Celsius to Fahrenheit ?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by limitedlifted, Jul 27, 2016.
  1. Dec 23, 2016 at 4:36 AM
    #41
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    I know both. I prefer English.
  2. Dec 23, 2016 at 4:59 AM
    #42
    NINK
    NINK Well-Known Member
    Jake
    Rockdale, TX
    2016 Farmtruck
    Whatever floats your boat, buddy:rolleyes:
  3. Dec 23, 2016 at 5:14 AM
    #43
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    Anyway, I have my outside temp display changed to Fahrenheit so I'm happy. Thanks for all your support.
    dYL0n likes this.
  4. Dec 23, 2016 at 5:23 AM
    #44
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
  5. Dec 23, 2016 at 5:38 AM
    #45
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
  6. Dec 23, 2016 at 7:40 AM
    #46
    30/30
    30/30 Member
    Jamie
    Tacoma DC 4x4 with Tec Package
    I was screwing around with my head unit and found the selection to switch the units to Fehrenheit from Celsius. I thought it was great, and switched it. Then drove the truck and found that the digital speed read out also turn to miles per hour form km.
    PS: when Canada went metric the deal was the USA was to, too. But they green egged on the deal, make situation we have now. Went to school in the USA from grade 7 to 12. Never learned metric! Now I am a CNC Machinist. And all the machines are imperial!!! Thank god. (And we all have big stones up here)
    ancient11 likes this.
  7. Dec 23, 2016 at 7:43 AM
    #47
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Im more of a Rankine kind of guy
    VE7OSR and Caltech90 like this.
  8. Dec 23, 2016 at 8:23 AM
    #48
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    CNC machines are all made metric. The ball screws all have a metric pitch. There will be a configuration that makes it imperial. Because of this there are rounding errors.
  9. Dec 23, 2016 at 8:29 AM
    #49
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I look at it as metric being digital and English being analog.
    For example, in English, you would say "I live 2 1/2 miles from here".
    In metric, it is proper to say "I live 2.5 km from here.
    If you are using fractions with metric then you are like all humans and naturally think analog.
    That's my logic.
    Joe23 likes this.
  10. Dec 23, 2016 at 8:35 AM
    #50
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I use decimal inches in rafter calculations
    TacomafromTacoma and dYL0n like this.
  11. Dec 23, 2016 at 8:36 AM
    #51
    30/30
    30/30 Member
    Jamie
    True enough, you switch back and forth actually, with a G20, or G21 . But always run imperial.
  12. Dec 23, 2016 at 8:36 AM
    #52
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I travel to the US for work. When renting a vehicle, i change the displays to metric, then leave it like that when it goes back. Imagine their surprise when they figure out i've done an incredible amount of mileage in such short time.
    Had the canadian work van serviced down there for an alignment after new tires were put on. Technician wisely took the van for a test drive, both before and after. His only comment afterwards was that he thought the speedometer was way off, but couldn't figure out how that was possible. I was tempted to toy with him for a while, and perhaps ask them to fix it, but alas, they did a great job at customer service, and work, and thought better of it.
  13. Dec 23, 2016 at 8:47 AM
    #53
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Metric system?
    Oh you mean the system used by countries that haven't been to the moon.
  14. Dec 23, 2016 at 8:52 AM
    #54
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    We also did in tool & die as well as all like trades.
    In wood working and carpentry that I'm aware of is all fractional inch.
    At Home Hardware, which is a Canadian store, they sell nails and screws by the pound. Butter is sold by the pound, although its labeled 454 grams.
  15. Dec 23, 2016 at 8:57 AM
    #55
    OZ-T
    Peter North
    British Columbia
    Rafter squares have decimal inches in the per foot of run table per roof slope , and usually a table showing the decimal inch to fractional inch conversion for when you have arrived at your rafter length
    They also are in 1/8" / 1/16" on one side and 1/10" and 1/12" gradiants on the other
  16. Dec 23, 2016 at 9:05 AM
    #56
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    That makes sense. If precision is required then decimals are better.
    The term "thou" is an official unit of length.
    It's also interesting that they have restandardized the cup as 250 ml
  17. Dec 23, 2016 at 9:09 AM
    #57
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Decimal inches... like how the hell am I supposed to draw 2.373 inches along the ruler? LOL
  18. Dec 23, 2016 at 9:18 AM
    #58
    OZ-T
    Peter North
    British Columbia
    If I was using my rafter square I would draw it with the 1/10" scale
  19. Dec 23, 2016 at 9:23 AM
    #59
    0210
    Vancouver, BC
    I don't think I've ever seen imperial measurements written down along a decimal scale on any ruler/square/tape measure/anything else with units. Every inch is always broken down into 16ths. I don't doubt that you have such a square, just frustrated about people's choice in using decimal inches instead of metric to begin with. Intentionally making their lives more complicated instead of using an easier and vastly superior system just to "stick it" to some imaginary foes boggles my mind.
    Joe23 likes this.
  20. Dec 23, 2016 at 9:32 AM
    #60
    OZ-T
    Peter North
    British Columbia
    All rafter squares
