cel light problem and how to fix?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pinktaco808, Sep 30, 2014.
  1. Sep 30, 2014 at 8:11 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    my mom truck 03 tacoma base model 4 cylinder throwing a cel
    P0505 idle air control system-- how do i fix this? thanks
  2. Sep 30, 2014 at 8:14 PM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
  3. Oct 1, 2014 at 6:54 PM
    pinktaco808
    bump anyone had this problem?
  4. Oct 1, 2014 at 6:56 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Did you not read the link I posted?
  5. Oct 1, 2014 at 7:06 PM
    pinktaco808
    i did ok sooo is there a how too? or diagram
  6. Oct 1, 2014 at 7:13 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Try cleaning the IAC (Idle Air Control) valve. There is spray you can buy at Autozone that is made to clean that and the throttle body. Try that first as its a cheap solution
  7. Oct 1, 2014 at 7:14 PM
    pinktaco808
    i take of the intake hose and spray it directly into the tb
  8. Oct 1, 2014 at 7:16 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    You can. But the problem is mostly the IAC valve. Should be screws that hold the cover on. Take those off and spay it down. Allow 30-45 min for the spray to evaporate before starting. Will be hard to start and smoke may come out the exhaust, but that is just the cleaner working its way through.
  9. Oct 1, 2014 at 7:18 PM
    pinktaco808
    what cover?
  10. Oct 1, 2014 at 7:20 PM
    pinktaco808
    got pics sooo i gotta take of what cover though
  11. Oct 1, 2014 at 7:21 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
  12. Oct 1, 2014 at 7:24 PM
    pinktaco808
    where the iac located on the truck? it a good ideal to clean both than ehh?
  13. Oct 1, 2014 at 7:30 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    It should be attached to the throttle body. And yes, might as well since you have the truck apart
  14. Oct 1, 2014 at 7:30 PM
    pinktaco808
    do you have pics or diagram
  15. Oct 1, 2014 at 7:32 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Not at the moment. My Haynes manual is in my truck which is at the body shop right now. I can see if there is any pics of it in there tomorrow for ya
  16. Oct 1, 2014 at 7:34 PM
    pinktaco808
    where is it exactly? is it on the bottom of the tb cause i cant seem to find it.
  17. Oct 1, 2014 at 7:37 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Look around the tb. Top, bottom, left, right, etc.
  18. Oct 1, 2014 at 7:40 PM
    pinktaco808
    is it connected with 3 wires? forgot it has about 130k
  19. Oct 1, 2014 at 7:45 PM
    NOLA ItsNotOva
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
  20. Oct 1, 2014 at 7:53 PM
    pinktaco808
    and have 2 hoses connected to it? but it gonna be connected to the end of the tb on the side though
