CEL, Trac Off, & Limited Power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoJersey, May 20, 2017.
  1. May 20, 2017 at 5:29 PM
    NorGATaco
    NorGATaco Well-Known Member
    Brent
    Northeast GA
    12 DC TRD OR Super White 4x4
    This was the first major problem I had with mine
  2. May 20, 2017 at 6:32 PM
    SoJersey
    SoJersey [OP] South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
    What did the parts run you to replace the pump and valves?
  3. May 20, 2017 at 6:42 PM
    NorGATaco
    Brent
    Northeast GA
    I think they were around 750. I know I ordered them from Bosch Toyota website
  4. May 20, 2017 at 6:43 PM
    NorGATaco
    Brent
    Northeast GA
    I have the receipt somewhere but I would have to look for it.
  5. May 20, 2017 at 7:00 PM
    tcjacado
    tcjacado Well-Known Member
    You did the bypass, was that cheaper than the 750 and it lasts longer than 60k right?
  6. May 20, 2017 at 7:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This ^^^^ it is becoming more of an issue everyday...
    Codes will be P2440 and / or P2442.
  7. May 20, 2017 at 9:17 PM
    NorGATaco
    Brent
    Northeast GA
    Yes I did the bypass. It was 350 but the system has to be working before installing
    Edit: I hope it lasts "till the wheels fall off "
    tcjacado[QUOTED] likes this.
  8. May 20, 2017 at 9:19 PM
    tcjacado
    Ah, did not know that part. I never had to deal with it on my 07 and now my 17 pretty sure doesn't have it. Lol
  9. May 20, 2017 at 9:26 PM
    NorGATaco
    Brent
    Northeast GA
    If I understood correctly the models before 2012 had a different system in them
  10. May 21, 2017 at 4:33 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Before 2012 the 4.0 liter engine did not have any air injection system. It was added in 2012. The 2013's and up also have the air injection system, but it runs after shutdown to dry out the moisture, the 2012's do not.
  11. May 21, 2017 at 5:49 AM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Anyone convert it to run like 2013+?
  12. May 21, 2017 at 5:59 AM
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    I'm glad my '07 Taco doesn't have one of these pumps, because it has went bad twice on my '09 Tundra (luckily replaced under extended warranty). Same symptoms the OP described, it would rev smoothly up to 4k rpm but absolutely no power, felt like a little three cylinder engine under the hood.
  13. May 21, 2017 at 6:18 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That would take an ECU programming flash. Not easy and dangerous to the ECU ( like it could brick it ) if done wrong.
    SoJersey[QUOTED][OP] likes this.
  14. May 21, 2017 at 12:51 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Did you replaced everything? Valves and pump?
  15. May 21, 2017 at 3:11 PM
    #35
    NorGATaco
    Brent
    Northeast GA
    tomwil likes this.
  16. May 21, 2017 at 4:25 PM
    #36
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Ok cool, fairly easy install? Remove and replace? I can do just about everything on the truck as long as it's not overly complicated.
    I sent Gunny from CamelBack Toyota on here a message to see if he can save me some money, is Boch hooking us Tacoma guys up?
  17. May 21, 2017 at 4:28 PM
    #37
    SoJersey
    Brandon
    08302
    '12 DC Offroad
  18. May 21, 2017 at 5:18 PM
    #38
    NorGATaco
    Brent
    Northeast GA
    It was just the best price that I found online. It is very easy to replace just tight in places getting the bolts and nuts out.
  19. May 21, 2017 at 6:10 PM
    #39
    SoJersey
    Brandon
    08302
    '12 DC Offroad
    Ok thanks man!
  20. May 31, 2017 at 3:26 PM
    #40
    GarnerGrey12
    GarnerGrey12 New Member
    2012 Tacoma 4x4 4.0
    The numbers:
    2012 Tacoma
    42,500 miles
    $1965.69 (including $291.25 for labor) to replace bank 2 secondary air injection pump, switching valves and gaskets
    I don't have the towing bill yet. Went into limp mode which was actually kind of scary considering where I was.
    I registered my complaint with Toyota customer service. Maybe they will eventually do the right thing.
    I'm just beginning the process to replace our other vehicle. Guess which manufacturer will not be on my shopping list?
