CEL on, truck dies after starting???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scottj, Oct 4, 2010.
  1. Oct 4, 2010 at 2:06 AM
    scottj
    scottj [OP] Well-Known Member
    York, PA
    12 DCSB TRD sport OME
    Well today I went out and started my 07' Tacoma and it dies. Try again and it runs but idles rough and is lacking power. Scanned at AutoZone shows codes for (4) different O2 sensors and (1) for the MAF. Just turned over 60K miles. Any ideas?
  2. Oct 4, 2010 at 6:52 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Post the exact codes ...
  3. Oct 4, 2010 at 6:55 AM
    tacos
    tacos Well-Known Member
    Andrew
    NKY
    05 A/C Off Road 4x4
    BHLM,5100's set 2.5,Toytec 2" aal,FJ TRD wheels,AFE pro-dry, Duratracs
    I would first start with replacing the MAF meter, it is located on the intake tube. Do that then clear the codes and see if the O2 sensor codes return. The mass air flow code may be throwing the 02 codes because a faulty maf will lean out the truck. A faulty MAF will cause your truck to accelerate like crap and have no power because the a/f ratio is incorrect.
  4. Oct 4, 2010 at 6:57 AM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Yeah that ^^^ is correct. My cats didn't go out until just recently here at about 85k
  5. Oct 4, 2010 at 7:14 AM
    tiger955
    tiger955 Well-Known Member
    Carson City
    06 Access 4WD
    trd suspension
    Before you replace anything... unplug and plug back in your MAF sensor and check all of the pipes between it and your throttle body. Also check to make sure all vacuum lines are connected. Any air leaks between the MAF and the engine will cause the MAF to read the wrong airflow and a lean mixture, if too lean the O2's will not read properly setting those codes also. The codes will need to be cleared once the repair is made or the light will still stay on.
