Cell phone holders
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Mar 6, 2021.
  1. Mar 14, 2021 at 6:29 PM
    Carter Tacoma 03
    Carter Tacoma 03 Well-Known Member
    Carter
    2003 Toyota Tacoma Xtracab Prerunner 2WD 2.7L L4
    Every since I got my truck I’ve been using this one: Mpow Car Phone Mount, Dashboard Windshield Car Phone Holder with Long Arm, Strong Sticky Gel Suction Cup, Anti-Shake Stabilizer Compatible iPhone 11/11 Pro/Xs Max/XS/XR/X/8/7, Galaxy, Moto and More https://www.amazon.ca/dp/B07X3ZXTDY/ref=cm_sw_r_cp_api_i_72KE3JKTC25WF6QDGX45?_encoding=UTF8&psc=1
    it’s great and there is a wireless charging version aswell. It has a suction cup and another clip to hold the bendable piece down for extra support. I actually bought the non-wireless one after I got the wireless because I ended up installing a gps and that came with an option to attach my phone charger so I use it for it’s main purpose as a stand.
  2. Mar 14, 2021 at 6:32 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I made one at work, bolted it to the plate in the dash that was already there.
  3. Mar 14, 2021 at 6:32 PM
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    I got a Scosche magnet mount that works great but off road the phone goes in the Ashe tray and stays tight.
    JJ04TACO likes this.
  4. Mar 14, 2021 at 6:33 PM
    Carter Tacoma 03
    Carter
    Hey how did you bolt those into the dash? I’ve never done it before and wouldn’t that was mess with the passenger airbag because that’s obviously what you bolting it into?
    six5crèéd[QUOTED] likes this.
  5. Mar 14, 2021 at 6:35 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Mines a double cab and doesn’t have the option to turn the airbag off, it was a blank plate :thumbsup:
  6. Mar 14, 2021 at 6:36 PM
    Carter Tacoma 03
    Carter
    Ohh I see I got the xtra so was just asking. I wonder why the double cabs don’t have that?
  7. Mar 14, 2021 at 6:39 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I assume cause the car seat would be in the back, just guessing though.
  8. Mar 14, 2021 at 6:48 PM
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
  9. Mar 14, 2021 at 6:48 PM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    The ram picture that was posted here was attached to a pillar handle which had a bolt that you could use to secure it to which I don’t have
  10. Mar 14, 2021 at 6:52 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Did you ever try suctioning it to the dash?
  11. Mar 14, 2021 at 6:56 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    M6 x 1.0. I used a 40mm. YMMV.
    flightmech08 likes this.
  12. Mar 14, 2021 at 7:05 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    As in I don’t even have the handle. Just a flat pillar
  13. Mar 14, 2021 at 7:07 PM
    theesotericone
    Bishop CA
    There should still be rivnuts under the pillar where the oh shit handle bolts on. Just find them and drill the trim piece.
  14. Mar 14, 2021 at 11:25 PM
    khail19
    khail19 Well-Known Member
    Khail
    Reno, NV
    2000 Prerunner SR5
    That's awesome, all I need is to swap a 3rd gen dash into my 1st Gen so it will fit!
  15. Mar 15, 2021 at 6:53 AM
    #35
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
    I used a Steelie ball magnet mount just above the clock
  16. Mar 15, 2021 at 7:14 AM
    #36
    Carter Tacoma 03
    Carter
    Yes that’s where I have it and it works perfectly fine along with the extra clip
  17. Mar 15, 2021 at 7:15 AM
    #37
    Carter Tacoma 03
    Carter
    True thanks
  18. Mar 15, 2021 at 7:22 AM
    #38
    Alby22
    Alby22 Well-Known Member
    Ashville, Ohio
    Cement 2020 Toyota Tacoma TRD Sport 4x4 Double Cab, Long Bed
  19. Mar 15, 2021 at 7:35 AM
    #39
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
  20. Mar 15, 2021 at 8:52 AM
    #40
    Alby22
    Ashville, Ohio
    Sorry, I completely wasn’t paying attention to what gen
