CEL flashing motor dies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dvrich, Dec 6, 2023.
  1. Dec 6, 2023 at 3:13 PM
    Dvrich
    Dvrich [OP] Well-Known Member
    Rich
    2005 black tacoma
    hey guys, hopefully someone can help me out with a little information.
    I took my truck racing at the rally track this past weekend and drove it home with no issues, i went to drive it yesterday and i can give it small throttle and ramp up and have no issues. but if i goose the throttle the truck instantly dies and the CEL flashes. with out doing anything to it, after a minute in the off position the truck starts right back up with no codes.
    im thinking loose connection somewhere but ive never seen the CEL flash with the truck not running before
  2. Dec 6, 2023 at 3:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Scan it for codes
    ToyoTaco25 likes this.
  3. Dec 6, 2023 at 3:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Flashing means catastrophic misfire.
    you 100% need to scan it before anything else. It could be 100 things.
  4. Dec 6, 2023 at 3:25 PM
    EL DUDE
    EL DUDE Well-Known Member
    Get a scanner like the above folks have said.
    check your coil packs (whatever they’re called) and your plugs.
  5. Dec 6, 2023 at 3:25 PM
    Dvrich
    Rich
    2005 black tacoma
    I said in the original post no codes. I did scan it for codes within 20 seconds of it dying and no codes came up. It didn't flash until after it died.
  6. Dec 6, 2023 at 3:26 PM
    Dvrich
    Rich
    2005 black tacoma
    Then starts back up with no codes and runs like a champ, perfect 14.7 afr. Until I goose the throttle and it instantly dies. Not stall, like shuts off completely
  7. Dec 6, 2023 at 3:27 PM
    EL DUDE
    No codes no bueno
    make sure all connections are tight, battery too, start with all the physical points. Tighten gas cap too for the hell of it
  8. Dec 6, 2023 at 3:28 PM
    Dvrich
    Rich
    2005 black tacoma
    I'm wondering if the flashing cel is it telling me it's not running anymore, I'm thinking a loose connection somewhere but it would have to be ecm related for it to shut off instantly
  9. Dec 6, 2023 at 3:28 PM
    Bishop84
    Your wording seemed a little confusing.
    So I'd be leaning towards fuel delivery causing stall. It's happening so quickly the code is likely pending then it stalls.
    Fuel pumps/fuel pressure has no codes, only lean which takes a bit.
    This sounds like a fuel pump dying, but I'd check the fuel pump resistor and the relay as well. The resistor is in front of the battery.
  10. Dec 6, 2023 at 3:33 PM
    Dvrich
    Rich
    2005 black tacoma
    I have nothing in front of my battery if your talking about close to the front of the truck.
    The fuel pump is brand new and gives me consistently 45psi including under load. Everything on the motor is brand new. I just went through sorting an electrical issue that caused a not start condition. But I replaced that fuse box that was giving me issues.
  11. Dec 6, 2023 at 3:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    See the link below for where to look for the resistor/
    https://www.tacomaworld.com/threads...ing-issue-2014-v6.468581/page-2#post-24609375
  12. Dec 6, 2023 at 4:01 PM
    Dvrich
    Rich
    2005 black tacoma
    This may be the cause. I did Jump the shit out of my truck multiple times this past weekend and I have yet to find a great battery hold down so it could have bumped the resistor and it could be killing the fuel. Crazy how it shuts off instantly. But I guess with fuel shutting off it would be losing pressure and then shutting down pretty quick
  13. Dec 6, 2023 at 4:02 PM
    Dvrich
    Rich
    2005 black tacoma
    @TnShooter you should remember the hell I went through haha
    TnShooter likes this.
  14. Dec 6, 2023 at 4:25 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'm thinking either a shitty power/ground at the PCM or something is spiking the PCM and causing it to reset.
    Just for grins try unplugging the coils one at a time and see if it still does it on each one.
    Yea I want back and found your thread, that was an adventure for sure.
    b_r_o and TnShooter like this.
  15. Dec 6, 2023 at 4:29 PM
    TnShooter
    Deogee
    STOCK
    It sure was.
    That was a long one for sure. :thumbsup:
  16. Dec 6, 2023 at 4:34 PM
    Dvrich
    Rich
    2005 black tacoma
    Does what? It doesn't stutter at all. Just straight dies haha
    If I unplug the coils I'll get misfires? But I'm not getting misfires when running it driving. Only shut down when I goose the throttle. I did add in a aux light relay but it's on its own circuit off my aux fuse box so that shouldn't matter
  17. Dec 6, 2023 at 4:38 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did the problem start after you added the aux lights?
  18. Dec 6, 2023 at 4:44 PM
    Dvrich
    Rich
    2005 black tacoma
    Well I took it from races and then just hooked the power line of my aux relay to my fuse block, then drove it a bit. Went to goose it and it just died lol so I have no idea when it started because I didn't goose it at all for a week
  19. Dec 6, 2023 at 4:52 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    A high voltage spike on certain circuits of the PCM can cause it to reset which would result in a stall.
    Ignition coils can be a source of such spikes, the voltage (Kv) required for the spark to jump the gap on the spark plug increases as cylinder pressure increases and snapping the throttle will cause a spike in cylinder pressure. A flaky coil can send flyback voltage spikes through any of the wires connected to it when it is stressed but yet not cause a misfire, this is typically more of a problem on vehicles where the coil driver is in the PCM but it still can happen on ones like Toyota where the driver is in the coil.
    It would be very easy to catch such spikes watching circuits with an oscilloscope but the next best thing you can do is unplug coils one at a time, do your same throttle snap that makes it stall, and see if it still stalls.
    GilbertOz and b_r_o like this.
  20. Dec 6, 2023 at 4:55 PM
    Dvrich
    Rich
    2005 black tacoma
    I have to be driving it to do that. That's the only time the trucks done it
