cell phone charging problem
Discussion in 'Technology' started by 07TacoRidah, Oct 13, 2012.
  1. Oct 13, 2012 at 9:04 PM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    So I got a phone from my dad, it's a Nokia E73. It only has a wall charger, so when I plug this charger in, after a little bit it make a beep and I get this screen (attached). I'm not sure what it is but after a little while longer I get another beep but the tone is different and then I see the battery (not sure of you can see it in the picture - upper right corner) and it's a crescent moon looking thing in there. At first I thought okay, the battery is charging, but maybe a minute later the phone won't go on, the screen won't even light up.
    Could this mean the USB port is bad? You can only charge it via the usb port (well for now I can only do it that way unless I get the battery charger). Anyone have experience with charging problems or this phone?
  2. Oct 14, 2012 at 12:27 PM
    07TacoRidah
    found out the problem. stupid wall charger was a POS China replacement one. Went to the Dollar tree and got me a USB cable :D
