CD Player spits out CD
Discussion in '1st Gen. Tacomas (1995-2004)' started by TigersTacoma, Feb 4, 2011.
  1. Feb 4, 2011 at 12:16 PM
    TigersTacoma
    TigersTacoma [OP] Active Member
    00 Prerunner
    Hey guys i have a 2000 tacoma and the cd player just decided to stop working. Everytime i put a cd in, it will hold it for about 5 seconds and then spit it out. It doesn't show an error message or anything it will just spit it out. Everything else works fine. I tried a cd player cleaner and it spit that cd out to. I also tried taking the player out and checking the wiring and it seems fine. I might just have to break down and buy a new one but I just wanted to see if anyone else has had this same problem. I'm not very savy when it comes to electronics so any help would be appreciated. Thanks
  2. Feb 4, 2011 at 12:17 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I think he's telling you he wants to go in the trash can.
    Wait....what are CD's?
  3. Feb 4, 2011 at 12:42 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's telling you to listen to better music :D
    I had an old truck that did that. It finally stopped taking them altogether and that was that, time for a new head unit.
  4. Feb 4, 2011 at 12:50 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    my truck used to do the exact same thing before i got a new stereo. i would have to bang the top of the dash, the part above the cd player and it would play. almost like a was banging the cd down into place. sounds ghetto but it worked for me lol you could try that
  5. Feb 4, 2011 at 7:00 PM
    TigersTacoma
    00 Prerunner
    well ill try that and see how it works. i appreciate it
  6. Feb 4, 2011 at 7:06 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    yeah just give it a few bangs and see what happens. dont bang the shit out of it, just hard enough to knock the cd into place.
  7. Feb 4, 2011 at 7:59 PM
    TacoBlitz
    TacoBlitz Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    my 2001 does the same thing. I was actually just about to post a thread asking about this but I happen to see yours first.
  8. Feb 5, 2011 at 5:55 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Mine would do that when it would overheat. I would pull the CD out which would be quite warm (almost hot) to the touch, wait 5 or 10 minutes and put it back in. It would be fine after that. I dunno if it had anything to do with the unit itself (which was stock), or because of my extra long commute (80 miles one way).:confused:
  9. Feb 5, 2011 at 5:59 PM
    Pugga
    Massachusetts
    Haha, if you can't fix it with a hammer, then you have an electrical problem!
  10. Feb 5, 2011 at 5:59 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    i doubt it's that... I've had CDs playing in the car for like 12 hours straight before
  11. Feb 5, 2011 at 6:02 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    when that happens there isn't much you can do. sometimes a good ole "disconnect the battery cables" trick can fix those electronics when they get on there period like that. get a can of that CO spray and shoot it in there. it's probably one of those little belts messed up though. . . bout as bad as the wiring in my old jeep. it required a cab temp of around 60 degrees and 2 left turns to make my cd player word (no joke). good luck though.
