the USB port for power with a wire going out to the old style discplayer. The player itself has to get power from the 12volt connection. I glued a bit of Velcro to the bottom of mine, and a matching piece on a plastic jar top that fits one of the cupholders. It's acceptable clean, not a huge Kluge. I also tried a FM transmitter from Belkin. Install isn't as clean as it needs power from a 12v socket which means you need an adapter; it can live in the center console but it has to have USB power plugged into the 12volt plug which means a bunch of cable. There are some of these that are rechargeble from a USB port and plug right into the player but I didn't try them. I don't know if all of the trucks without CD have Bluetooth; if they do that seem to be the way to go. Cost of these is under 20 bucks so you can use your old walkman or MP player or iPod.
    The MITO rig would give a nice clean install but at 10 x the cost. It does make changing CD's on the fly much easier.
    gForceDude likes this.
  17. Apr 26, 2021 at 4:10 AM
    #57
    Icarus II
    Icarus II Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    One less prescription per month. Add up your cell phone, cable, Spotify, etc. and see how much monthly income is for things you may be able to do without.
    ugawino[QUOTED] likes this.
  18. Apr 26, 2021 at 4:21 AM
    #58
    bolt_thrower77
    bolt_thrower77 Well-Known Member
    2021 DCLB trd or
    i swapped out the oem head unit on my '21 for a kenwood....i actually did the whole sound system, but it started just because i wanted a gyatdam cd player....and navigation that i don't have to pay monthly for....i'm more concerned with the function of the stereo instead of having a gyatdang 40" tv on the dash
  19. Apr 26, 2021 at 4:43 AM
    #59
    ugawino
    ugawino Well-Known Member
    Bill
    Paola, KS
    2021 TRD Off-Road, Silver Sky Metallic
    Mods? We don't need no stinking mods.
    Sure. But a monthly subscription to Spotify is the equivalent of 1 CD per month. And my Kindle Unlimited subscription is the price on 1 paperback per month. And that gives me unrestricted access to tens of thousands of songs and books at the touch of a finger. 20-30 years ago, I was buying way more than 1 CD and 1 book per month.
  20. Apr 26, 2021 at 5:42 AM
    #60
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Swap out your head unit for something aftermarket plenty of options out there with CD players still plus the oem radio sucks .
