Cel!!! No
Discussion in 'Performance and Tuning' started by ETaco23, Oct 25, 2009.
  1. Oct 25, 2009 at 2:19 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I got a check engine light today, and went to auto zone to get the codes. its the 881. 2,3,and 4
    all having to do with emmisions. So what do you guys think I should try?
    I was planning on getting a new AF sensor soon, so maybe that will do the trick?:eek:
  2. Oct 25, 2009 at 2:23 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    try testing the egr valve. mine took a crap on my 02. the little square box underneath it went bad as well. mine was a 4 banger so lay out would be different
  3. Oct 25, 2009 at 2:32 PM
    ETaco23
    Evan
    PNW
    just replaced it not to long ago. But thanks for the oppinion man!
  4. Oct 25, 2009 at 2:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A "P08**" code is a tranny issue.....But I cant find a P0881 code anywhere in the service manual. Are you SURE thats the correct code?
  5. Oct 25, 2009 at 3:10 PM
    ETaco23
    Evan
    PNW
    oh, I see where the code is! sorry
    its a P0420
  6. Oct 25, 2009 at 3:28 PM
    ETaco23
    Evan
    PNW
    I ordered a new A/F sensor from Rockauto for 140. Bc I know its probably a good idea to change it at 111k miles. But If that doesnt help, what should I try next? rear o2 or cat.?
  7. Oct 25, 2009 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That code doesnt have anything to do with the MAF. Check for exhaust leaks. It could also be the Sensor 2 O2 sensor, or the cat.
  8. Oct 25, 2009 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Oopps....You rdered an AF sensor. YES. Thats a good thing to change.
  9. Oct 25, 2009 at 3:37 PM
    ETaco23
    Evan
    PNW
    Well I dont think I have a leak, I checked for leaks after Installing my Headers really well. And Im verry parranoid about that type of stuff, But I will check everything out again. But I dont hear one.
    And I really hope its not the cat, bc I had to cut and weld that flange on it for my headers, and that was a PITA, and dont want to have to re-do that! Damn this sucks!
  10. Oct 25, 2009 at 3:52 PM
    ETaco23
    Evan
    PNW
    Im ganna try disconnecting the battery first, bc I never did when installing the headers and having all my leaking problems. lol So this is step one.
  11. Oct 25, 2009 at 4:25 PM
    ETaco23
    Evan
    PNW
    well the CEL is off now, And I hope it stays off!
  12. Oct 26, 2009 at 9:13 PM
    ETaco23
    Evan
    PNW
    Is it true that it can take almost 50 to 70 miles for a CEL to come back on, after clearing codes/disconecting battery?
  13. Oct 26, 2009 at 9:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep......sometimes...it may be a couple hundred miles.....sometimes,in my case.....i cleared it and it came back on 2 minutes later.
  14. Oct 26, 2009 at 9:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sometimes. Most times it comes on sooner.
  15. Oct 26, 2009 at 9:22 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    do you have a 2.7? cause mine through that also and i just tightened up the recirc valve
  16. Oct 26, 2009 at 9:25 PM
    ETaco23
    Evan
    PNW
    no its the 3.4L
    I geuss I will just wait and see if it comes back. thanks guys!
