Cel p0446
Discussion in 'Technical Chat' started by TacomaDan, Mar 15, 2010.
  1. Mar 15, 2010 at 2:21 PM
    TacomaDan
    TacomaDan [OP] Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    Ok im throwin this code in my 96 V6 4x4. Do you think it would be safer to just go to the dealer to get them to fix it or do you think any reputable shop could do it right? I called the dealer and its $90 just to diagnose and find what the part is. It could be any number of different relays to sensors to evap canister. What do you think?
  2. Apr 20, 2010 at 8:24 PM
    ShankOttawa
    ShankOttawa Member
    Ottawa, ON Canada
    99 Xtra Cab 4x4 V6 5spd manual
    KYB MonoMax rear shocks Bilstein 5100 adjustables
    I just pulled the same code on my truck tonight. I'd like to know if it's the charcoal canister or something else?
  3. Apr 21, 2010 at 12:58 AM
    TacomaDan
    Daniel
    Woodland, CA
    Ya im going to the dealer tomorrow and gettin it fixed. Ill let you know. but it could be a number of different things. There are a few sensors and items that could be the problem also....
  4. Apr 21, 2010 at 9:42 AM
    ShankOttawa
    ShankOttawa Member
    Ottawa, ON Canada
    Thanks! I'm very curious to find out what it is exactly!!
  5. Jul 1, 2010 at 9:50 PM
    TacomaDan
    Daniel
    Woodland, CA
    Took it to the dealer. It was my charcoal canister and a check valve associated with the canister. Replaced and no check engine light for 2 weeks!!! WOOT
  6. Sep 2, 2010 at 9:08 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I just scanned my buddy's 2000 tacoma for codes and pulled:
    P0141
    P0450
    P0446
    could it be the same problem?
  7. Sep 2, 2010 at 9:43 AM
    TacomaDan
    Daniel
    Woodland, CA
    It could be but the code goes for the whole evaporative emmissions system. There are a few other sensors and I'm sure they are associated with a few different systems. I am not sure what those other two are but I bet if you figure out what codes they are, you'll find out they all have a certain sensor in common. I dont know, just throwing suggestions out there. I hope it helped! All I know is I only threw P0446 not the other ones.
