CEL after Doug Thorley Install + Way too loud. Help!
Discussion in 'Performance and Tuning' started by sonomacoma, Feb 3, 2011.
  1. Feb 3, 2011 at 12:44 PM
    sonomacoma
    sonomacoma [OP] I'm in shape. Round is a shape.
    JB
    Sonoma County
    07 TRD Off Road DCSB 4x4, 17 TRD Off Road DCSB 4x4 M6
    DB Customz Grille, AFE Intake
    After DTLT install on 07 4.0L I keep throwing a CEL with code P0402. O2 sims also installed but still throwing CEL code P0402. The code translation is: Excessive EGR flow.
    My question is this, even though I keep clearing the code with my scanguage, will the ECU eventually learn that the new EGR flow is normal and adjust itself accordingly?
    Also, running DTLT's, custom y-pipe that deleted the secondary cats and a Dynomax Straight thru 2 into 1, 18" muffler. It's sounds like I'm running it with open headers. You can litteraly roll a marble down the header and it would drop out the muffler without stopping. Way to f'n loud and tinny sounding. Any suggestions on another muffler that may give a little quieter, lower rumble and not sound so raspy. Thanks all.
  2. Feb 3, 2011 at 12:52 PM
    outlaw7
    outlaw7 Well-Known Member
    Brandon
    PacNorWest
    2010 trd sport
    which y pipe are you running? you might want to add a second mufller to your cat back.
  3. Feb 3, 2011 at 12:58 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Or a resonator.
  4. Feb 3, 2011 at 1:05 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I highly recommend a resonator... especially if you're getting bad rasp. I am guessing somewhere in the 18" range...
  5. Feb 3, 2011 at 1:10 PM
    sonomacoma
    JB
    Sonoma County
    Custom y-pipe that deleted the secondary cats and tucked up a little further in front of the transfer case to keep the whole exhaust system above the frame rails. So there are no cats anywhere in the system. Headers to straight 2 3/4 y-pipe to muffler to tailpipe ending before rear axle. I think I went too far. :)
    I'm just going to have to try a different muffler, flowmaster or something to quiet it down. If it were 20% quieter, it would be perfect.
  6. Feb 3, 2011 at 5:27 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    and/or,,, is your O2 sim correctly installed?
    I have the APR X-1 controller, it does not read the rear sensors therefore no codes... But, I once forgot to plug back in the rear sensors and threw a similar code.
    Try rechecking all your conections, then disconnect the neg battery cable for 10-30 min. Re-attatch, and see if CEL pops up again 50-100 mile down the line.
    As far as Sound, you should've known that all CATs removed would = LOUD!!!
    j/k... But yeah try the second muffler or resonator. I opted to go back to stock Y-pipe. But now that im Boosted, im looking at runing a test pipe again; and will be running an 18" resonator in front of the Banks muffler.
    Good luck, and congrats on the headers...
  7. Feb 3, 2011 at 8:28 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    I had this issue as well with same headers and y pipe. One of the 02 sensors on the headers wasn't plugged in well so check everything. I also went back to stock headers and y pipe. Sound and smell made me go back to stock.
  8. Feb 3, 2011 at 10:34 PM
    sonomacoma
    JB
    Sonoma County
    Thanks all for the responses. Putting resonator(s) on Monday. That should do the trick.
    Btw..the code i was throwing was P0420...catalyst problem, not P0402...EGR flow...my bad. I'll try unhooking the batt for 30 mins and see how it goes. At least it's not another issue. I sort of expected the CEL might show up. Thanks again.
