CEL CODE P0171
Discussion in 'Technical Chat' started by harley09, Sep 20, 2010.
  1. Oct 11, 2010 at 6:15 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    For shitz and giggles can you check pressure in fuel rails. How you feel about checking fuel injectors? :)
  2. Oct 11, 2010 at 5:43 PM
    harley09
    harley09 [OP] Member
    Larry
    Arizona
    99 PreRunner
    Yeah, I think I am going to have to take it to the local shop, I have run out of options. Thanks all for your help. If I get this thing fixed I will post what the problem was.
  3. Oct 11, 2010 at 5:44 PM
    98tacoma27
    Ben
    Not Beech Creek
    What brand sensor did you use?
  4. Oct 12, 2010 at 4:42 PM
    harley09
    Larry
    Arizona
    99 PreRunner
    If your talking O2 sensors, I installed Bosch.
  5. Oct 12, 2010 at 4:53 PM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    I know you don't want to spend the money if you don't have to but I would replace the mass air flow sensor. Like a previous poster said it may just be shot and time for a replacement. That code (p0171) is typical when the mass air flow sensor is bad.
  6. Oct 12, 2010 at 6:15 PM
    98tacoma27
    Ben
    Not Beech Creek
    That could be why. Are they universals or direct replacements? Toyota's are very touchy with aftermarket O2's.
  7. Oct 12, 2010 at 7:41 PM
    Roco Taco
    Roco Taco Member
    Bobby
    MD
    Roco Taco
    I am a toyota certified master tech and have seen this problem many times especially on the 3.4 v6. It could be a vaccum leak somewhere but most likely it is a dirty or bad mass airflow sensor. Most people will clean the wrong part when trying to clean it. The sphere shaped part that is exposed on the sensor after you remove it is actually just a temp sensor. You have to look inside the sensor past the temp part and you will see a silver wire like thing. This is the part that needs to be cleaned. Use brake clean or mass airflow sensor cleaner. Carb or throttle body cleaner may leave residue on it and cause the same problem. I have seen many trucks with this problem and many times it is because of too much oil on a K&N or similar air filter so if you have one be careful not to use too much oil. Hope this helps!
  8. Oct 12, 2010 at 7:50 PM
    Roco Taco
    Roco Taco Member
    Bobby
    MD
    Roco Taco
    if cleaning it doesnt work you can spray the intake with throttle body cleaner while running. if it revs up there is a leak where you are spraying it. If you dont find any leaks change the MAF. Sorry to say it but you were really wasting your time and money by changing the other sensors. This is actually a pretty common problem.
  9. Oct 13, 2010 at 11:38 AM
    harley09
    Larry
    Arizona
    99 PreRunner
    Looks like I might go and replace the MAS since I cleaned the whole probe when I cleaned it the second time using mass airflow sensor cleaner. Thanks.
