CEL Question again.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fabulous, Jun 3, 2010.
  1. Jun 3, 2010 at 12:47 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    the other week the check engine light came on in my tacoma when I was 600kms from home. I drove it home, and made an appointment at the dealer, but I had to wait until today to get an appointment. Well, the other day I was checking everyything under the hood to make sure it was good, and checked the battery posts to make sure that was all good...but it reset my computer, and the dealership now can't tell why the light came on. My question is this...if there is a problem, should my check engine light come on again? If it doesn't should I not be concerned? Any help is appreciated.
    Thanks.
  2. Jun 3, 2010 at 12:52 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    If there is a problem then yes it should come on again. Some of the codes require a two trip detection in order for them to be tripped. It could have been something as simple as a loose gas cap also.
  3. Jun 3, 2010 at 12:55 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    There should be a 'history' stored within the computer. The dealership should be able to find the code hidden in the memory.
  4. Jun 3, 2010 at 12:58 PM
    Fabulous
    Fabian
    Calgary, AB
    They checked it out today, and couldn't find anything. I wonder if it could be attributed to the gas I filled my truck up with prior to my road trip...it was Costco gas which I've never used. I had read on other forums about their gas being not so good, and setting off peoples CEL?! I'm just hesitant to drive it in case I F it up...
  5. Jun 3, 2010 at 12:59 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You won't F it up. Drive it like normal and see if it comes back. If it doesn't, then you are good to go.
  6. Jun 3, 2010 at 1:05 PM
    Fabulous
    Fabian
    Calgary, AB
    Ya think? I guess I will do that then. If the light comes on, then I'll just take it in... was just paranoid that if I accidently reset it, and it didn't come back on, I may harm the truck. Thanks.
