CEL on after spark plug change???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smoove06, May 1, 2011.
  1. May 1, 2011 at 1:51 PM
    Smoove06
    Smoove06 [OP] Well-Known Member
    Alex
    North Phoenix
    05 SSM DCSB PreRunner
    Starting From Scratch....again
    So i just completed changing my spark plugs and to my surprise, my CEL came on after i fired her up. Also, she started to shake a lot more than ususal and it seemed like it was misfiring. So I went back under the hood to re-check my work and low and behold, i forgot to put on one of the wire harnesses! So i plugged it back in and now the shaking is gone but my CEL is still on.
    Here are my concerns:
    Did i do any major damage?
    Can i reset my CEL myself?
    Do i need to take it to the dealership to reset it or get my engine retuned?
    Thanks in advance!
  2. May 1, 2011 at 1:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think if you disconnect the battery for 15-20 seconds you'll be fine.
  3. May 1, 2011 at 2:05 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    If disconnecting the battery does not reset the light, it should go out with 3 or 4 days of normal driving. This is providing that the problem is fixed. Make sure you do not drive it if the CEL is flashing. Also, AutoZone may reset the light for you at no charge.
  4. May 1, 2011 at 4:34 PM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    x2
