CEL P0430 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Layhammer, Feb 18, 2016.
  1. Feb 18, 2016 at 10:33 AM
    Layhammer
    Layhammer [OP] New Member
    Jon
    2006 Tacoma 4x4 SR5
    Hi Taco world,
    I have a 2006 4x4 Taco w 118,000 miles. CEL came on and had it scanned and it threw a P0430. Given the mileage and age of the vehicle, I decided to replace the downstream O2 sensor since it was the original and probably needed regardless. Used a Denso, but had to wire it myself to the existing wire clip. Installed it and disconnected the neg terminal to clear the CEL. CEL came back on 2 days later. I drove for another day and CEL turns off on its own. Another day, and it's back on. Day 6 after replacement its back off again and has stayed off for last 2 days.
    Any suggestions or commentary on what the cause is of the CEL warnings are, and how to stop them if they continue?
    Thanks.
  2. Feb 18, 2016 at 5:45 PM
    tacoparadise
    tacoparadise Well-Known Member
    2012 tacoma 4x4
    I believe that a po430 is catalytic converter effientcy code below threshold, meaning it could need a converter.
  3. Feb 19, 2016 at 3:38 AM
    Layhammer
    Jon
    2006 Tacoma 4x4 SR5
    Yeah, I'm aware of that paradise, but I've also read a lot about this issue and seen everything from bad O2 sensor, to faulty/cracked air intake to bad AF sensor etc, and only sometimes is it the CAT.
    My truck doesn't exhibit any symptoms other than poor mpg(12 mpg city) and considering the miles on it presently, I decided to replace the O2 sensor to start.
    I guess my next step if the CEL keeps appearing is to remove the exhaust and look inside the CAT to see if it still looks in tact.
    TacoFlavoredKisses likes this.
