CEL P043E, P043F, P2401, P2402, and P2419
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ron.p, Nov 14, 2011.
  1. Jan 6, 2014 at 8:15 AM
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    I used a shop vac on a previous vehicle to put suction on each line just to make sure it was clear. However, the code for that was P2422 on a Kia, which said "Blocked or Clogged EVAP Canister."
  2. Mar 23, 2014 at 5:11 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    lol i got the same codes about a month ago...going to try to take it apart one of these days...see if maybe its fixable.
    a used one around here is $125
  3. Nov 5, 2014 at 10:52 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    Pulled the same codes.. I'm assuming the charcoal canister is the same for a 2.7l 6lug truck ?
  4. Nov 10, 2014 at 6:32 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    Before you do anything, pull the battery cable and reset the ECU to see if they come back.
  5. Nov 10, 2014 at 6:46 AM
    tacokid09
    Brian
    San Luis Obispo, CA
    2010 Tundra
    ended up taking the canister out and it was filled with water... :(
  6. Dec 27, 2014 at 5:47 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    if we have an off road only truck,
    cant we just remove the system completely,
    plug everything up,
    and "trick" the sensor?
    Bobby18 likes this.
  7. Dec 27, 2014 at 9:20 PM
    Climberclimb
    Climberclimb Well-Known Member
    Stacey
    British Columbia
    2020 TRD Sport premium
    Stock!
    Hey everyone. Just bought a 2015 dc sr5 Tacoma, after a week and 400 km - same issue you guys are experiencing. Will find out Monday what is wrong when the master tech is back to work. Great site btw! Cheers
  8. Dec 30, 2014 at 3:48 PM
    CowboyTaco
    North Georgia
    11 TRD Sport
    You sure it was water? I think those normally get filled with gas if it's any kind of liquid.
  9. Dec 30, 2014 at 5:35 PM
    Supramacy
    Supramacy Well-Known Member
    Usually it's water that gets into the canister through the filter that leads to the filler neck.
  10. May 24, 2015 at 11:59 PM
    marioR77
    marioR77 Member
    Mario
    surprise
    06 Tacoma long traveled prerunner
    Baja style bumper and fenders
    Will anything extreme happen if you let it run like this for a couple days? Need to get the $-.-
  11. May 25, 2015 at 12:06 PM
    marioR77
    marioR77 Member
    Mario
    surprise
    And also the guy at auto zone says that the only filter that involves fuel is the entire fuel pump. Is this true???
  12. May 26, 2015 at 6:00 AM
    CowboyTaco
    North Georgia
    11 TRD Sport
    Just watch your gas mileage.
    Unsure. I've gotten both good and poor advice from autozone. You might call your dealership and just ask what they normally do in the event of those codes. They will likely tell you that you need to come in so that they can inspect; however, some service advisers will actually give you a little more information. I'd start the conversation off with "I'd like to do some preliminary diagnostics before coming in because I live XXX away from the dealership and it isn't a convenient drive...."
    If I remember correctly, I reset my ECU and the codes didn't come back. You might start there.
  13. May 29, 2015 at 1:50 AM
    marioR77
    marioR77 Member
    Mario
    surprise
    Thank you dude! So from what I've read in this thread the part is located in the gas tank?? Is that fairly simple to do?
  14. Oct 6, 2015 at 7:50 PM
    lx450landcruiser
    lx450landcruiser Member
    06 double cab trd offroad
    lifted, arb bumper
    Been driving around with my check engine light for about a year and a half. Finally due for emissions testing and finally had to bite the bullet and fix the issue. Replaced the charcoal canister and decided to crack open the pump part just to see. (See attached) no wonder the light kept poping on
    MTopp likes this.
  15. Dec 30, 2015 at 9:53 AM
    #35
    carriong
    carriong Member
    Gerry
    06 Tacoma TRD 4X4
    Ron, mine did the same exact thing when I changed over to K&N air filter. I go the same exact codes, Im going to change it back to the original air filter, erase the code and see what happens.
  16. Feb 1, 2016 at 10:21 PM
    #36
    emilminasian
    emilminasian Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    whats up TW!, okay so ive been getting these codes on and off....
    on top of that my car randomly starts kicking in the freeway... its not like a transmission kick, very odd. truck has 80K miles oil change every 4K miles. have a cold air on it. any one have these issues before? dont know what do and dont have warrenty
  17. Feb 2, 2016 at 3:05 AM
    #37
    carriong
    carriong Member
    Gerry
    06 Tacoma TRD 4X4
    I had the same issue, I bought a duralast vapor canister from autozone for $360 online and autozone gave me a $75 gift card. Never had an issue again and am saving alot of gas.
    It was a little tricky to get out but definitely worth the effort. Not sure what a garage or toyota dealership would of charged me, but im pretty darn sure it be alot more than $285.
  18. Feb 2, 2016 at 8:46 AM
    #38
    emilminasian
    Emil Minasian
    Glendale, CA
    What exactly is that canister ?
  19. Feb 3, 2016 at 4:45 AM
    #39
    carriong
    carriong Member
    Gerry
    06 Tacoma TRD 4X4
  20. Feb 5, 2016 at 7:09 PM
    #40
    emilminasian
    Emil Minasian
    Glendale, CA
