cel code help
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Apr 18, 2011.
  1. Apr 18, 2011 at 6:21 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    got my cel checked at autozone and this is the code: P0171. Help?
  2. Apr 18, 2011 at 6:41 PM
    Murrfk
    Murrfk Well-Known Member
    Manitoba, Canada
    1996 Tacoma 2.7l
    It means your google search is malfunctioning!
    j/k System too lean is what I get. O2 sensor needs replacement?
    Here is what the manual says:
    *Air intake (hose loose)
    • Fuel line pressure
    • Injector blockage 0 0 (EG-230) (Fuel Trim)
    • Heated oxygen sensor malfunction
    • Mass air flow meter
    • Engine coolant temp. sensor
  3. Apr 18, 2011 at 6:44 PM
    DaytonLax14
    Corey
    Ohio
    okay gotcha. would i need to replace the upstream or downstream sensor?
  4. Apr 18, 2011 at 6:51 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I have the exact same code and i just recently replaced both o2 sensors! I got the p0121 code i think. It said to replace them both and i did. CEL went away for several months. Then i went mudding and got stuck in a water pit and the water was up to the floor.
    Could it really be the sensors?? And could it be just one? I really hope i dont have to replace both.
  5. Apr 19, 2011 at 7:19 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Make sure there are no leaks in your vac lines. Unmetered air after the MAF will make the engine run lean/rough.
  6. Apr 19, 2011 at 8:12 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    Cheapest starting point: Clean your MAF. Takes about 2 minutes.
    Reset your CEL and see if it comes back on.
  7. Apr 19, 2011 at 10:40 AM
    BBJ285
    BBJ285 Well-Known Member
    Scurry, TX
    03 Pre-Runner
    SnugTop cap, "SuperSpring" helperspring, flowmaster muff,K&N CAI, CB, small amp & 2 6x9s in the bed on a toggles switch for nights at the drive-in...
    will usually be the upstream(front) sensor.
  8. Apr 19, 2011 at 10:41 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    keep an eye on your mpg.
    I think the upstream in bank? causes severe loss.
  9. Apr 19, 2011 at 11:23 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I second the MAF cleaning had the same cel code on for 2 years replaced both sensors and it came back on 20 mins later, cleaned the MAF a month ago and hasnt been on since
  10. Apr 19, 2011 at 11:28 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    *3rd's the motion
  11. Apr 19, 2011 at 12:11 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Thanks everyone for the help! This will save a trip to the stealership. Rep for all!!!!
  12. Apr 19, 2011 at 6:21 PM
    DaytonLax14
    Corey
    Ohio
    cleaned the maf and reset the code and the good ol cel came back on
  13. Apr 20, 2011 at 5:44 AM
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    :lalala:
    Running lean? So (correct me if i'm wrong) You look at either a low fuel pressure/insufficient flow or an electronic giving your computer bad info... Fuel filters are what, $20? Whens the last time yours was changed? When's the last time you checked for vacuum leaks? (re:skytower) It's cheaper than replacing the front O2 again.
    Also, long shot - but after cleaning and resetting the code did you also unplug battery for 10-20minutes and 'hit the brake a few times' to reset the comp? - The old 'incorrect' a/f rate could be stuck in there and throwing code before it polls the MAF/1st O2 for an updated reading.
    My old (70's) Honda parallel twins run like shit when they even think they're not sealed up right. (CV Carbs... so kinda need that Vac pressure)
    <-i'm all about checking for the cheapest/easiest before shelling out more than 50$ unless it can be very well narrowed down to just that 1 expensive part.
    Check for leaks/make sure you're resetting fully.
