Cel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wareagle5693, Aug 8, 2010.
  1. Aug 8, 2010 at 6:46 PM
    wareagle5693
    wareagle5693 [OP] Well-Known Member
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    3" Spacer Lift, with Bilstein 5100s front and rear, BHLM, Satoshi grill, Blacked out tail lights, Midland CB radio, 4' Radio Shack antenna mounted in the bed, Volant CAI, Gibson Exhaust, Magellan GPS, debadged, aries bull bar, pro comp 7089 wheels, Pioneer DEH-P6200BT head unit, eagle eyes halo projector, 8000K DDM tuning HID bulb
    Well my parents had to borrow my truck today, to help my step-sister move into her new apartment.
    Well he said on the way home it started running rough, and the check engine light came on but went off.. so I had to go take the trailer home, which blew 3 fuses for my taillights. :mad: but when I got in the CEL was back on, so we got his OBD II trouble code reader, and we got these 2 codes.
    P0174(that's for Fuel Injection) and P2197. Does anybody know what the second one means? I couldn't find it.. Thanks!
  2. Aug 8, 2010 at 6:49 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    P2197 – Oxygen (A/F) Sensor Signal Stuck Lean (Bank 2 Sensor 1).
  3. Aug 8, 2010 at 6:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    the P2197 code is a generic fault code. Check your vacuum lines, and intake. Make sure all is connected well.
  4. Aug 8, 2010 at 6:51 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    Which oxygen sensor?
  5. Aug 8, 2010 at 6:51 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    Thanks Chris!
  6. Aug 8, 2010 at 6:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent heard of this code for the A/F sesor. Are you sure about this?
  7. Aug 8, 2010 at 6:53 PM
    wlmuncy
    William
    Knoxville, TN
    It's from a Tundra forum, but looks right:
  8. Aug 8, 2010 at 6:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah. Cool. "Stuck lean" could still mean air is comming in thru a vacuum line, or the intake. I would start there.
  9. Aug 8, 2010 at 7:04 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    Alright, I'll check it out tomorrow sometime.
    That would what's causing it to run rough right?
  10. Aug 8, 2010 at 7:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It could be. Most times I have had an engine run rough, was due to a vacuum line being disconnected, craked, etc.
  11. Aug 8, 2010 at 7:13 PM
    wlmuncy
    William
    Knoxville, TN
    I would say yes.
  12. Aug 8, 2010 at 7:13 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    Well I can check and if it still does it.
  13. Aug 10, 2010 at 12:31 PM
    wlmuncy
    William
    Knoxville, TN
    Did you get worked out? If so what did it end up being?
  14. Aug 10, 2010 at 12:36 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    I've been trying to figure it out, I can't see anything that looks wrong with the hoses... but I'm not 100% sure what I'm looking for either, i had to go back out today to get some stuff.. and when I was sitting at idle it started running really rough again... so rough i had to turn the car off and back on. So i'm trying to figure out where I need to look to get this checked out, or if i just need to take it in to the dealer, or a garage somewhere.
  15. Aug 10, 2010 at 12:39 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    do you still have your stock intake, slap that on for a bit to see if it runs better and the CEL goes away
  16. Aug 10, 2010 at 12:43 PM
    98tacoma27
    Ben
    Not Beech Creek
    For reference:
  17. Aug 10, 2010 at 12:52 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    So it's a sensor that went bad?
  18. Aug 10, 2010 at 1:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    Not necessarily. A lean condition means more air is present than should be in relation to the gas content of the mixture. It could be, as stated earlier, a vacuum line is disconnected/cracked/bad somewhere. However, the code is side specific, Bank 2. That should be the drivers side. You can test the sensor with an OHM meter to verify it's faulty. That should rule it out quick, or point the problem to some where else.
  19. Aug 10, 2010 at 1:09 PM
    wareagle5693
    Jay
    Montgomery, Alabama
    08 PreRunner SR5
    Alright thanks Ben! I'm probably going to wait til my step-dad gets home now. But hopefully it's just a line is bad not a sensor.
  20. Aug 10, 2010 at 1:10 PM
    98tacoma27
    Ben
    Not Beech Creek
    If it is the sensor, replace it with the OEM Denso.
