CEL P043E, P043F, P2401, P2402, and P2419
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ron.p, Nov 14, 2011.
  1. Feb 27, 2016 at 3:00 PM
    #41
    carriong
    carriong Member
    Gerry
    06 Tacoma TRD 4X4
    I didn't have any kicking issues.
  2. Apr 11, 2016 at 3:23 PM
    #42
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Well I just started up the truck and got all 5 error codes as well. Fuel mileage has been dropping over the last few weeks and have noticed an intermittent rough idle as well. I guess this is the culprit. Bummer.
  3. Apr 12, 2016 at 2:44 AM
    #43
    carriong
    carriong Member
    Gerry
    06 Tacoma TRD 4X4
  4. Apr 12, 2016 at 2:45 AM
    #44
    carriong
    carriong Member
    Gerry
    06 Tacoma TRD 4X4
    I had the exact same issue, went back to regular air filter, changed the cannister and its been fine since.
  5. Aug 15, 2016 at 1:40 PM
    #45
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Guess I'll be doing this soon. Apparently driving in 8 ft deep water is hard on the evap canister. Got this series of codes over the weekend.
  6. Sep 13, 2016 at 3:18 PM
    #46
    tacotim448
    tacotim448 Well-Known Member
    Tim
    Nashville
    2011 Money Pit
    It never efffing ends.....
    Yesterday I had my rear leaf springs replaced as part of the Toyota recall. When I left the dealership my CEL and SLIp Assist light were both activated. I returned today to have a diagnostic check run. They told me it was my canister and filter. Total cost to replace is $999.35.
    I've read through this thread and it sounds like this is a pretty easy DIY. My questions is, how pressing of an issue is this? What adverse effects will it actually have if I wait to do it myself later?
  7. Sep 13, 2016 at 3:46 PM
    #47
    mightytacoman
    Kel
    4.5L 1grfe
    I replaced mine about a month ago. Took less then an hour to do them. Found the canister for about 260$ and the filter for about 45$ online. Its not a "pressing" issue per say but it can lower fuel mileage.
    tacotim448 likes this.
  8. Jun 18, 2017 at 11:37 AM
    #48
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Old thread bump. I'm having these same codes popping up in the last few months. Clear them and they seem to only take a few days to come back anymore. Everyone says replace the canister and filter. I removed the canister and inspected it, no liquid inside, hoses tight, connections ok, nothing abnormal, so I reinstalled it. Looking at the hoses I found the vacuum hose from the intake to the VSV valve loose and dry rotted. Installed a new hose, I'll see if that takes care of the problem. Otherwise it's canister time.
    mightytacoman and Chopperrescue like this.
  9. Jun 25, 2017 at 1:38 PM
    #49
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    The hose on the intake did not fix the light. I ordered a new canister assy and hose(back ordered). Removed the old pump and took it apart, corroded inside.
  10. Dec 21, 2017 at 4:26 PM
    #50
    Lil'Taco
    Lil'Taco Well-Known Member
    Scotty
    Wilsonville
    2010 PreRunner Sport DCSB
    Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Decked Drawer system, aFe CAI, Borla Cat-back exhaust, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts, Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights... It has more stuff done to it now.
    This will have been the 3rd time these have been replaced. I replaced them on Monday, drive in the rain, but I covered the filler cap in a plastic bag (fiberglass besides) three days after they were replaced the codes came back. I'm running out of money to through at it.
  11. Feb 8, 2018 at 3:46 PM
    #51
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Been 4 years since this post. I just cleared the code then and it hasn't come back.... Until today.
    I'm thinking something with the cold weather. Will update if it turns out to be more than that this time around.
    NABeast likes this.
  12. Feb 8, 2018 at 5:15 PM
    #52
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    Thanks for the update. I replaced my canister and vacuum motor a while back, and mines been good. But i live in Florida. Although I think I could have just done the vacuum motor and been good with that.
  13. Feb 9, 2018 at 5:28 AM
    #53
    CowboyTaco
    North Georgia
    11 TRD Sport
    Itsnickfool and N919HJ like this.
  14. Mar 8, 2018 at 5:55 AM
    #54
    CowboyTaco
    North Georgia
    11 TRD Sport
    Just an update. No parts replaced. The codes tripped when it was a very cold night and I had a full tank of gas. The cold only lasted a few days and I cleared the codes again on a warm(er) day and they haven't come back.
    I'm thinking I may have a faulty sensor or something, but I'm not going to worry about it until it happens again. (more of a when it happens, not if)
  15. Jun 10, 2018 at 7:50 PM
    #55
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    anyone have actual pictures of the bolts/fasteners that hold this whole piece in? I just crawled under the truck to investigate. Looking to see if anyone can help me speed up this process with a few pics before I go in blind. I had just the P043E code which looks like a clog. Trying to find what could be clogged after a weekend of off-roading. Nothing looked super muddy and I don go "mudding" but there was standing/dirty water on some trails.
  16. Jun 11, 2018 at 4:10 AM
    #56
    CowboyTaco
    North Georgia
    11 TRD Sport
    Have you tried just clearing the code to see if it comes back?
  17. Jun 11, 2018 at 9:03 AM
    #57
    Skootter14
    Jeremy
    Nah, not yet. It hasn’t triggered a CEL, my UG just pops up with pending p043e
    CowboyTaco[QUOTED] likes this.
  18. Jun 11, 2018 at 10:54 AM
    #58
    CowboyTaco
    North Georgia
    11 TRD Sport
    clear it and see if it pops back up on the UG.
    For those of you who do not have an Ultra Gauge....you need to invest.
    Skootter14[QUOTED] likes this.
  19. Jun 13, 2018 at 2:47 PM
    #59
    Skootter14
    Jeremy
    so this morning it went from pending to actual with the inclusion of the CEL and traction light on the dash haha.
    I did pull the neg terminal to reset it. we'll see if it comes back on. If so I will buy a canister and filter piece and replace it myself. Also, the UG did show the same 5 codes before I cleared them. So I am sure its this same issue :thumbsup:
    Do you have any pics or walk through for it? Im sure if I can install a S/C I can replace these components. Just haven't seen pics or anything and would prefer not to go in blind if possible.
  20. Jun 13, 2018 at 3:55 PM
    #60
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    I think used a ratchet wrench, you just have to feel for the bolts since they go in from the top. It’s probably easier if you dont have a spare tire underneath ether, you can just sit under there and reach over the diff. I think i just needed the vacuum pump and not the whole canister, but I already had both.
