Cell Phone Bluetooth Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nascarjc, Jul 7, 2008.
  1. Jul 7, 2008 at 2:56 AM
    nascarjc
    nascarjc [OP] Member
    Hello TW,
    The other night I was looking thru the forum and found where someone had put a bluetooth in the sun glass compartment in the top console. For the life of me I can't find it again. Has someone run across this or point me in the right direction. CA law went into effect of having the bluetooth handsfree devices to use the cell phone. I don't believe in talking on the phone while driving but sometimes you just have to. The help would be much appreciated. :)
  2. Jul 7, 2008 at 4:11 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Never heard of that mod....but here's another thread to check out.
    http://www.toyotanation.com/forum/showthread.php?t=138931
    You can also get GPS's and stereo head units that'll do it. Although...the GPS's are FM transmission which tends to lack in quality/reception.
    I have a GPS that can do it....and if I could find a clean/clear FM station - it'd probably work better.
    Apparently, blue tooth is available on the 2009 tacomas. I wonder if that's integrated with the head unit? and if it would fit to replace the older units?
    *probably cost too much anyway*
  3. Jul 7, 2008 at 10:25 AM
    Mingy
    Mingy Well-Known Member
    Milton, Ontario
    V6 uble Cab TRX/Towing
    Lear cap.
    What I did was I got a Motorola Bluetooth handsfree which usually clips to the visor. I don't like anything in my field of view, especially anything which moves or has a flashing blue lite, like this things has (why people do this I'll never understand). No visual dsistractions = 32 years accident free driving.
    I removed the visor clip and epoxied a rare earth magnet to the handsfree. Then I cut a piece of steel about 2x3/4 and glued this into the sunglass compartment (under the foam). Now the Bluetooth is out of my line of sight.
    Then I took an USB lighter charger and pulled out the PC board. I wired the board (about 1x1 inch) directly into the console power supply, and cut and threaded the USB wire through a small hole I drilled in the sunglass compartment. That keeps the Bluetooth permanently charged.
  4. Jul 7, 2008 at 10:38 AM
    nascarjc
    Thank you for both suggestions. I might have to look into it, but there is a thread here in this forum that I saw. If I do find it also, I will post it for you in case you are interested in it. Mingy, great driving record. :D
  5. Jul 7, 2008 at 10:49 AM
    Mingy
    Milton, Ontario
    Lear cap.
    I figure I'm due! :(
  6. Jul 7, 2008 at 2:13 PM
    nascarjc
    Don't think that way, think you have paid your dues long time ago. ;)
  7. Jul 7, 2008 at 3:01 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Check this out for a cheap alternative...
    http://www.tacomaworld.com/forum/audio-video/10746-blue-ant-supertooth-light.html
    I have a Pioneer DEH P700BT Headunit which gives you hands free bluetooth over the car audio system. I LOVE IT!!
  8. Jul 7, 2008 at 3:59 PM
    Finch Taco
    Finch Taco Member
    Charlotte, NC
    09 MGM PreRunner DC LB TRD Sport/JBL
  9. Jul 9, 2008 at 7:36 PM
    05dcabpatsfan
    05dcabpatsfan New Member
    mass.
    05 SR5 morped to TRD Sport
    hood, grille(s), intake, headlight mod silver to match, aftermarket tail lights, fog light mod w/yellow bulbs, NAV, OEM rear spoiler, bed lights w/remote, 275/60 17 indy 500's, remote start, add a leafs, TRD suspension,oem running boards, roof racks
  10. Jul 10, 2008 at 6:37 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  11. Aug 6, 2008 at 10:03 AM
    Asgard
    I got mine installed yesterday (professionally) here are some pics attached :
  12. Sep 22, 2008 at 6:39 PM
    bhester
    bhester Active Member
    Bobby
    Hopkinsville, KY
    2024 Tacoma TRD Sport Premium
    Asgard I read your post about your new blue tooth in the sun glass box. How do you like it? Is it easy to hear and can the other person hear you good?
  13. Sep 22, 2008 at 6:49 PM
    Asgard
    Quality is excellent, I have no problem with hearing the other person or the other person hearing me. No dropped calls or anything, the only very minor problem I have is the display lighting is white I wish it was amber to match my other display lights also it does not dim when I turn on my headlights. Thats about it no other complaints.
  14. Sep 29, 2008 at 8:00 AM
    uuc328
    uuc328 Well-Known Member
    So. Arlington, Texas
    '07 FJC fender crack edition
    great thread! just what i was looking for.
  15. Sep 29, 2008 at 12:00 PM
    uuc328
    any one know if the kit asgard installed will auto mute the stereo when a call is incoming?
  16. Sep 29, 2008 at 1:06 PM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
    Great looking install - but I'm not sure that I want to sacrafice my sunglasses storage for it. I plan on getting the Kenwood DNX5120 that "should" handle the bluetooth deal for use with my Palm Centro.
  17. Sep 29, 2008 at 2:28 PM
    Asgard
    No, it doesn't auto mute. You just have three wires to connect : ignition, 12v and ground.
  18. Sep 29, 2008 at 2:33 PM
    uuc328
    i suppose i can live with that. cant wait to get my wireless all wired up :D
  19. Oct 1, 2008 at 7:12 AM
    uuc328
    decided to go with the Garmin nuvi 760 instead. its only about $80 more and you get GPS navigation too.
    will post up the install details this weekend
