Cell phone mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by lucky13don, Mar 16, 2018.
  1. Mar 17, 2018 at 2:00 PM
    taco lifter
    taco lifter Well-Known Member
    James
    2002 Tacoma 3.4 crew TRD off road
    3" Trailgear lift, rack on camper shell, deck plate mod, led
    I took power from the pre-existing cigarette lighter and dremeled out the little coin holder, and found another socket the same size.
  2. Mar 17, 2018 at 2:01 PM
    taco lifter
    James
    The charger I got also displays internal temp, car voltage, as well as amps drawn.
  3. Mar 17, 2018 at 2:18 PM
    lucky13don
    lucky13don [OP] Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Would you have a link?
  4. Mar 17, 2018 at 2:21 PM
    SimplexFish
    SimplexFish Well-Known Member
    Mahaff
    Houston, Texas
    2004 Tacoma Double Cab PreRunner TRD
    @luckydon13 Clean the surface with a good quality wax and grease remover, let it dry completely before installing the mount. 3M also makes an adhesion promoter for their double sided tape line, highly recommended. Lastly, wait at least 24 hours after installing the mount before u hang ur phone on it.
    lucky13don[OP] likes this.
  5. Mar 17, 2018 at 2:33 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I use the same mount with a Rokform phone case. It’s great for Gooogle Maps. I can’t see speed below 10 or above 110 mpg but I don’t think anyone cares at either of those speeds lol
    AE040336-008B-4028-9DB9-E2D726A54321.jpg F21439D8-3F28-428F-9BC3-34EDD5631CF9.jpg
  6. Mar 17, 2018 at 2:37 PM
    seniorredwood
    seniorredwood Assistant to the Regional Manager
    Pennsylvania
    2017 TRD Sport, 4x4, MT, DCSB, MGM.
    Do the A Pillar Ram mount mod.
  7. Mar 17, 2018 at 2:39 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Links to parts. Might just replace stock radio and go with a Bluetooth head unit.
  8. Mar 17, 2018 at 2:52 PM
    05Taco4x4
    2TR-FE Enthusiast
    I saw a thread a few days ago, guy was making one that has wireless charging
    taco lifter and lucky13don[OP] like this.
  9. Mar 17, 2018 at 2:53 PM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Why not just use a Bluetooth adapter to use with your stock stereo.
  10. Mar 17, 2018 at 2:53 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Hmm, cause I didn't think of that. Good idea
  11. Mar 17, 2018 at 2:56 PM
    jrallan26
    Iowa
    I have one. Works fine. I use a GT car kit.
  12. Mar 17, 2018 at 3:11 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    It's actually the blank switch for where the power mirror switch would go in trucks that didn't come with power windows or locks but came with power mirrors.
    taco lifter[QUOTED] likes this.
  13. Mar 17, 2018 at 4:26 PM
    taco lifter
    James
  14. Mar 17, 2018 at 4:32 PM
    tntacomaguy
    tntacomaguy Well-Known Member
  15. Mar 17, 2018 at 4:32 PM
    #35
    taco lifter
    James
    If you want use the Soundstream VRN 65HB, extremely simple install and has good fitment. And fairly cheap too.
  16. Mar 17, 2018 at 4:33 PM
    #36
    taco lifter
    James
    yeah it works all the time, kinda bright so if you're one to get annoyed by a light in the corner of ur eye at night then I wouldn't get it. But it works really well, shows current in system while driving around 14.2v and when not around 12.2v. Its also cool cause you can see how much ur devices are drawing.
    tntacomaguy[QUOTED] likes this.
  17. Mar 17, 2018 at 4:35 PM
    #37
    Clearwater Bill
    Billy
    Largo Florida
    Link to your unit of choice? That sounds like a budget solution that could work with my '04 Highlander.
  18. Mar 17, 2018 at 5:00 PM
    #38
    chiz
    chiz Well-Known Member
    La Plata, MD
    2004 PreRunner
    word for word what I did, but I also used a hair dryer to heat the tape and surface up a little bit, it helped...also did that with my window visors.
  19. Mar 17, 2018 at 5:22 PM
    #39
    jrallan26
    Iowa
    https://youtu.be/b8qYQjNpLxs
  20. Mar 18, 2018 at 11:45 AM
    #40
    1997tacomav6
    Denver
    Magnetic ball mount works perfectly for me
