Cel issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wilcox, Jan 18, 2016.
  1. Jan 18, 2016 at 1:47 PM
    Wilcox
    Wilcox [OP] Well-Known Member
    Heys guys help me out.I got the dreaded cel PO420.I have reset it twice and ran a bottle of cataclean through it and no luck thus far. The upstream o2 sensor is fairly new. It runs great.What else could I try..Need your suggestions.
  2. Jan 18, 2016 at 3:36 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is the down stream sensor that reads the cat efficiency .
    Might be as simple as a leaking gasket .
    Depending on the mileage it might be time for new cats
  3. Jan 18, 2016 at 4:21 PM
    1988Mercedes
    1988Mercedes Well-Known Member
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    New cat fixed my 420. Downstream sensor could cause the problem but that would be too easy and cheap. It's the cat.
  4. Jan 18, 2016 at 4:57 PM
    Wilcox
    My truck has 154,000 miles on it so it could be time.Whats the best aftermarket cats to use
  5. Jan 18, 2016 at 7:48 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I just ordered both cats for my truck. walkers. 400 bucks for both including exhaust and O2 sensor gaskets.
    another thing you could try doing is the seafoam intake cleaner.
  6. Jan 19, 2016 at 1:12 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
  7. Jan 19, 2016 at 2:26 AM
    1988Mercedes
    CHARLES
    ARKANSAS
    2020 AG PRO MT
    I put a Flowmaster on but would not go that way again. It works fine but does not have a flange that accepts the pipe lip on the factory system. I had to do a lot of grinding to make it work.
  8. Jan 19, 2016 at 2:41 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Having the same issues. 150k miles. Cel has been on for atleast 5 yrs. No change in fuel economy.i was looking at both cats, muffler and tailpipe from rockauto. Think I may do that. This flow master sounds like ass.
  9. Jan 19, 2016 at 7:47 AM
    Pescado
    Pescado Well-Known Member
    Vancouver
    2002 Lunar Mist TRD DC
    265/75/16 BFG KO2, Pro Comp 7069, General Springs HD leaf pack, Bilstein 5100's, Snugtop Canopy
    For our 1st gens, if the code reads B1 which cat does that refer to?
  10. Jan 19, 2016 at 7:22 PM
    Wilcox
    I thought about changing out the downstream sensor since it only cost 61 dollars off Amazon..Then just go from their. Then after that I can find out which cat is going bad..I will also check out rockauto
